And, Yes, the question is removed... That is puny green men with large heads and compound eyes are prettier...
Out the ganzfeld phenomenon
Re: out the ganzfeld phenomenon
By the way, if during the experience not to sit and stand, the muscles should not disable or experience fail?
who wants to make MindFold (an absolutely black patch) just need to cut out the BLACK foam rubber points, not really points but a mask with holes for eyes and the front surface of the optionally, you can seal anything material type from old floppy disks...
"Let's argue on taste of oysters with those who ate them."к-13 wrote:for Nothing, agent Scully better than aliens)))
M. Zhvanetsky
Detail as possible about the MM, particularly for a Navigator? In particular, the reproduction of the ganzfeld effect. What color scheme, sound, what mode, etc. nuances.к-13 wrote:the Mind-machines lucky for them, the ganzfeld effect is the tool for the job - enough to accommodate half ball under the glasses, and you can use them with open eyes to receive a whole bunch of States - a much faster and more efficient than other ways. On the Navigator, perhaps better than should be
I would like to learn about the inner work on yourself during the observation of the effect, go into trance after all
(including about the possibility of working with a conductor on its effectiveness in this case).
K-13
in the classic version I understand you can also unsubscribe from fluorescent lights and replace it with ultra-bright diodes, they do not bask, face sweat will not
yeah, I also wonder how Ansfelden to work through the Navigator...1Андрей1 wrote:K-13 wrote(a):
The Mind-machines lucky for them, the ganzfeld effect is the tool for the job - enough to accommodate half ball under the glasses, and you can use them with open eyes to receive a whole bunch of States - a much faster and more efficient than other ways. On the Navigator, perhaps better than should be
To start pure introspection - interpretation of images, associations, logical connections...Райдер wrote:I would like to learn about the inner work on yourself during the observation of the effect, go into trance after all(including about the possibility of working with a conductor on its effectiveness in this case).
To experiment, experiment and again experiment))) I Advise you to start with red color and alpha up to the boundary with the theta.1Андрей1 wrote:detail As possible about the MM, particularly for a Navigator? In particular, the reproduction of the ganzfeld effect. What color scheme, sound, what mode, etc. nuances.
For Pathfinder specifically, do not bother, while others are well suited several layers of tracing paper, taped at regular intervals on the entire inner surface points - light is much less, but it is distributed on almost the entire surface of the fuzzy spots and that is enough for bright images.ЗОМБИ wrote:K-13yeah, I also wonder how Ansfelden to work through the Navigator...
Incandescent bulbs in the chandelier on the ceiling are quite suitable.in the classical way I understand it is also possible to withdraw from the fluorescent lights and replace it with ultra-bright diodes, they do not bask, face sweat will not
OK, I followed Freud (the interpretation of dreams)
No, it is better to try the old fashioned way with balls. By the way, there are led flashlights from 200 lumens. Taken in a Chinese shop so 270 lumens , blind let God (scary to think about 1000). they are not expensive.к-13 wrote:To experiment, experiment and again experiment))) I Advise you to start with red color and alpha up to the boundary with the theta.1Андрей1 wrote:detail As possible about the MM, particularly for a Navigator? In particular, the reproduction of the ganzfeld effect. What color scheme, sound, what mode, etc. nuances.
ZOMBIE seen on Amazon MindFold at 12-15.e. worth taking? Just me in the dark pass out quietly in sleep. Write in detail how and what to do with this thing.
This phenomenon can be used as training for entry into the state of "body asleep, mind awake" or it's not quite the processes in the brain will work? I have quite a long train and autotreninga and all the way, max only sleep for 30-60 minutes work.
do foreign authors of any inventions (floattank, mindfold) usually guzzle LSD-25 and only then enlightened with their units1Андрей1 wrote:ZOMBIE seen on Amazon MindFold at 12-15.e. worth taking? Just me in the dark pass out quietly in sleep. Write in detail how and what to do with this thing.
I have not tried it... nor LSD, nor mind a fold... only parts for Assembly mindfold lying around for several years already
I understand that Yes, is similar to training with MM reflex to develop...Райдер wrote:, This phenomenon can be used as a training
In principle, Yes. Status similar, and if loosening, can be easily obtained from the first second. But better still techno Monroe to use - it's still his patrimony...Райдер wrote:, This phenomenon can be used as training for entry into the state of "body asleep, mind awake" or it's not quite the processes in the brain will work?
In principle, we need only to ramp up state (lower frequency) and to maintain wakefulness. Session with SMR (sensory-metronymic rhythms - 13-15 Hz) this is also the purpose - I understand that some frequencies are stimulated, but in the end occur 2 times below 7 Hertz (the border of alpha and theta) is the frequency which is often out-of-body experiences occur, if you believe the reviews, although there is also not so simple.I have quite a long train and autotreninga and all the way, max only sleep for 30-60 minutes work.
I'm about 3 years ago a little easier at Bronnikov on the website took only my and nose closed until his upper lip is also absolutely not transparent, only the purpose of her somewhat different (looking at my hands through it, for example, or to walk at home) - a very interesting thing. And so, I can use regular goggles (they are very comfortable and they fit snugly to the face usually still every trip to the mountains forget them at home and have to buy new ones) and from the inside in several layers of food foil is pasted.ЗОМБИ wrote:do foreign authors of any inventions (floattank, mindfold) usually guzzle LSD-25 and only then enlightened with their units1Андрей1 wrote:ZOMBIE seen on Amazon MindFold at 12-15.e. worth taking? Just me in the dark pass out quietly in sleep. Write in detail how and what to do with this thing.
I've already no less than Robert Monroe trust
How can you trust someone with that avatar?
Look closely in a profound expression of this Fox Icarus - that's exactly the attitude I have to life - just caught up with this bird, I often don't even know why she gave me and why I was sweating so much, chasing her, is disgusted, and let go of pity, and there's only that much more beautiful flying. The process for me much more interesting result...
It is not necessary to put on me the importance, I'm not worth it - let's together chase after any bird, and then think about what we want to do with it)))
So I'm not the only one chased after them .....)))))
