Will try, thanks! And from mp3 intuition as something you can purchase? And maybe even for the owners of "Navigator" release disk with similar combos. sessions, to be able to buy?Андрей Патрушев wrote:Vlad Jaruszewski
Easy. Open the file in the editor sessions for the Navigator to explore the frequencies and to sound totally, simply change the extension to identify - with the old format it is.
With visualization also probably pass, but since intuition will not work.
Vargan Trance - combined session
Влад Ярушевский
- Has thanked: 5 times
Re: Vargan Trance - combined session
One time I was going to do, but then decided that a lot of fuss, but to no avail... Audiostrobe is only a pale shadow of what can give a session of Pathfinder.Влад Ярушевский wrote:And from intuition mp3, like something you can buy? And maybe even for the owners of "Navigator" release disk with similar combos. sessions, to be able to buy?
Влад Ярушевский
Thank you. Then we slowly move to the Navigator.Андрей Патрушев wrote:One time I was going to do, but then decided that a lot of fuss, but to no avail... Audiostrobe is only a pale shadow of what can give a session of Pathfinder.Влад Ярушевский wrote:And from intuition mp3, like something you can buy? And maybe even for the owners of "Navigator" release disk with similar combos. sessions, to be able to buy?
However!Андрей Патрушев wrote:Audiostrobe is only a pale shadow of what can give a session of Pathfinder.
Okay, while I do not understand. As familiarity with the "Navigator" will understand.
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
Yesterday fotofacial /otocenie do with some time until satisfiedРостислав wrote:thanks for the tip Cesare)
- Иван Славов
I really need help.
Can't download additional session on Navigator via card reader. Writes that the error of the I / o device.
A good Navigator successfully reflash to version 2.0
In the instructions, other than recommending to use a card reader to record additional files, there is a phrase: "the work of the WUA "Navigator" as a MSD device is very useful for recording and deleting sessions..."
Please explain to me how in this mode is to use the Navigator when connecting to the computer?
So I want to "powergaming"...
Or to give preference to the entries using card reader, after buying a new one?
Simply by connecting your device to your computer, no files are copied. The copy process is like, but in the Navigator, then the new files don't see (copied to the appropriate folders). And when you re-attach sort the files copied to the microSD Navigator does not see
Miracles.Светочек wrote:And re-attach sort the files copied to the microSD Navigator does not see
If the Navigator is enabled after you connecting the USB cable, it is defined as a standard USB flash drive with folders. Via card reader is much faster, but it is possible through Navigator.
The whole evening trying, and then all chudesatee and chudesatee... even connect with two different laptops I tried - same thing: the copy process can be seen, appears in the appropriate folder in the Navigator file.
Then turn on again without the computer, and file no. Again connect your device to your computer as a flash drive, open the folder with the special session and there is no files.
Through a search trying to find on the Navigator - no... gone...
And the same story happened yesterday, when in a folder with the gate tried to fill in the files of the Solar Wind...
what else can you think in such a situation, that copy managed?..
Андрей Патрушев wrote:Miracles.Светочек wrote:And re-attach sort the files copied to the microSD Navigator does not seeTry a simple search on the drive.
Алексей Крячко__
- Been thanked: 17 times
is it possible to test the same with another memory card type MicroSD ? If the other memory card will be written and work with the "Navigator", it means that the problem it.Светочек wrote: Can't download additional session on Navigator via card reader. Writes that the error of the I / o device.
For starters, you can just put a new MicroSD card into the GPS and turn it on. In this case, it will be created automatically with all necessary utilities folder, it will briefly display the message "Creating folders...". Then you can turn off, remove memory card and try using a card reader to record or after a shutdown to connect the USB cord, then turn on again the device and in mode flash memory to rewrite directly to the folder SES_SPEC.
Alex,
Over the past two days on the computer and the Navigator learned more than during all the years of their operation in their own interests
Yes, the problem was the memory card. Took a new, trial recording is successful.
Well, as You can guess I with his delicate perception of technical processes did not immediately Mature enough to understand that when programming a card Navigator, if there was no pre-installed sound files, they are there and will not appear if they are not specifically there to record
And at first thought that they're just automatically appear when recording ON... Therefore suffered I
Now copied all the setup files from the card to which nothing more is recorded, after making a copy on the computer
Thank you for your attention and podderjku went to Varganov
Nope.Дмитрий Т wrote:I Can recommend the harp for meditation, my whole body chilled?
