Audiostrobe drives
What is audiostrobe drives and impressions about them
Чиосана
Post by Чиосана » Wed Jul 02, 2008 19:23
Thank you, with disks sorted out. But audiostrobe, even more confused.
Using the machine as audiostrobe decoder when listening to CDs
session is not needed? Then it turns out the session to listen to separately?
Been thanked: 182 times
Post by Андрей Кабанков » Wed Jul 02, 2008 22:43
Чиосана wrote:Thanks, with disks sorted out. But audiostrobe, even more confused.
Yes,that's right.
Чиосана
Post by Чиосана » Thu Jul 03, 2008 11:16
Do not think for molestation. Kind of understand now, but I want to clarify.
Tell me, then session you can still listen to regular cd drives (nature, new age, etc.).
Thank you
Post by Dimas » Thu Jul 03, 2008 13:06
Chisana
Incredibly true,Chisana!
Сабуро
Post by Сабуро » Mon Jul 07, 2008 4:52
What format AudioStrobe CD?
Is it possible AudioStrobe drive to pump on flashplayer and flashplayer to mindmachine or the decoder? I still see and hear?
Thanks for the reply.
Post by Андрей Патрушев » Mon Jul 07, 2008 10:04
Сабуро wrote:what format AudioStrobe CD?
Recorded in normal audio format.
When downloading in wav format You will all see and hear. :)
Post by Гость » Sun Jul 20, 2008 6:05
But if I have no CD player nor the desire to take...
Can you please tell me what else (except for CD) can be used to listen to them together with MM
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Sun Jul 20, 2008 9:48
Any device that can play music CDs. For example, a computer.
Яуген
Post by Яуген » Fri Dec 05, 2008 13:56
When listening to an AudioStrobe CDs (explore, Healing) glasses ColorTrack is only one eye. When listening to the built-in sessions or two. What could be the problem?
Post by Dimas » Fri Dec 05, 2008 13:58
Augen
the brightness on the device to maximum make,adjust the VOLUME on the audio media,turn it up,should burn 2!
Post by Guest » Fri Dec 05, 2008 15:15
brightness at maximum, the volume of the audio media to the maximum
light is just right :([/b]
Post by Dimas » Fri Dec 05, 2008 15:17
Hmm,strange,everything is fine costacabana?If anything,you will change!
Post by Guest » Fri Dec 05, 2008 15:23
I am far away from Minsk to go :cry:
Post by Dimas » Fri Dec 05, 2008 15:33
Anonymous wrote:I am far away from Minsk to go :cry:
Can you send!
Post by Guest » Fri Dec 05, 2008 15:45
Glasses or Inner Pulse?
Post by Dimas » Fri Dec 05, 2008 16:09
Anonymous wrote:Dimas
All together,identifying the problem.
Post by Guest » Thu Dec 11, 2008 16:36
Convey with friends. Headphones didn't.
44
Post by 44 » Mon Dec 29, 2008 12:32
So still ,anybody can clearly and in steps explain how to listen audiostrobe drives with points ?
Connect sound from a computer on MM , bespectacled quiet and not in the FAQ ,not in the book is not written step-by-step instructions ...
Post by Dimas » Mon Dec 29, 2008 14:04
44
You need to put the device in mode of the decoder and click knupku PLAY!
Давид
Post by Давид » Mon Jan 12, 2009 16:58
People tell me someone, where can I get mind the car in Kharkiv? Because looking for a very long time and can't find!
Of course I would like to buy the Nova Pro 100.
I would be grateful! bc
Владимир Никонов 2
Post by Владимир Никонов 2 » Mon Jan 12, 2009 20:25
David, please order through the website, will be delivered by courier in 3-5 days.
САДОвник
Post by САДОвник » Mon Jan 19, 2009 18:30
Good day! About 10 months ago I bought mindmachine and strobe disc pack. So much time already and I use this good. From the very beginning was well-read that there is a images the brain generates, one horses run one of the trees, the kaleidoscopic images. Personally, I these effects are seen only on the cover disc :) And conventional flashing as it is. Neither change colors nor the formation of any images. But recently I started to fall asleep lying on your back and found that after short-term falling to sleep during a few minutes after waking up so ash and is full of the brightest and very clear colorful images and concrete pictures. Then puts, and again, a simple blink. But my mom and girls this is the first time since the first minute threw. Why am I so deep? I like to fix and in General, what is the reason(if there is certainly a particular explanation). Was still observed, but not as bright when I tried immediately after one of Sosvet Andrew to include audiostrobe disk. Then I saw it for the first time. But the experiment was not repeated because the theta drives are not particularly cling to as I the intermediate state at the time didn't worked at all(the Schumann resonance is meant).
Идущая вперед
Post by Идущая вперед » Tue Jan 20, 2009 12:13
yesterday listened to the disc about whales.... such a nice drive.... listening to whales - and to imagine how huge gigantic animals roam the expanses of the ocean
АндрейЛ
Do I have to listen AudioStrobe through headphones?
Post by АндрейЛ » Sat Jan 24, 2009 14:37
The question arose: in the "comments" to the AuS-disks says that the music "three-dimensional". It's good, but if they listen through MM, i.e., through headphones, what kind of three-dimensionality can be a speech? Or you just have to watch videopulse, and let the sound goes through the speakers (eg. 5.1)?
Re: do I Have to listen AudioStrobe through headphones?
Post by Guest » Sat Jan 24, 2009 23:11
АндрейЛ wrote:a question: in the "comments" to the AuS-disks says that the music "three-dimensional". It's good, but if they listen through MM, i.e., through headphones, what kind of three-dimensionality can be a speech? Or you just have to watch videopulse, and let the sound goes through the speakers (eg. 5.1)?
For example, in the headphones Ultrason. :)
