SP. from Tweety with pump
- Дунька с водокачки
- Been thanked: 1 time
and
review: the thermometer 40 degrees. all the Windows and doors wide open,and I sit here all cool.
in fact for me, nee Siberian from Transbaikalia is ubijstvenno tepmerature. in such weather without air conditioning heart hurts, not enough air and nervousness happen. and here I sit - from the Windows blowing in the hot wind and nothing to me. inside is a pleasant refreshing coolness and no not for the price nadot.
on the device are my sobsno hair and affirmation(written)
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
naroda!!!
I understand that clog up the thread, but the first impressions from my go and the rod from me.
soon poprivyknut and leave you alone. and right now, should be mine to share, and besides you no one, all the others wagged his finger at his temple.
in General another review:
affirmation on the business on a particular transaction, rather than on a specific person worked.in recent days, the deal seemed dead, but I, knowing the properties of this apparatus, wrote the same affirmation.
and now calling the most "specific", and says that he wants to work with. and we thought that he had changed his mind or found another option.
reading the thread, I got the affirmation from the situation is not worth it, so I did to start for the object.and all the time I was sure that everything it is exactly what happened (as he wrote Merkaba).
- Шалтай Балтай
then somehow Sergey Gurin complained that his affirmations are not working and someone, can't remember who, advised him first affirmations to do for the situation and personal qualities, so I thought, nacatamal quantum physics that a particular person and personal qualities,in principle, the same.Шалтай Балтай wrote:Oh, it's like this?Дунька с водокачки wrote:what to do affirmation from the situation is not worth it, so I did to start for the object.
- Шалтай Балтай
- Шалтай Балтай
Humpty Baltay
but to pump so galleries?
"Insert the plug of the power supply into the power socket (power) on the device, then plug the power supply into a wall outlet. Turn on the device. For most devices the power supply should give 9 volts and a current of 100 milliamps."
if Yes, then - hooked up - then what?
well, I read to the end, then if it again asks...
and so here is my affirmation worked for us (all from the same manual):
"when you focus your attention on the person who is not present, that is, you see this person "inner vision", then you set another type of structural relations with this person! Surely you at least once in life experienced such an experience, when you only should've thought about someone almost immediately received a phone call. And who would it be? Of course, none other than the man that you just thought "Hey, that's funny, I was just thinking about you! ... "
You can mentally establish a structural link with a person, object, or situation; therefore, you can mentally direct the vital energy. Thus, whenever you are mentally or concentrate on something or on someone, you can stabilize the structural relationship with the object of his thoughts. In the old days the sages and religious leaders told their followers that they should see his thoughts, because, "where your mind is, there the energy flows!"."
This is likely to be interested in newcomers than procuring ergonom though....
1 isolate SP orgone from the environment ,leaving only the open crystal
2подаем through the MIND signal affermazioni , spells, etc.
get
1 you can listen to afirmatii etc directly without addiction and no Golovnaya and nausea caused by the overdose of orgone
2 before crystal poluchaem much more power in a narrow beam
3 be careful
_________________________
Afraid of their desires,and they will come true!
get
3 be careful
Re: SP. from Tweety with pump
Oh, so it's now a separate topic Stoll?
for sho I was separated from my people?
well, it is clear that blonde, but well I tried so hard... and you have me in quarantine...
- Шалтай Балтай
the topic has grown - you will not find anything
broke as I could
broke as I could
Oh yeah, sorry, I later saw.
nonche of tormozhu
nonche of tormozhu
