- Has thanked: 24 times
- Been thanked: 142 times
Post
by Маг.нет » Thu Mar 17, 2011 0:41
Stabilizer - useful thing
Sincerely, MAG.no
Денис87 - Posts:10
Post
by Денис87 » Mon Apr 04, 2011 15:13
and mandalas to print on a color printer or is there no difference?
Денис87
Post
by Маг.нет » Mon Apr 04, 2011 15:42
Маг.нет wrote:I thought "the best copy of" mandalas to charge - print on the laser color printer.
In the process of discussion has highlighted the efficiency of copiers for the printing of the Mandal (in descending order): professional photo printer - laser color printer - laser-monochrome printer - inkjet printer.
Sincerely, MAG.no
Антон И. - Posts:10
Post
by Антон И. » Mon May 23, 2011 13:24
MAG.no
maybe I'm a moron, but explain to me not understanding if do of 3.0 N 2.0, you need the first mandala or not?
Антон И.
Post
by Маг.нет » Mon May 23, 2011 13:26
Mandala 1 is needed in any case, she's part of the whole charging system, though with his individual function.
Sincerely, MAG.no
Алексc3000 - Posts:362
Post
by Алексc3000 » Thu Jun 02, 2011 17:40
Good day forum, I want to make a bracelet for charging 3.0 N, what to do with their pens and not buy in the store ready, parts will be cast from resin (backside or Politica), in each link you want to drink a few pebbles pre-charged by the same system, and after Assembly of the bracelet again to charge ready-made product, the question is this: what if all three mandalas to print on a single sheet of paper (like stop magic printing printed) in umerenom and all this stuff to pour the resin in each link of the bracelet as I will not spoil the product and what will happen????
Алексc3000
Михаил_ - Разработчик
- Been thanked: 906 times
Post
by Михаил_ » Thu Jun 02, 2011 18:42
spoil. And cast with the precharge nothing. The procedure is fully described and use it as described if you want to get 3.0 and not something else.
In other words, the charge ready-made bracelet.
Post
by Маг.нет » Thu Jun 02, 2011 19:29
Doing the same as the other, in the same conditions with the same tools you will get the same effect.
This condition of repetition of a scientific experiment. If you can spend some experience, then I can do the same. will get the same result if I follow exactly the instructions that you used if I use the same tools, have the same status, and the like. Normal mages don't have to guess, get them something or not. They just know, and therefore believe in what you're doing, in the same way as scientists know their stuff and believe in what you're doing. Is a made an experiment, a perfectly made device, is carried out the ritual - all this from one sandbox and it will work. No need to guess, will work or not, worked up to you will work after you will earn you. easiest process magical ritual compare with the ritual of cooking according to the recipe. The result is always predictable, simply do what you need.
Sincerely, MAG.no
Post
by Алексc3000 » Thu Jun 02, 2011 19:59
Understood, just a thought came up, resin it dries after a long time, even when it is dry and can be hold in hand, to complete polymerization takes place about three days and in that time, she can be anything they want to do it all information on record and very well, will write that down and wanted that window to use it.
To be honest it was the interesting answer to the question about mandalas (and ignored it), if I understand correctly this method (alternative) drawing mandalas laser on each link.
Алексc3000
Post
by Маг.нет » Thu Jun 02, 2011 21:44
Mandala you need to know exactly what to do and what happens, it's algorithms.
In the charging process "N" 1-3 stages can be compared with the input algorithms (non-activated) in the material stage 4 - serial activation algorithms inside the material to "shear" the material in the "as 3.0". Imbalances in this process can lead to a "curve" unpredictable result. But You to use it...
As for the drawing of the mandala with a laser, it seems to me there is not only simply "drawing", the beam is also likely modulated by the programs, but then Michael_ will be able to better explain.
Sincerely, MAG.no
АКВО - Posts:345
- Been thanked: 1 time
Post
by АКВО » Mon Jun 06, 2011 0:33
Good Evening!
3.0... N doing Everything in the instructions... but 3 times was hanging the computer from the audio file, I don't know if he lost completely at least once. What does this audio file when you record, that if without him or half of him?
АКВО on Mon Jan 19, 2015 16:43, edited 1 time in total.
АКВО
Post
by Маг.нет » Mon Jun 06, 2011 7:02
Good!
File important part of the charging system, it is desirable that he "scrolled" through "lockups".
To understand the stages 1-3 "introduction" of the material with the structures and trends in the points 1, 2, 3; stage 4 - structural "shear" through points 1-3. Failure of the 4th stage, the entire charging process (steps 1-4) is better to repeat again.
This description exaggerated, but close to fact...
I think in the presence of inaccuracies Michael_ will correct...
Sincerely, MAG.no
Post
by Михаил_ » Mon Jun 06, 2011 11:41
1.the hanging file is identical signalling the importance of the process for You.
2. no file can be 3.0 but not the version N and weakened, or, more precisely, less feature-rich. So better really to repeat everything.
Марина 68 - Posts:5
Post
by Марина 68 » Tue Jun 07, 2011 23:04
Please tell me whether I understood.Since the beginning of the subject to wrap the first mandala to withstand the specified time.Then wrap the second mandala again to withstand a specified time,then the same with the third mandala. Then wrap all three mandalas(in the sequence) and as well as in the manufacture of the 1st version together with headphones dipped in water?
Марина 68
Петрос
- Has thanked: 45 times
- Been thanked: 9 times
Post
by Петрос » Wed Jun 08, 2011 0:02
Marina 68
no, the water is good to drink (just kidding). this process without water
Петрос
Марина 68 - Posts:5
Post
by Марина 68 » Wed Jun 08, 2011 0:13
Petros thanks for the reply ,and all the rest right?Ie audio is only connected to the final stage where the subject is wrapped all three mandalas?
Марина 68
Post
by Маг.нет » Wed Jun 08, 2011 7:36
Yes, audio is included in the 4th stage of charging, while wrapping all 3 mandalas in the sequence shown.
Do this exercise "dry", though there is another caveat, in each stage after wrapping a mandala/mandalas parcel wrapped in foil.
Successful research!
Sincerely, MAG.no
P. S. it is Desirable that steps 1-3 were approximately equal time, 4th time is a multiple of the track multiple runs.
Марина 68 - Posts:5
Post
by Марина 68 » Wed Jun 08, 2011 22:07
MAG.no thank you very much,now everything is clear.
Марина 68
Post
by Маг.нет » Fri Jun 17, 2011 18:15
Маг.нет wrote:Stabilizer - useful thing
Sincerely, MAG.no
Thanks to the Distinguished Master of the TAO now have available a description in detail: ru/viewtopic.php?t=4084">самостоятельное_изготовление_Стабилизатора. Methods.Manufacturer.The results...
Thank you Master TAO!
Sincerely, MAG.no<
АКВО - Posts:345
Post
by АКВО » Sat Jul 02, 2011 11:17
Is there a difference between the creation 3.0 N 2.0(b/d) or 2.1(h/d)?
АКВО
Post
by Маг.нет » Sat Jul 02, 2011 11:24
Not at all. When charging 3.0 N structure is not adjusted, and 3.0-structure is "welded" over. It concerns only 3.0, this structure has a priority advantage.
Sincerely, MAG.no
АКВО - Posts:345
Post
by АКВО » Sat Jul 02, 2011 11:42
clear. Welcome!
АКВО
Мирра - Posts:2
Post
by Мирра » Sun Jul 17, 2011 16:13
Маг.нет wrote:Yes, audio is included in the 4th stage of charging, while wrapping all 3 mandalas in the sequence shown.
Sincerely, MAG.no
I would like to find out what the mandala first, what second and what third. Mandalas in PDF format and no numbering. In the file - the third mandala upside down. If you flip it (along with the file, it will be the first (and so on).
Which begs the question, this inverted mandala - there is a third or first (in the file)?
Мирра
Post
by Маг.нет » Sun Jul 17, 2011 16:30
1-2-3 in order of priority, in the pdf, Yes 3-I inverted mandala
(scanned upside down).
*In the fourth stage, the order of 2-3-1 wrap
Sincerely, MAG.no
