Bracelet Gene/Reanimator 1.0
Аиша
Has thanked: 56 times
Been thanked: 14 times
Re: Bracelet Gene/Reanimator 1.0
Post by Аиша » Thu Jan 08, 2015 4:48
Michael! Bracelet is something! 8) My body felt))) Not that I didn't know where that is, :shock: but with the bracelet now I know exactly :) Dismantled for parts and put on problem areas.. 2 nights was sick! :roll: 1 Bracelet is clearly not enough for thrills :lol: Can you create a suit, like diving :oops: Schoby much time and covered :wiz
Денис87
Post by Денис87 » Fri Jan 09, 2015 1:58
where better to start using a newbie with this bracelet or bracelet 2.2?
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Fri Jan 09, 2015 7:29
In the General case - with 2.2 :)
Post by Михаил_ » Fri Jan 09, 2015 22:15
Genome/Reanimator is a separate and optional product, well after some time of using any other BJ (month+).
You should start 2.2 or (better) OS 2.2+ or Panacea (panacea but a 2.2 - different things, it is better to have both or at least the experience with them for several months). Panacea can free easy to do, although they are great part from the commercial, but the experience will. Well, that's if the finances closely.
ИгорьС
Has thanked: 5 times
Post by ИгорьС » Sun Jan 18, 2015 23:26
Received yesterday. One for me and one wife. Feeling a little different. I have a feeling of fullness in the region of the solar plexus and all. Wife says looks like a "Brownian motion" in the body. Boom watch.
Well, here it is. After a couple of days, first I, then my wife the exact same symptoms of the viral disease. Is it a coincidence or a bracelet can make it "clean"?
Аиша
Post by Аиша » Mon Jan 26, 2015 23:05
In General, exacerbated by the entire genome Chrono in the body, but like the rest of the BZ, which first used. It is noteworthy that about some "children's" ailments long ago forgotten. Depression and other manifestations not observed, on the contrary, I want deistvuet and implement, the mood is optimistic. Question to Michael: "can I insist the water on the Genome, to speed up the process?or use a Panacea? "
Павел Борисович
Post by Павел Борисович » Wed Feb 11, 2015 14:23
Inappropriate-not suitable, is not affected in any way, but there is reason to think not to have them (feelings) abstract self-development - have published many techniques and methods for doing this....
I'm sorry, "a lot of techniques and methods," published on this forum or should I search the Internet?..
Аиша
Post by Аиша » Thu Feb 12, 2015 1:53
On the forum there and the Internet is. On the forum checked)))
Артем север
Has thanked: 141 times
Been thanked: 29 times
Post by Артем север » Sun Mar 29, 2015 17:24
Question: what is the difference of the bracelet from the broadcast? Functionality. Leaves bracelet 9000, and the Genome of stream per year for a total of ~32000 including slots with on modes.
And of course I like some of the responses: "if you don't understand ,this is not for you"...
5 points easy!
Андрей С.
Post by Андрей С. » Sun Mar 29, 2015 22:39
The bracelet works through the local zone of contact with the physical body, the stream works on a completely different level of experience/layers of the cocoon and different principles of action. Acts, of course, different - not better or worse, just different. It's kind of obvious, and if they are not clear to you, it can actually... premature? :) Alternatively, you can use intuitive / passive mode.
Артем север
Post by Артем север » Mon Mar 30, 2015 3:49
Андрей С. wrote:Bracelet works through the local zone of contact with the physical body, the stream works on a completely different level of experience/layers of the cocoon and different principles of action. Acts, of course, different - not better or worse, just different. It's kind of obvious, and if they are not clear to you, it can actually... premature? :) Alternatively, you can use intuitive / passive mode.
Well, maybe it is clear to me that the bracelet is worn ,and the stream broadcast.Wanted more in the matter of unsubscribe, but prematurely I thought, "what and so the question will be clear".
The question again: what is supposed to recover the Genome? What is the aim of the program broadcast "by default"? What should be with the person after about a year and a half the broadcast? It is that of the old man, the drunk will become sober rejuvenated Prince with high morale(well, it is, figuratively)? The manufacturer is the same as that with which we took the idea of this broadcast, and knows what she needs to do and what needs to change in a person? It is clear that all individually, but there is some sort of "minimum program"?
And why is the stream more even with three bracelets Genome? If works better, how? If the bracelet was worth 32 t live year 32 t R, then the question would not have happened.
I have the Genome for about a month, there is change , but I wonder what should be in the end of the Program broadcast during the work year more than a year, what is the result supposed to be?And how to understand what all happened, the way passed, I recovered, cocoon is also, time off the stream ...?
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Mon Mar 30, 2015 12:06
Tom, for every answer you you have to be born in mind still for 10 questions, and all because logically it's not to explain, and understanding comes through intuition, through feeling, what it is, through feeling, I need it or not, although the logic is also needed, but she's not home.
And for you, no bracelet, no stream, nothing will not do - they help you use your resource, guide, teach (to a greater extent on the unconscious level).
Read the forums, reports of other people, with time comes understanding
Артем север
Post by Артем север » Mon Mar 30, 2015 12:24
Petr99 wrote:Tom, for every answer you you have to be born in mind still for 10 questions, and all because logically it's not to explain, and understanding comes through intuition, through feeling, what it is, through feeling, I need it or not, although the logic is also needed, but she's not home.
That is, it is an inner "stimulus-pusher" with a clear on a subconscious level, a map of actions to achieve a normal state of the body?
Petr99
Post by Petr99 » Mon Mar 30, 2015 12:34
Yes, you could say that. In our regular life, no (don't talk about it, it is not used nationwide) recognized for the imaginative libraries, which could be explained, but everything works on the unconscious level. And when the person recovers and expands his consciousness (proportional recovery), these things are beginning to move on a conscious level, the person begins to understand and here it is already possible to use logic. While this time can be intuitive: "I like it, but don't like it" or "I feel like I really need it"
Post by Михаил_ » Wed Jun 08, 2016 16:14
АндрейКо wrote:Maybe a coincidence, but wearing a bracelet of Genome-Reanimator became clearly and constantly see the aura of people. I will not say to interfere, but we can't turn-off... See all.... (of course with AMB snake wood)
But there is additional information about people ;-)
Post by Михаил_ » Thu Jun 09, 2016 12:58
АндрейКо wrote:Using Genome-Rescuer allows you to push if there is a certain stagnation (reaching the equilibrium point that is) when using other products. In my case this applies to AMB. Currently wearing 1 AMB and 1 genome Reanimator - the action progress and feel stronger than when wearing two AMB without Genome-Rescuer.(this applies to the current state)
Also seen in relation to the broad Panacea ebony.
Generally very strangely small number of reviews about this product on the other.
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Mon Oct 31, 2016 1:35
Removed as not containing useful information on the topic.
Post by Михаил_ » Mon Oct 31, 2016 5:29
Reread several times, I thought, read more :)
Even funny and here genome-Reanimator in the batch of AMB interesting...
That's how I live, so I am surprised - everyone personally so myself, the universe, sometimes even among friends-familiar people is something but it is like completely unexpected, and seems so deeply and know well.
As to the message that I frankly did not understand what happened and with a hangover :)
Genome-Reanimator works with what gariaev and his ilk call the holographic part of the genome, t/e/ s information and fix it,something like a check disk with fix broken files.
By itself it is pretty harmless, though, and is a load.
AMB a thing in itself in terms of what algorithms are such that he very often throws out non-standard solutions. A combination of both?
T/e then it would be interesting to understand what changes it caused (just for the sake of a deeper understanding of this funny incident).
Amused :).... almost as much as mushroom rain from the sky (thought it was the sprinklers on somebody's poorly set up, and it happened everywhere and small-small like dust.And the sky Sunny and clear...
Тимоша
Has thanked: 21 times
Been thanked: 5 times
Post by Тимоша » Mon Oct 31, 2016 17:59
What is taken as the standard? Which matrix is the restoration (Adam Kadmon?) and where is the access?
Post by Михаил_ » Thu Nov 03, 2016 1:51
Тимоша wrote:what is taken as the standard? Which matrix is the restoration (Adam Kadmon?) and where is the access?
PRETTY amuse :)
Overall it was described.
The standard taken the human genome to its violation modern.(the ancient version).
The term "Adam Kadmon" was introduced in a particular school and show me where it is still used for the tail was not dragged there. Behind him hangs the real thing, but not is not harmonious neither with the working condition, it is a distorted genome gene-modified body, where everything is disabled.
And about access finally funny.
First he is at all. Although there are plenty of fun trends to know the head so that all that is closed. Closed but someone's private development. I demonstrate at workshops, what your own correct precisely the genome available to all, at least in LM.
Secondly, my access level is missing in all reasonable cases, than again many people had the opportunity to see for yourself :)
Success.
Тимоша
Post by Тимоша » Thu Nov 03, 2016 8:20
Thank you, Yes this is the same "favorite" school, and private attitudes of people that are known to all, love to uncle Bob.
Post by Михаил_ » Sun Nov 13, 2016 0:57
Now publish a new package of translations from the field that included filling in "the Ridge". There will be another Genome, third :) more precisely the 4th :) (1 in the transmissions, one club, one bracelet, and it's the 4th:) ) and what's funny - all different.
Just people much asked on my forum that filling comb in the Studio (broadcast) due to a vivid feedback on her work.
Анька
Has thanked: 45 times
Been thanked: 12 times
Post by Анька » Tue Dec 06, 2016 13:55
Michael_ Good day! Bracelet Gene/Reanimator 1.0 can help to get rid of the blocks in the body? There is already Nookular Body and recently got the Card Chronos Delta effects are, but I would like additional product, because I feel that the units are very deep and hard, hard work, slowly but surely unwinds, but I would like more help and power from any product. Tell me how reasonable the purchase? Thank you.
Post by Михаил_ » Tue Dec 06, 2016 14:11
Yeah, good Nocera :) I mean I have already Nocera, genome-Reanimator thing diversified, but with blocks I would start to work even with self-made panacea. And purchase nothing, and the effects are there. Just gene-Reanimator better if you use any BJ, for some time, including homemade. And it is not blocks.
And Yes, we all have a lot of things.
Recently, Pandora black homemade appeared - try it too ... is fast, is - 1Jn notebook sheet and a little time.
Blocks in the body, they have the flaky nature of the psychological component of the home in my opinion. T/e are some mental attitudes which came out of the cocoon on the level of afirca and began to "ossify" in physics.
Construtor relationships (in projects) also help. Because it usually fixing channels or hooks which are pulled. About pendants/cards from other manufacturers do better not to ask, I fakticheski not in contact, so the interaction with them do not say anything.
In General, before you buy something, try to do so much just laid out. Then what will buy to understand on the basis of the experience and maybe to buy not required. Or to do or not like. Genome by the way also homemade you can make, if I remember correctly. Forum to help You.
PS good massage too, by the way to help... from a local product would highly recommend and use myself vibroplate the couch and Megan, though and now expensive, but the massage nothing replaces of course, he must be very... qualified. I mean the blocks. Because they are already on muscle-physical layer out normally. I just took it all and remember it clearly. Thank you for your question.
Анька
Post by Анька » Tue Dec 06, 2016 14:28
Well then good evening)))) thank You for the answer :) And the bracelet is way too long already, 2 this Bracelet of life 2.61 (ebony). Thanks for the advice will look homemade, maybe that will do) Massage, so good thing I went somewhere a year ago and Thai and an osteopath and want again to be like very interesting to look at the effect when a lot of blocks left. So I'll pass :) all what you say is well understood, although I didn't even know what blocks the chakras, and so on :)
