Stones for sale.
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
- Шалтай Балтай
Алексc3000
Re: Stones for sale.
Something
very confused, maybe dear Logik explain to time with the stones bound of the difference between the quartz crystal from crystal rhinestone, confused why the prices are something very different, crystal quartz optical cleaner but costs several times cheaper.
Rock crystal is called crystal clear quartz.Алексc3000 wrote:something very confused, can a respected Logician will explain again with stones bound of the difference between the quartz crystal from crystal rhinestone, confused why the prices are something very different, crystal quartz optical cleaner but costs several times cheaper.
It costs much more than the usual milky white, opaque or translucent quartz.
Prices in different places may be quite different. Affects the price of all transparency, chipping defects and their absence, the shape and size, the larger the crystal the more expensive it is. Also the price is affected by the treatment. Processed quartz is more expensive, sometimes many times.
Алексc3000
Then
very confused, if the crystal does not differ from quartz in properties why crystal is cheaper quartz. Ran across a different crystals that the differences in the crystals as well as crystals and in the place where it is from the Druze broke off from one base fiber and the other as the shard of glass smooth, both natural crystal here will be which one to choose.
Never seen.Алексc3000 wrote:why crystal is cheaper quartz.
No one will be chipping the crystals from the druses. In Druze the cost of crystals are higher, and collectors, more demand for the Druze.Алексc3000 wrote:and in the place where it broke off from the Druze
The base of the crystal where he began his growth may be quite different. Sometimes he seems to be growing from other rocks. His chip and place the chip visible minor irregularities.
Алексc3000
So I, too, seemed strange crystal but cheaper is one can there is simply a lot and he's lying under their feet, and on account of the Druze don't know Druze was met with a comparatively large crystals and the like is not so expensive thus the idea came to smash if it is possible for parts in the amount of more expensive to sell, but at the expense of the base of the crystals now hold in my hands a couple small one fibrous base like a bunch of fibers in the bundle and the second as a chip of glass have smooth, don't understand I think one of quartz and a second crystal just can not understand.
division by quartz and rhinestone conditional. Is determined only by the transparency.Алексc3000 wrote:one fibrous base like a bunch of fibers in the bundle and the second as the chipped glass smooth, do not understand anything I think one of quartz and a second crystal just can not understand.
Алексc3000
Got it, thanks for the quick replies, the main thing that difference turns out not only a particular frequency vary.
Алексс3000
And where you use the crystal? What comes to mind - pendants on a chandelier or kitchen utensils. The dishes are unlikely to carve quartz crystals. Pendants for chandeliers, perhaps a Czech crystal. Did not see live, all that came across, it was a glass of good quality. Maybe it's someone's marketing ploy? Just kidding? As I recall, quartz can scratch glass. There is a possibility of the sample crystal scratch glass? The idea traces should not be. But don't push it.what is the quartz crystal from crystal rhinestone
Logik Privelikim thank you for the wonderful gems!
Got the crystals just... can't describe!
Logic, respect. All the stones got in integrity preservation. Thank you. Mmm you want some more, some passion for stones.
Crystals received, all is well. Thank you!
The stones presented in the subject sold.
Little changed methods of payment 5% surcharge for cashing Yandex money cancelled, due to the extensive spread of cashless payments. Payment to the card of Sberbank canceled - too lazy to renew the card because of the three stones
Payment options
1. Bank transfer.
2. Postal transfer.
3. Yandex-money
Payment options
1. Bank transfer.
2. Postal transfer.
3. Yandex-money
Thanks Logik !
Received safe and sound!
1. It is necessary to clean the crystal with a fine spray(drop) from vodoprovod - what time is it?
2. How to set coil --(where one side of the plane 45* other multi-faceted) ?
3. If the wound (bagel) very Krishna tight winding to the crystal?
