Suggestions for improving.
1.Hmm, what could be simpler...Ростислав wrote:1.The only not so convenient menu, a lot has to do transitions on the menu! Maybe you can somehow simplify?
2.Too tight of a button
3.Don't like beeping buttons(how to disable?)
2. Despite its size, it is necessary to press exactly in the middle, then there is no feeling of tagaste.
3. In my first machine the buttons are not food (I don't like), but then Andrew and Alex decided that it's better...
Алексей Крячко__
Re: Suggestions for improving.
I beg you to make a new firmware which has the ability to disable the sound when pressing the keypad on the Navigator.
Only today wanted to show how I use the Navigator and all on a single charge. But broken off. Last time forgot to pull out the headphones and glasses from the device, all in a heap, put in a bag. As I remember, the charging indicator did not burn only one box, it was yesterday. Today, the Navigator shows no signs of life. Hooked it up through the power supply, 5 min was messing with the power button. Finally, he started beeping, one beep per second or half a second. The screen glowed dimly with a blue light. If not for a nasty squeak, would have left Navigator to charge. But the squeak got, and I doubted that he was involved in charging batteries. There he wrote, read is not possible, the background is pale, the letters dim. Pressing any keys what is on the screen does not change. Had to pull the batteries and put them on an external recharging.
Got two questions.
1. Can I leave my sunglasses and headphones in Navigator, if it is switched off? Hardly I left it on pause, I can always turn off if not using.
You can make the function of auto power off completely, if the track is ended to prevent the device from full charge battery?
2. In what menu the user gets when you enable a network device with a fully discharged accumulator? In my case it was just bismal and it was not clear, it is possible in this view to keep charging the batteries and what happened to him.
Got two questions.
I, too, for auto! I think 10 minutes without movement is enough to disconnect!
In such case it (the display) is probably 15 is enabled (if enable is off, that is not food, NAVIGATOR), but for full charge, you need to run this process settings in the menu section, to sunbathing "red lamp". When extinguished the lamp, when plugged in the device and the display - mode of the maintenance, but not charging. Self-attenuation of the lamp signals the end to complete the battery charge.Ланцелот wrote:2. In what menu the user gets when you enable a network device with a fully discharged accumulator? In my case it was just bismal and it was not clear, it is possible in this view to keep charging the batteries and what happened to him.
Full charge I have 15-20 runs 45-65 minute drives with points on big volume, after work turn off the headphones and glasses - disconnect.
Sincerely, MAG.no
- Владимир Никонов 2
Important: to add brightness to the sessions. It doesn't penetrate through the eyelids in some sessions.
Алексей Крячко__
Good afternoon, all users.
Apologies for the silence - I was on vacation and with communication difficulties.
Now we will continue working on improving the software of the device.
Yes Yes looking forward to it!!!
Re: Navigator. Experience.
Today turned on the GPS, the battery indicator shows 8. Include adustable session spontaneously stops, the charge indicator shows 0. In a second, again 8. Built-in session Navigator loses.
Алексей Крячко__
It is a sign of a dead battery. Audioscrobbler consumes two times greater than the play mode sessions. Interruption of sessions or audio programs when it detects low battery made specifically to prevent any possible failures and unpleasant sounds.Логик wrote:Today turned on the GPS, the battery indicator shows 8. Include adustable session spontaneously stops, the charge indicator shows 0. In a second, again 8. Built-in session Navigator loses.
The charge indicator shows the relative level of battery voltage. NiMn keep the voltage up to full charge, under load it quickly drops from a dying battery, and then quickly restored (if the batteries are new and working properly). In old batteries or NiCd discharge is accompanied by more uniform voltage.
The batteries that stood for more than 5 years...Алексей Крячко__ wrote: charge Indicator shows the relative voltage level at the battery. NiMn keep the voltage up to full charge, under load it quickly drops from a dying battery, and then quickly restored (if the batteries are new and working properly).
It turns out, the charge level indication is a total bullshit response on her watch even if the full level 9 and 8 are already almost exhausted.
Batteries from the kit Navigator put it on the charger in the external charger - charge in 2 hours instead of 4. It turns out that they discharged was only half full and Navigator is not working.
You don't have too much fear of failure, because of lack of battery power?
The batteries charge even without including charging in Pathfinder on the charge control no! Probably just in proshiva on a timer or something.
In this school, the charge controller is not in gland.
There is an option to switch if possible for lithium-ion lithium-polymer batteries(firm Nokia)! Problems would be I think less!
Logik
Just don't use such old batteries.They behave in all devices after several years of operation, while indicating a full charge, the phone switches off after the first call, a laptop after a few minutes of work.At the auto Moto have the same situation, the battery loses its capacity, but shows normal charge when charging. Such rechargeable batteries in the garbage
Use batteries from the kit.
I have the batteries from the kit with the NAVIGATOR sometimes behave...
And not just in PATHFINDER, but in phones, laptops, iPods, hours, and generally "dumb" appliances, the type of shaving machine with vibro, etc, the impression (based on observation) that I their full potential take away "the right moment" in some States, interestingly enough a couple of days and the battery or the battery is like new, continue to use as if the discharge was not, I have this assumption may at forms the opportunity?
Sincerely, MAG.no
Sincerely, MAG.no
Use those from the kit. There's the same story, only values 7-6.Андрей Кабанков wrote:Use batteries from the kit.
In case you described is known to me, but obviously not suitable for this situation.Андрей Кабанков wrote: Such rechargeable batteries in the garbage
By the time the work in the Navigator, about the same both sets. It turns out I have to change the batteries, because the device has no plausible indication of the charge level?
It was not in previous firmware...
I think that in an upcoming firmware update should change the bar depending on the battery without changing the operating range.
It would be great and then collapse impressively the CD Tamas Lab. on 47 minutes, the Navigator shows the charge 9 at startup, and it's in the middle of listening is disabled because the batteries are dead... complete Bummer, for a second time to listen don't lie - simply an external player to plug in and do the old machine to use... Why 10 steps to use, if in fact there is 2 - 9(loaded) - and the rest of 8-0(empty)... And so it would be easier - if, for example, less than 3 on the indicator, then less than an hour to listen to, and 9 is just loaded...Андрей Кабанков wrote:I Think that in an upcoming firmware update should change the bar depending on the battery without changing the operating range.
I think it's better to do 4 graduation instead of the current scale with 10 gradations - the full charge,three cetveli,half and a quarter, and specify estimated time of work with standard batteries mode session, and player for these levels of charge.
It would be even better - it is almost all users of mobile phones are already used)))
Even these batteries have memory effect if not fully discharged then modern capacity decreases even new! For this it is best to drain through and recharge the charger.
