Ring. Sacred measurements
Prompt and with 188 MHz does anyone have any experience? Anyway, what this purity is? Can it be used to beginners in the work?
- Шалтай Балтай
Re: Sacred measurements
Good zdraveska Vlad N.
There is such experience
IMHO - not for everyone
working with nominalne plans. Pervorechenskiy, gives a vision of the intentions of the opponent. It requires a certain level of perception. Otherwise there may be conflicts
I think the Ekliziast: "understanding the soul of the wise man, the ascent to the valley of sadness (or tears)"
Unfortunately in most cases the intention of modern Western man, much zaprogramirovan the society (say the tag), the contemplation of this phenomenon can cause a depressive reaction may despair, "the mass of biorobots". Well if you practices ready for this
all IMHO of course
all IMHO of course
I have article 207 and 217. Picked up to compare with the rad.1000, interested in the quality of implementation of individual affirmations. Took 207 in hand, looked at the twist welding.The same was done with the 217. Went around the room, looked for where to put that, no one moved, took away the sheet with afirmou. Until this was done, I felt a powerful energonaladka themselves, and I do not need. Put the rings in the far corner, they put the ham from the nearest wish of my surroundings to subside in drunken pristavali, sat down to my computer to see the news, automatically took a SIP from the water glass - felt - the water is charged. Conclusion: devices powerful. The next morning, crossed paths with the drunk: sober, boring, nepristegnuty... Wish work... For the benefit of others. That is, the active harmonizer 207 217 plus can improve family relationships.Влад Н. wrote: with 188 MHz does anyone have any experience? Anyway, what this purity is? Can it be used to beginners in the work?
- Шалтай Балтай
Artfan
To work with the intentions, thought forms, perhaps more suitable even Forgotten (177 MHz) merc, articles, 206, 216, although it seems cal Harrison says about 188 as of a certain cumulative option 144 and 177, something is...
- Шалтай Балтай
Cheh... wanted to say "machine gun I can't give you"Артфан wrote:That is active harmonizer 207 217 plus can improve family relationships.
Harmonizer is another story. I would even say that this is the highlight of all the devices Sliema, although the most difficult in izgotovlenii. Well, let's see....
No, for me the best single-shot airguns. Watch how much he is sober will last and that stronger craving for vodka or a piece of paper with a wish to add. Thank you for the info for 206 - 216...Шалтай Балтай wrote:wanted to say "the gun I can't give you
- Шалтай Балтай
IMHO, it's his choice,Артфан wrote:Watch how much he is sober will last and that stronger craving for vodka or a piece of paper with a wish to add. Thank you for the info for 206 - 216...
I would venture to advise: do not program his behavior, program its impact on themselves. Let him drink, even in death, the main thing that YOU did not hurt.
Here's more information on the sacred dimensions
http://blog.world-mysteries.com/science ... asurement/
Hello!! crept a few questions about the size of the frequency 144мгц,if the size corresponds to the frequency that they are not the true test should be 520,075 mm ,I understand that and everything will work, but how?since the primary source says that it's resonance should be! it is of such size will not,I have GAD so this frequency resonates piece Suite wire size 52,0 cm + - depends on material<Шалтай Балтай wrote:the Main goal of a topic: to give work measurements to create the rings
Source: http://www.sacredmeasures.com/measurements.html
Types of Standards there are two: those that are ring and linear (no need to ring spinning, and so works)
Measurements for rings
Basic measurement
Frequency: 144 MHzlength: 523 mm
Basic use: Any problems 3D planthe Forgotten MercCode: Select all
|Harmonica | Length mm | Diameter | |part or | | ring, mm | ------------------------------------------- |1 | 523.2 | 166.6 | |1 1/2 | 784.9 | 249.8 | |2 | 1,046.5 | 333.1 | |3 1/2 | 1,831.3 | 582.9 | | 1/2 | 261.6 | 83.3 | | 1/4 | 130.8 | 41.6 | | 1/8 | 65.4 | 20.8 |
Frequency: 177 MHzlength: 596 mm
Usage: Work with intention, awareness, karma, past life regressReinforced mercCode: Select all
|Harmonica | Length mm | Diameter | |part or | | ring, mm | ------------------------------------------- |1 | 596.7 | 189.9 | |1 1/2 | 895.1 | 284.9 | |2 | 1,193.4 | 379.9 | |3 1/2 | 2,088.5 | 664.8 | | 1/2 | 298.4 | 95.0 | | 1/4 | 149.2 | 47.5 | | 1/8 | 74.6 | 23.7 |
castana: 188 MHzlength: 733 mm
usage: the Pineal gland
(sorry, yet more information is not, recently used, jamahal ischo)
to be continued ........Code: Select all
|Harmonica | Length mm | Diameter | |part or | | ring, mm | ------------------------------------------- |1 | 733 | 233.3 | |1 1/2 | 1,099.5 | 350.0 | |2 | 1,466.0 | 466.6 | |3 1/2 | 2,565.5 | 816.6 | | 1/2 | 366.5 | 116.7 | | 1/4 | 183.3 | 58.3 | | 1/8 | 91.6 | 29.2 |
Linear measurements
PS
At first glance it may seem strange that a high frequency ACC greater length, kiczales it should be the opposite. Slim said in an interview. The bottom line is that this is not hormonal frequency and resonance, it has its own laws. To understand this it is necessary to read Hans Becker, whose writings I can not find. There is another person, bill Ryde, a friend of slim, he is not less in the subject than slim, maybe more, but if you believe Brian, which is Infinite, the bill is strongly encrypted. In General, it all looks like a detective story, so far is....
- Шалтай Балтай
Good zdraveska CPN
FAQ No. 4
the tenth time I repeat:
we are talking about a tensor (torsion) field and not elektromagnitnom
the gear, ostilly here don't work
want to measure vozimye molecular oscillator, and mercy not on the forehead, made
PS
will carry in the flame
FAQ No. 4
PS
About the qubits. 11:53 https://www.youtube.com/watch?v=yfATfp2LBl8
There is such a thing TORTIMER SKATOVA TSM-021. Just it is designed to measure the torsion fields.Шалтай Балтай wrote:we are talking about a tensor (torsion) field and not elektromagnitnom
- Шалтай Балтай
Thank you
To me it's still a little interesting
- Шалтай Балтай
Open question: Error of the Sacred Standards. In other words, the accuracy With which to measure Sacral Measurements?
If the feelings, at 3.5 I'd say +/- 3.5 mm somewhere. A slight shift left/right gives a different response in the body.
Viking Elbow: 67.6 CM Length Elbow (443 Mhz)
the elbow of the Vikings was discovered friend, Maurice Godfrey (the Netherlands) in an old book about the history of the Vikings. He found this measure is repeated through out the book and was intrigued by it. He said Maurice, and Maurice told him Maryana. She used her dowsing skills to find out about this and they both decided to try the measure in tensor rings.
The energy of this frequency embodies the Sacred Feminine, su btle, beautiful, gentle energy, bringing the secret spark of life, like white, light pink, yellow beam of light which has no beginning and no end, with constant endless stream. It is very good for sleep and emotional disorders, muscle disorders, and has excellent results in the toothache.
Element: Water. Works on 1st, 5th, 6th and 7th chakras.
It can be used as a direct elbow. Tools that can be made from this frequency, fraction and elbow combinations: 1/8, 1/4, 1/2: tensor ring; the ACU-Vac coil tensor; Gaia sphere - 6 rings, pendant, pocket, travel and home dimensions harmonisers; seed / flower of life; the infinite heart.
Source: https://www.facebook.com/groups/1650769 ... 636895215/
Hello.
Measurements associated with frequencies and given length.
But these lengths do not correspond to the wavelength of these frequencies.
How to understand this?
- Шалтай Балтай
Good day, SpinСпин wrote:hi.
- viewtopic.php?p=152728#p152728
Шалтай Балтай wrote:PS
- FAQ No. 5
- PS
You need to understand that we are not talking about the electromagnetic field is a tensor, or, IMHO a torsion field. "Video" "3D" logic does not work here.
- I tried porrazzo with the numbers, but it's all nonsense:
viewtopic.php?p=160262#p160262 - Some people the word MHz is associated with the oscilloscope. It only returns an associative, I would even say the pattern of thinking. This was taught in school. Here such a model is untenable.
Re: The Ring. Sacred measurements
I do not understand why your measurements over to 3.5?
I Aku – VAK made 5 measurements and it seems to me need more.
And even as the Ark VAK can be made from 3.5 m – just a little work?
- Шалтай Балтай
Good day, ValeВале wrote:I don't understand why your measurements over to 3.5?
The measurements given above were derived experimentally seeing the familiar slim, and they themselves, as doperom.
Casellino 5th measurements, personally I have no knowledge about it. Maybe this is a working version, maybe not quite. No data
here is a photo of Aku-Vakov 3.5 Measurements:Вале wrote: And even as the Ark VAK can be made from 3.5 m – just a little work?
https://www.youtube.com/watch?v=AhqNtzz ... ture=share
The project Cymatics - a very interesting topic ( to this day, there are 13 episodes ).
The calculation of the qubit ( due to the size of the pyramids at Giza ) - 1:00:21 1:01:02 and 1:11:15 1:11:54 - https://www.youtube.com/watch?time_cont ... 3kNGIcNDA0
Actually, very educational film about the pyramids. For example, I learned that each of the 4 sides of the pyramid is refracted exactly in the middle, and it is visible only in the days of the equinox ( photo and types included ).
Расторгуев
Tell me, if we do say ring 7mm 59cm and the wire Merim before twisting or after twisting?
After plying.Расторгуев wrote: ↑Fri Jul 26, 2019 16:16Tell me, if we do say ring 7mm 59cm and the wire Merim before twisting or after twisting?
