Wallpapers for rise of the energy of the room
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Re: Wallpaper for the energy of the room
Post by мимоходом » Fri May 29, 2015 21:52
I? Magic learning. Here's a little bit about ancient magic learned:
I suspect that ancient magic was very aware of this and picked up the cloth in such a way that in them as in a maze view, a negative impact was STUCK.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:03
well, if you learn Magic, then you need to Hear someone else's perception )
just the perception has always imposed some terms. Holography, Toriniku - modern developments will not disappear.
For example, a bunch of different plates made of bio-resonance according to this principle, (the effect of a hologram)
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:06
the pattern on the clothes as labyrinths - it worked
to them as the maze - the look, the negative impact was STUCK.
but on the female it can see better, they have energy more vulnerable, so the patterns more
мимоходом
Post by мимоходом » Fri May 29, 2015 22:10
That's for sure, without them anywhere. I've read about modern developments that holography is the recording of electromagnetic radiation with accurate reproduction. That is, opened in 1947 that the light can be recorded as sound (via laser coherent radiation). And be reproduced as sound. But I never met that holography is the patterns on the shirts of the 18th century, embroidered with a cross.
What did you read about holography?
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:13
do not read )
just see the application of these technologies in 1. the plates and 2. the effect of drawings - such as Tibetan mandalas
holography is not the effect, but rather the principle - when in one point of space there is information about the whole.
if the EO is very simple - "all in each part“
мимоходом
Post by мимоходом » Fri May 29, 2015 22:17
holography is not an effect, but rather the principle - when in one point of space there is information about the whole.
who told you that? Holography was invented classical science and gave it a specific definition. And determined the methods to create holograms.
Now I will try to explain as simply as: holography is the same as audio recording. Or no, let's even so - the same as the entry on gramplastinki, only for the other range.
Well, I understand, in the late 19th century and who can worshipped gramplastinki, Papuans some. But in the 21st century...
As for the mandala - that is the picture for self-hypnosis to enter trance state. What does the hologram (such as the principle of recording light)
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:20
a lot of sources, Google. The idea is that the hologram is also a philosophical principle. Ie in any part of the universe has information about the universe.
for example I was told by Michael Talbot:
a Hologram is a three-dimensional photograph made with a laser.
To make the hologram, first of all photographed object must be illuminated with laser light. Then a second laser beam, flowing into the reflected light from the object, gives an interference pattern which can be recorded.
The picture looks like a meaningless alternation of light and dark lines. But it is necessary to illuminate the other laser beam, as immediately appears a three-dimensional image of the captured subject.
Three-dimensionality is not the only remarkable characteristic of holograms. If a hologram is cut in half and cover with a laser, each half will contain the whole original image. If we continue to cut a hologram into smaller pieces, each of them we again find the image of the whole facility. Unlike normal photographs, every portion of a hologram contains all the information about the subject.
The principle of the hologram “all in every part“ allows us a fundamentally new way to approach the issue of organization and orderliness. Almost for as long as Western science developed with the idea that the best way to understand a phenomenon, whether a frog or an atom, is to dissect it and study its constituent parts. The hologram showed us that some things in the universe that we can't afford. If we are going to dissect something arranged holographically, we will not receive parts of which it is composed, and get the same thing, but smaller in size.
http://galactic.org.ua/pr-nep/Fiz-4.htm
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:22
as for the mandala - that is the picture for self-hypnosis to enter trance state. What does the hologram (such as the principle of recording light)
despite the fact. what's the idea of the holographic pictures ? the fact that physically, they flatand when you look at them they bulk.
understand ?
that's why I said about the holographic nature of nettle shirts. from it the feeling is. it's done so.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:24
incorrectly. holography is a 3D movie. And there is a normal movie, not 3D.
Here len is a regular movie, and nettle - 3D ))))
новый Искатель
for the transition to the trance state. What does the hologram (such as the principle of recording light)
despite the fact that physically flat image - when staring at her - becomes three-dimensional and deep, three-dimensional, falling into it.
мимоходом
Post by мимоходом » Fri May 29, 2015 22:27
the idea is that the hologram is also a philosophical principle
Well, as a philosophical principle then? Here you sticker showed. She is laser-etched, according to the method, which was described by the scientists who invented the laser and discovered the monochrome radiation.
But let us not be distracted. As the nettle shirt of the 18th century can be "holographic", if the very concept was invented in 1947. It was not before. Even the esoteric, which are like magpies dragged beautiful scientific buzzwords for the collection. Well it was not all. Just imagine: Lenin gets on phonetic and shouts, "ooga, my, holography of svershilos!" Or Blavatsky writes in his memoirs "a long time ago at the dawn of time have lived on earth among the holograms". And then another man lapotnikov land, who knows five words, the most important of which is "help!" - embroidered so imagine a holographic shirt... Well, it was not the same. Clarify just in case, and something else will go Blavatsky quote...
You, my dear, better finish secondary education with a normal score (if wrong - sorry, judging by your literacy, are to blame). Then get a higher education. Then get a family, give birth to children. It is given to man for 30 years. And before then better not try to go into the esoteric. The magic is, but it has its time and the fruit should ripen. And before to ripen the fruit needs to be trained and to continue itself in the offspring (then just health will not allow). But if all the time not to do - then Yes, the road to charlatans
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:41
elementary. in every individual - is a part of society as a whole. for example, you and I belong to Russian culture. although very small the particles.
in every cell of the body, there infa about the body as a whole.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:42
http://kosmoritm.narod.ru/fractal3.htm
1. The principle of the hologram
There is probably no such person who at least "vaguely" heard the famous Maxim attributed to Hermes Trismegistus "on top and bottom". These words are taken from the emerald tablet, is named after him. Emerald tablet of Hermes Trismegistus occult code of the ancient Egyptians, the deeper meaning of which is still relevant.
Talented Russian psychic S. N. Lazarev in the book "Diagnostics of karma", 1-ing part of his work also describes the holographic nature of the Universe:
"...A necessary condition for the existence of any organism is uninterrupted contact of each of its parts with the center. To part worked successfully on the whole, it must consist of two matrices. The first matrix of the whole with which she identifies, the inside contents. And the actual matrix that is form. They are dialectically opposed to each other. In simple terms: the part should contain information about the whole principle of holograms".
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:44
my dear, I sending you send Lazareva, Hermes Trismegistus, Kabbalah, and others - to explore the link, and send the other to study higher education. You are a typical what guy 50-60 who stopped and numb in development. See old men. It is very similar.
- learn http://kosmoritm.narod.ru/fractal3.htm
and I'm not you dear ))) I harmful )))
мимоходом
Post by мимоходом » Fri May 29, 2015 22:46
The holographic principle put forward a theoretical physicist in 1993. Has nothing to do with holograms, lasers, stickers, spirituality, and Lazarev, grab a nice shiny thing in the slot.
Physics-theorist, it is one where you have to invent all the options possible. Then to figure out how to prove it. To give academic test task to prove, and it may take 50, 100, 500 years for the proof of the theory.
Sounds that assumption here it is:
All information contained in some region of space, can be represented as a "hologram" — theory, which lives on the border of this region.
Theory on the borders of the studied region of space should contain, at most, one degree of freedom at the Planck area.
For example, if we consider the University cafe, then the holographic principle asserts that all the physics present in this cafe, is determined by physics on its walls.
Source of this hypothesis is the so-called AdS/CFT-correspondence, which clearly shows the mathematical equivalence of quantum field theory in space-time is anti-de sitter dimensions 3+1 and conformal field theory in space-time of dimension 2+1.
Now, this assumption is a theoretical physicist, so the work he has to assume imaginable and unimaginable. This assumption not only that it is not proven - there is not even evidence for it. Well, just a funny wrapper to himself. Type assumptions "the rat heart bigger than a crocodile"
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:47
I have to back up your information, my dear, a bunch of links. What supported you ?
it can you not climb where is not necessary ?
I'm okay, but Lazarev, the Kabbalah, Hermes Trismegistus. It's all charlatans ? well, okay, my dear.
higher education I received in 2002 , and according to you of you need to higher education to burn with a hot iron. Higher education is a terrible thing, if they person very seriously engaged.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:50
it Sounds, this assumption like so:
wiki to petite and I can
here, read this
about the hologram Slavic shirts - I said that there is this principle. not Lenin on a tank armata.
and the principle is not Wikipedia, we're about the esoteric actually. and you got me into science drive.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 22:53
here you Lazarev, can from the point of view of Wikipedia to criticize ))))
and polunischego education....
Then:
"...The holographic nature of the Universe in space means that the subtle universe is a point. And because the plan is associated with a primary thin, any area of the Universe has complete information about it. It turned out that the universe is holographic and time. That is, a thin primary plan past, present and future also represent a point. Therefore, in any ongoing process is hidden information about past, present and future. And externally damped processes in the higher plane and continue their existence. The event forms consciousness and influences it."
Or here's another:
"...our subconscious mind is a field structure of a more subtle nature, which just duplicated the body and brain. Because the universe is holographic in time, on the subtle planes past, present and future are compressed into a single point. That is, they hid all the information of the universe. In simple terms, our subconscious knows everything. We know all that was in the universe, all that is and all that will. So if you don't slow down our inner vision, our consciousness will burst like a soap bubble and our brain atrophies".
мимоходом
Post by мимоходом » Fri May 29, 2015 22:56
Let's very simply explained, it is not difficult )))
Hologram. The circuit of the invention follows:
coherence(1928)-holography(1947, analog recording on gramplastinki) laser(1960) - hologram (1962) - a hologram of the 21st century in your photo above
the Holographic principle
Invented a theoretical physicist in 1993. Then he has a principle borrowed Lazarev, distorted beyond recognition. Then Lazarev has distorted you, giving already perfect story
These two inventions-the principle unrelated, while the second not only is not proven, so you have it and from memory can not repeat even there pure mathematics
Like all figured out, it is not clear how the invention of 1947 and theoretical physical principle 1993 appeared on the shirts of the 18th century. There are no time machines don't do, will have to introduce her to the concept.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 23:04
me, too easy.
your world scientific. my no. that's all.
on the shirts of the hologram was not there. on shirts is the principle of the hologram. the projection on the plane of the volume. (and I'm talking about energy, bio-energy fabric, not physics)
you agree that the hologram is the projection of the VOLUME through a PLANE ?
Yes/no underline.
and I'm talking about ENERGY.
or BIOENERGETICS.
[I think the lasers and official definitions. bioenergy vkurse what ?
here in the bioenergetics principle of the hologram is also elegant and works. good luck.
мимоходом
Post by мимоходом » Fri May 29, 2015 23:07
good luck.
Thank you! Good luck in mastering of matter )) It's not easy, nothing helped.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 23:09
actually had a view of holography in bio-tissue. and why you began to look for there physics.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 23:25
then I probably will be on this sequence and scheme as YOU. well, since you suggest. no thanks, I think. :?
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Sun May 31, 2015 10:37
новый Искатель wrote:and the more specific you can advice ?
and something like that vaguely, and about anything.
Sorry, was away.
Either You do everything yourself, based on Your feelings, or use the advice of people, respected in certain circles. For me tips Yevgeny Kolesov (Het Monster) like. This is a separate room, it is desirable to avoid unauthorized people to enter it only in good (a particular state. If you are practicing any magical practice, in the case of Kolesov's divination, it is only in this room. During practice opens a channel through which the energy. Opens after some time after start and closes after a while at the end. if you practice every day, the channel will open more and sooner (from the beginning of practice) and closed later (after practice). Well, there comes a time when it is open constantly. Even if you do not practice how, it is still present. This seems like a chill, partly as lowering the temperature in the room, partly as the capability of being in a stuffy room with a high temperature and feel comfortable. :) Initially, this room is really comfortable. But to live in it better not, transformation is too serious. Firstly, the body could not withstand such energy, the second for life happen from the point of view of the common man, different shit.
Drawing on clothing only corrects the energy that creates the fabric. In the early 90s I tried to knit sweaters with different patterns. Even where the book left on this topic. But it was too difficult to sustain correctly the pattern on the clothes is almost impossible. Easier just to buy stuff at the moment, in tune with my condition, intuitively.
Mine is not yet considered pattern? not mandalas and paintings. Painters such as Nicholas Roerich. Not, of course, here money is not enough, and the directions.<
новый Искатель
Post by новый Искатель » Sun May 31, 2015 15:32
For me the advice of Evgeny Kolesov (Het Monster) like.
where are these tips you can read ? he then wrote
