Novice Navigator
Re: Novice Navigator
Post by ЗОМБИ » Sat May 12, 2012 20:38
ahh, well, then the flag in your hands... don't forget to share if will convert :wink:
Авессалон
Post by Авессалон » Wed May 16, 2012 14:21
Is it possible one day to combine programs for relaxation and theta frequencies? Which program has more theta rhythms?
Thank you!
Post by Воффка » Thu May 17, 2012 7:55
Andrei Patrushev
Hello, Andrey! Tell me, audiostrobe "chords" optimal in all cases or in some better "General" use? And why?
Post by Андрей Патрушев » Thu May 17, 2012 9:06
Avessalom
Program with theta frequencies are programs for relaxation.
Post by Андрей Патрушев » Thu May 17, 2012 9:10
Voffka
Audiostrobe "chords" is designed for diversity and gives a slightly different result than the base.
Post by Воффка » Thu May 17, 2012 13:21
Andrei Patrushev
Which mode is recommended when working with the conductor and endorphins? And it makes sense not professional (well, that is me :) ) to explain why the result is different?
Post by Андрей Патрушев » Thu May 17, 2012 15:14
Voffka
Mode can be any set, and when tired another. :)
Воффка wrote:what is the result is different?
Feelings and conditions - as always, everything is very individual... :?
Post by Воффка » Mon May 21, 2012 22:06
I can not create a session in the editor for the Navigator :( Act I:
open the session editor for innerpulse and by analogy trying to create it in the editor for the Navigator, but to have a bunch of obscure values and strings, i.e. the values and strings in the editor to innerpulse, the editor for the Navigator, or are called differently, or all differently arranged and it is not clear what to do. Particularly interested in session P06. Maybe there's some tutorial?
Post by Воффка » Mon May 21, 2012 22:13
Here's what else came up, maybe someone who can do a session which is called innerpulse R06 for the Navigator? And there's similar already it will be clearer :)
If anyone knows this would agree shouldn't be charged :)
I suspect that using Navigator, the effectiveness of the session you can increase, or create different sessions? :)
Пит
Post by Пит » Mon May 28, 2012 18:27
Tell me , please, when you purchase audiostrobe disks is it possible to copy to the SD card in the Navigator, or they are copy-protected and require listening only through an external source bc
Post by к-13 » Mon May 28, 2012 20:13
Use uncompressed wav for the Navigator is enough.
Post by Воффка » Wed Jun 20, 2012 0:14
Really want to create a session for the Navigator (and more specifically to copy some Nova with about one hundred and session of Andrey Patrushev). Just tried the example session r04n open in the editor to innerpulse be copied to the Navigator, not nifiga, it's all very different. Is there any manual on how the editor for the Navigator to do this? If there is someone to file a petition to explain?
Post by Андрей Патрушев » Wed Jun 20, 2012 0:27
Voffka
Session for Navigator free, as for the Nova Pro 100. Most of the sessions of the Navigator is a session of the Nova Pro 100. :)
Post by Воффка » Wed Jun 20, 2012 15:03
Andrei Patrushev
Your alpha sessions there, and the effect of them I really liked... and not an example session P06 from which I received the faucet interesting effect. I'm ready for it all to pile, but to understand it can't you will need someone to explain the meaning of each field.
Post by Андрей Патрушев » Wed Jun 20, 2012 19:49
Voffka
Well, why not? There is something. :)
I will try soon to make the R06 and the rest of your session for navigation.
Энди
Post by Энди » Sun Jul 01, 2012 22:37
Lord let lamerskie a question! When starting in Pathfinder, for example the gate program journey through the inner worlds that MM plays only the first track and the second is not automatically transferred, you need to leave the state obtained as a result of listening to and manually turn on the following track. The same applies to the mode svetanics. I like to listen to meditation mode svetanics, but if meditation consists of several tracks can sometimes be the embarrassment. Settings searched I found nothing. Tell me what to do? Another annoying performance auto power off - sometimes will fall asleep and Wake up blinking led is already late at night, I would shut down and turned off why these unwanted reminders.
Post by Андрей Патрушев » Sun Jul 01, 2012 22:43
Andy
All files within the folder are played in turn it is necessary to press key F first, then fairly quickly press PLAY.
Post by Воффка » Thu Jul 05, 2012 14:51
Andrei Patrushev
Any news on the session which vibrators? :oops:
1Андрей1
Post by 1Андрей1 » Thu Jul 05, 2012 20:32
And along with the new firmware, which sort of promised back in may bc
Алексей Крячко__
Post by Алексей Крячко__ » Fri Jul 06, 2012 12:15
The new firmware is called 1.14 M, essentially the same as the 1.14 which was fixed some minor bugs and fixed the volume of your player to strobe mode-decoder that a user inadvertently could set the level lower than the threshold. Firmware 1.14 M stitched in all the devices sold since may of this year.
Post by к-13 » Fri Jul 06, 2012 13:50
Андрей Патрушев wrote:To all the files in the folder are played in turn need to press the F key first, then fairly quickly press PLAY.
And it is possible more in detail about these chips? There's probably other shortcuts.
Post by Андрей Патрушев » Fri Jul 06, 2012 16:48
K-13
Yes, because all written instructions, including this "trick". :)
Post by к-13 » Fri Jul 06, 2012 22:59
I only read the first, there, in my opinion, this was not :oops:
Кукловод
Post by Кукловод » Mon Dec 03, 2012 15:58
Hello, dear audience. I want to dot the "And" on the issue of compliance seesi and most suitable types of signals. I certainly understand that it's all individual, but still, it seems to me that the advice "experienced" would be very useful, especially when considering the Department for beginners. In this connection, will list below all the possible day of the session to the firmware 15M2, in front of which, please put the letter of the most appropriate signal. Thanks in advance, hopefully it will not be easy.
I. Recreation and entertainment:
Violet -
II. Relaxation:
R01N -
R02N -
R03N -
R04N -
R05N -
Evening -
Nndrfne -
SMR -
III. Training:
L01N -
L03N -
MABS -
IV. Visualization:
С01N -
C02N -
C03N -
C04N -
C06N -
V. Meditation:
D01N -
D04N -
D06N -
VI. Energy:
E01N -
E02N -
M_Awake -
morning -
VII. Sleep:
S01N -
S02N -
S03N -
VIII. Special:
OPN01 -
OPN02 -
OPN03 -
P01N -
P02N -
P03N -
P04N -
P05N -
P06N -
P07N -
P08N -
EMRD -
OC1 -
Hlng -
MHlng -
I think many will thank You.
Also please clarify what OS (generation t) and what is the upper full and lower spectra, which can do aerobics? Also thanks in advance.
Post by Воффка » Mon Dec 03, 2012 17:32
Here we can say that the sine and assymetry. sinus good before bed and then in cases where other forms of signal trouble falling asleep and then not always.
Кукловод wrote:I certainly understand that it's all individual
So individually, each for HIMSELF selects the most appropriate form of signal is not something that would even for a particular session and for a specific use, even one and the same session :? And remember that a lot depends on the environment and their own expectations of the user. In General recommendations concerning the form of the signal given in the instructions and more accurate descriptions to be vryat maybe because You yourself said:
Кукловод wrote:...what is it all individually
. Reviews about the different forms of signals can read on the forum.
Andrei Patrushev recommended to use all waveforms at the queue in random order.
Кукловод wrote:Also please clarify what OS (generation operating system)
The abbreviation for lucid dream generation - session fosters a lucid dream.
Кукловод wrote: and what is the upper full and lower spectra, which can do aerobics?
The upper frequency range of alpha, beta, lower alpha-theta, respectively, theta-full-beta. "Aerobics" you can do energetic change frequencies back and forth. :)
