Planned changes in the commodity row of the entire line BJ-SK, etc.
Has thanked: 24 times
Been thanked: 142 times
Re: proposed changes in trademark row the entire line BJ-SK
Post by Маг.нет » Thu Oct 27, 2011 23:50
:) Thank you!
Sincerely, MAG.no
Natalyy
Post by Natalyy » Sun Oct 30, 2011 13:27
And how much will the programmer, or rather, with what amount will start its cost? But I kind of also expect, though more to save and have a two-in-one programmer for panacea and СК1М :) (and it may not be worth it to wait and buy СК1М ?)
АКВО
Post by АКВО » Sun Oct 30, 2011 13:36
СК1М always useful :)
Natalyy
Post by Natalyy » Mon Oct 31, 2011 16:35
AKVOso I have no doubt about it :) Just not yet I have the opportunity to buy both.
АКВО
Post by АКВО » Mon Oct 31, 2011 16:47
In my opinion, better start UK, while it is cheap, and the programmer will not run away.(especially СК1М almost an eternal thing):)
I did, no regrets.
Post by Маг.нет » Mon Oct 31, 2011 16:50
IC 1M after the release of the programmer is much more expensive, the Programmer can not 100% cover all quality SK 1M, yet the approach is a little different. The programmer will cost a bit more than SK 1M in the basic version, but Michael_ has already announced about parallel output and more advanced (from the point of view of "iron") equipment, which will be slightly more expensive.
From an economic point of view at the moment is cheaper to buy SK 1M, and the Programmer later on opportunities.
Sincerely, MAG.no
Post by Михаил_ » Mon Oct 31, 2011 22:40
the cost of the most simple version of programmer will probably 17000.
СК1М as it comes out really expensive.
The programmer, unlike the UK can not work around the clock offline if not connected to the computer. In General, to say that it is better and easier - hard. For someone, the programmer can be more convenient (additional f-tsii at almost the same cost). But for many more standalone device СК1М will be interesting. IN the UK is expected to double (apparently) higher prices. And SKVC console.
Post by Михаил_ » Tue Nov 01, 2011 0:26
Two news :) as always, good and bad. Joke.
Products the new series apparently will go to the office on Tuesday and Wednesday. This is "bad".
But we are very pleased with the broad test of the hologram the panacea in applications, which had not quite planned. That apparently will allow you to quickly have a couple of new products useful for the people.
Announcement.
Unplanned innovations.
Комплект наклеек «Панацея-Дом»
Set "cure-House". Consists of 50 holographic stickers Panacea. In addition to the basic program and the ability to switch modes (a friend of mine looking at how it works, said once - "let's switch 2.9 - will be quieter") on the holograms of the system caused the program a "harmonious house". The task of the whole system is to create a favorable atmosphere inside a certain space.
Recommendations for use: one sticker on each window sash into the top corner (left or right - does not matter). Under one sticker in the corner of the large mirrors in your home (the angle is not important, the point of attachment - from use, not from the back side, i.e. not, as in the case of the "mirror of ISIS").
One sticker on the front door. One sticker on the wall of the room opposite the window.
The remaining can be mounted on the water pipe or any other places according to their own feelings, including the bed.
Overall, according to our calculations, a set of 50 pieces, enough for 2-4 bedroom apartment or small office.
The cost of the kit 30t.
This kit does not conflict with the products of the "front room window" and implementing a different function.
In "processed" in this way spaces it creates a special internal atmosphere in General we can say that this treatment is something similar to EP2, in the minimal version of activity without an external source of energy.
However, in this case as such, "active" shielding no, although indirectly, due to the dominance potential of energoactivity space over external space of interaction clearly vary. You can say that people living in this area tend to be.... more successful.
At home we spend a lot of time to attend to their homes.
... Yes, it's significantly more powerful than the charging light matrix.
I would also recommend a couple of stickers to leave in the car (including the windshield and rear view mirror). Program there fit the same? to create a space with the qualities of lowering external influence on the driver (and the car). Again, Economou are completely different things created for different purposes, not a hindrance, can help (the operator is in a higher energy density state).
Set "Cure House" is also perfectly suitable for the office, or may be divided between several rooms used by a single operator. In the basic mode, the operation of the "home" (or just "harmonic space"), combined with a basic regime of a panacea. Because the programmability option of holographic labels increased, the switching from the basic mode panacea 2.9 maintaining the operation of the program "house" is easy to carry out mentally, even for a beginner. It can also be implemented by applying a switching matrix.
On the power of this product is slightly inferior to ISB-3 and creates zones with high energy saturation near the place of gluing. The highest efficiency on glass and mirrors. Gradually, all the space between the several labels will be harmonized. The time of full activation of the system should not exceed 7 days after application to the object. Some initial discussion is on my forum, I accidentally hit the branch of a stabilizer (there are quotes given according to first reviews).<
АКВО
Post by АКВО » Tue Nov 01, 2011 0:38
the piece is not planning to sell? :)) 5-10...
Post by bofara » Tue Nov 01, 2011 1:15
Oh, that's very good news! :) Hopefully, there will be a about new products I think will be a great demand! IMHO!
Post by Михаил_ » Tue Nov 01, 2011 1:35
In smaller quantities we sell unshaped stickers and charger disposable. System house just 50 or more. We have a good reason. This is not a mandatory component, though very good :)
( http://openmagic.org/ph/showpost.php?p= ... tcount=476 ) No, of course you need to understand that the user who left these reviews it is as though the professional user. But today for example I received feedback from my colleagues, or rather from his not sensetive parents (he apartment was treated so 4 rooms). They say that a little better and brighter-fresher was inside.
More in General, I have positioned this product as advanced for regular users. And I understand that the cost of labels is not high, although there is still the action of their firmware program. But we do not just want charity to distribute them, and to improve technology. And while useful equipment unfortunately is very decent. So it is this form of investment in the knowledge-based part. With less gradation of people will take a minimum, psychology (for example at the moment for a complete "happiness" in terms of technology development we need three pieces of iron worth 1.5 3.0 1.5 million rubles, which is significantly higher than the profit from the sale of goods)
Good news. Stickers without the program house, which will be sold in smaller portions also work.... not much worse, just the impact would be less complex. So the intermediate option is still there.
Post by bofara » Tue Nov 01, 2011 1:37
:ay Success of new products!
Post by Михаил_ » Tue Nov 01, 2011 2:12
Set the Panacea-stick. 10 stickers for their own programming.Contains software that simplifies programming your own algorithms and ideas, copy information from various sources and so on. Complete "flash drive" dull work is actually BJ is a panacea, i.e. if no program, then these stickers will behave close to a simple adhesive piece of paper. All their strength is in the ability very easily be programmed and is extremely resistant to keep the algorithm work. Recorded on the algorithm "stick" to simplify the creation of their own mental systems.
Price 5T. p.
Stickers "Panacea" without applied programs. 3000r 5shtuk. Can be used actually as a product Panacea for charging (as charging system), for pasting on objects, and glass, to enhance BJ panacea or pendants panacea for programming (programming available to anyone without a flash-drive) and for any other purposes.
Planned kits.
The system transfer.
2.0 1000R
2.1 2000P
2.5 10000r
2.6 10000r
2.7 12000r
2.8 12000r
Panacea 6000r
System transfer, unlike stickers, the panacea, is a laminated color printout, which caused the hologram sticker panacea and own info-system, then the whole "Cake" treated additional laser charging system.
The transfer system previously described, more details on its use will write later in the profile subject. It allows you to change the subject-the carrier of the qualities of the BZ, at its discretion, quickly and conveniently. With careful handling the plastic is durable and will last You a long time.
Post by Михаил_ » Tue Nov 01, 2011 2:20
System "1копия".
2.0 800R
2.1 1500R
System 1 consists of 1 copy of a single label with ACC. program, when applied to the subject, in 2 days made on it BJ the correct version, the label can be left or safely throw away (it worked out). The subject of the later charge is not lost, as in the industrial source exchange for another item is not possible. Benefits - cheaper, decide charge form factor. For our printing system 1 copy of the much simpler fabrication of the system transfer for You, if you do not change the primary carrier (e.g. a clock) is easy, cheap and convenient.
Planned increase in prices on 2.5, 2.6, 2.7, 2.8 will be implemented from 1 December. Accurate new prices will be announced later.
At the same time increase the value BJ Panacea black tree, up to 10 000 and, accordingly wide BJ panacea black tree, up to 12 Tr
Post by Михаил_ » Tue Nov 01, 2011 2:22
Higher prices for СК1м and HF console to the UK is likely to happen also from 1 December, if in November we will send the programmers to a Panacea.
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Tue Nov 01, 2011 11:06
Michael_
If the system transfer to transfer for example 10 bracelets BJ 2.0 one, then it will work in a ten-fold power? A similar question on the other versions.
System copy it's just a sticker to charge any object? Obligatory 2.0 or 2.1, a copy of the charge to another object?
Post by Михаил_ » Tue Nov 01, 2011 12:37
1. About increase capacity - not sure. Will check, will report.... And ideologically in the presence of 10pcs 2.7 would be better if they post 10 times clothing items for example. :)
The problem is that to push the subject above it the weight and size of the borders is quite difficult (well, so it is not destroyed more quickly). But you have to look. I will unsubscribe a bit later.
2. system "1копия" simply records the subject 1 time, ie, the original object is not necessary, it is the system itself. It makes for 1 copy of the product (can't do 10, or if you try, then it will smear result), and then not working.
Post by Воффка » Tue Nov 01, 2011 13:26
Михаил_ wrote: 2. system "1копия" simply records the subject 1 time, ie, the original object is not necessary, it is the system itself. It makes for 1 copy of the product (can't do 10, or if you try, then it will smear result), and then not working.
The size of the charged object somehow limited? If you stick to something large, properties will not weaken? For example on some huge boulder :)
Natalyy
Post by Natalyy » Tue Nov 01, 2011 13:33
Михаил_ wrote:Sticker "Panacea" without applied programs. 3000r 5shtuk. Can be used actually as a product Panacea for charging (as charging system), for pasting on objects, and glass, to enhance BJ panacea or pendants panacea for programming (programming available to anyone without a flash-drive) and for any other purposes.
I'm not quite sure if to use these stickers as the product is a Panacea - simply enough to carry?
Charging - it will charge the bracelet and it will be BJ a Panacea?
How they can increase BJ a panacea: if you take the normal wood, we get on the power as ebony?
And I wonder about the charging of 2.1. Power work like a regular wood (if the media is too wooden bracelet or watch)? Or somewhere between normal and black tree?
Post by Воффка » Tue Nov 01, 2011 13:37
Michael_
1.How much time will it take to migrate and how this will be practically implemented?
2.As I understand the card is not great and it charges item must fit completely?
3.For the period involving the system transfer, the original become just a regular "stick" or any property still retains?
4.How to zadeistvovat transfer back to the original product?
5.What will become of the original if the object to which the transfer will be destroyed, for example burnt?
Post by Михаил_ » Tue Nov 01, 2011 13:45
Воффка wrote:Michael_How much time will it take to migrate and how this will be practically implemented? ?
on top put. From one hour to 2 days, but the degree of transfer efficiency reaches a plateau after 15 minutes. I.e. "quick" stop for 15 minutes. Qualitatively 1-2 hours. Socks lasting for 1-2 days.
Practically laid on top and all.
The card is A5 (half a standard A4 sheet. Not the small ones. It is possible to fit partially (clothes), but it is better completely.
Some will remain. Overall card here, as it merges with the object to which the.
How to zadeistvovat transfer back to the original product? What will become of the original if the object to which the transfer will be destroyed, for example burnt?
The reverse process - either transfer to a new subject, or for 15 minutes to put on the back of the card.
If the object is destroyed, it will remain connected to what's left of it (well, in this case, the smoke and ash), but degraded. The connection breaks when you transfer to a new object entirely.
Ie this is not a problem.
Post by Воффка » Tue Nov 01, 2011 13:46
Allowed to buy transport in a purse and use one system transfer to a variety of bracelets, for example 2.6?
What if you stand at the card itself, put a cat or any other living facility? :) :wiz
Post by Михаил_ » Tue Nov 01, 2011 14:02
Воффка wrote:allowed to buy the shift in the purse and use one system transfer to a variety of bracelets, for example 2.6?
No, of course You can :) but zakolbasilo wearing not childish :) 1 system = 1 bracelet. Now if you really divided like normal 2.6 for two and that's two 2.6 in the weaker half (well, if the link to replace 50% of normal), in this case it will be ONE 2.6 and the subconscious of the operators, plus energy - all this will be somewhat confusing. Well, as if to give someone a BJ, we are still working short time personal settings. In addition to share power. In short, chaos is still the same. So what to do is possible, but not necessary.
"And these berries are edible? You can, you can... but only once."
Post by Воффка » Tue Nov 01, 2011 14:32
Clear :)
What if the card living object be placed?
Post by Воффка » Tue Nov 01, 2011 14:35
That the transfer will act as a damper(physically)? Simply put, it happened that the bracelets were cracked, the gum was torn, that the transfer will take the blows? Card, original or what suffered?
