The development of the mind of the machine Navigator.
Timer... he can turn on the desired session or a track to me at the right time, for example during sleep, with the audio broadcast on the audio pillow?
And the cozies under Navigator is not yet available? Conveniently bylob with elastic type wristband to be worn on hand (e.g. while Jogging) and the possibility of hanging on the neck, pockets will be more whole.
Sincerely, MAG.no
Sincerely, MAG.no
The main difference from other mind machines is the ability to sound and light about them, Andrew wrote in a presentation that allows the use of new technologies to create more efficient sessions.It's not an improved model of mind machines available on the market,and the new generation device that allows you to create a more effective session.
Маг.нет wrote:Timer... he can turn on the desired session or a track to me at the right time, for example during sleep, with the audio broadcast on the audio pillow?
Sincerely, MAG.no
The size of the device is not so small that you could carry it in the little pouch on the wrist or around the neckАндрей Патрушев wrote:- TIMER. Is provided to be triggered only once after a specified time, or cyclical, through the interval. When the timer has elapsed an alarm sounds from the built-in speaker and signal led is blinking, the timer can run in the background, including when you play sessions or audio files. There is a separate two modes of the timer: to start the session after a certain time, or to play an audio file. Session names and audiphile be selected during the timer setting.
Thus, the timer can be used as a motivator, the signaller of the need to take medicine to practice lucid dreaming, self hypnosis for sleep.
and what is the main difference in light and sound from the "classical" binaural beats and light flashes?Андрей Кабанков wrote:the Main difference from other mind machines is the ability to sound and light about them, Andrew wrote in a presentation that allows the use of new technologies to create more efficient sessions.It's not an improved model of mind machines available on the market,and the new generation device that allows you to create a more effective session.
Hello!
The machine offers the possibility to use a timer to turn it on during sleep, after sleep.
It would be nice if this machine would be separately sunglasses and headphones, with constructive comfortable for sleeping. For example a fully closed points (so as not to disturb anyone) on elastic band instead of arms (by type of swimming goggles), to ensure that the ears are not pressed and not slipped during sleep, if on the flank turned. Also, headphones to really sleep comfortably. To nothing never pressed and did not interfere. Is darling, too elastic to provide. The ears themselves are soft and flat.
Such a separate set of sleep with the machine.
It may be bare, but not soon (there are still a lot of other problemsЭкко wrote:Andrei Patrushev
and if you add BOS? and I understand the device will not be compatible with the files *.lss?
No session of photosonics directly upload will fail. It may be done by the software or in editor sessions, but until the funding of this idea is not provided...
Hello.Ашот wrote:It would be nice if this machine would be separately sunglasses and headphones, with constructive comfortable for sleeping. For example a fully closed points (so as not to disturb anyone) on elastic band instead of arms (by type of swimming goggles), to ensure that the ears are not pressed and not slipped during sleep, if on the flank turned.
Much sense with glasses and headphones for sleeping there. Glasses can be mounted over the bed (or the side), and for the sound to ispolzovatj special pillow (you to make). And the rest of Grimstalker out of the competition, IMHO.
Still have question on installation color.
It is possible to set the color so that it has changed in the course of the session, in a specified order?
For example, in the beginning of the session - red, then orange, then yellow, etc...
And whether or not frequency of exposure.
That is, different colors in the course of the session, ustanavlivatsya user manual and does not change depending on the frequency.
I think it would be interesting for the diversity of sound and light experience. Napremer in the alpha session "view show" from all colors of the rainbow, with variations..
Ashot
Yes, the presentation it is written.
Only diabetes have specific three colors: red, green, blue. All other colors can be obtained through a combination of the colors in the rows and filling period (incidentally, it should be remembered that the filling period, the pacing rate will double...). On the other hand, color in the blink of an eye, more dependent on the stimulation frequency and duty cycle than from the color of SD.
Last edited by Андрей Патрушев on Sat Jun 18, 2011 10:47, edited 2 times in total.
And if you have a recorder, it would be possible in the future to provide the possibility to overlay different effects on the recorded sobstvennym voice affirmations (such as echo, chorus) to minimally interact with the computer and promptly prepare affirmations relevant at the moment, only through machines.
It would be possible to include more samples into the machine -different nature sounds, Tibetan bowls, bells, different ambient. as it is implemented in the audio processor Nature Now Therapy.
The user could mix stimulation with the set of sounds of nature and ambient, which it is pleasant at the moment and is appropriate for this session.
In my opinion you should not try to embrace obyatnym not to shove and not pihuamo...Ашот wrote:And if there is a recorder, it would be possible in the future to provide the possibility to overlay different effects on the recorded sobstvennym voice affirmations (such as echo, chorus) to minimally interact with the computer and promptly prepare affirmations relevant at the moment, only through machines.
- Шалтай Балтай
In my opinion, the build quality and appearance is much better than the old models photosonics, and that still pleases me as audiophile, so the sound in this device...Тоха wrote:the build Quality hopefully will be better than fotonica? And the power connector I have in place. Had to be perverted with him
