come?Новик wrote:to go to holotrop
How to quit Masturbation?
Clear.Сергей Гурин wrote:Well basically used affirmations in different variations so to speak...
*Muttering affirmations for a long time
*listening to recordings of own normoton affirmations,
+ writing installations on paper
*audionastroi A. Sviyash,
*affirmations for SP,
*program rainbow + the Matrix of success working on the principle of 25th frame...
In General, experience has such equipment more than 3 years, I can't say that there is some tangible result
Will answer in PM.could you elaborate if you can...
Masturbation is normal at any age, even if you successfully married... the Sexual tension well remove exercise. Some people use abstinence as techniques of spiritual growth.
By the way, just in case to see a urologist. - The reason for the permanent tower can be starting the disease.
Any complex - it's just a habit. To rid the little mental techniques (nothing better 6 stepper of reframing I don't know), you just have to start actually regularly doing something differently than before. And don't Bang your head against the wall when suddenly forgot for some reason, or failed, and to analyze the reasons and attempt after attempt. In fact the failures do not happen (this is just an emotional assessment), there is only feedback.
In the network there is a book called. Also promoter of this technique is Dr. Sinelnikov. There are more mythological (read "beautiful") option - Holodynamics.Сергей Гурин wrote:Andrew, where can I get detailed practical information about this technique?Андрей Патрушев wrote:nothing better than a 6-stepper of reframing I don't know
The technique itself:Chistiakova reframing
1. Identify the stereotype X, which you want to change. "I want to start to do X, but can't." Or "I want to do X, but I something stops".
2. Set the communication with the part responsible for the stereotype of X.
a) "Will the part of my personality that is responsible for the stereotype X, communicate with me in consciousness?" Pay attention to any feelings or sounds that occur within you after you ask yourself this question within yourself.
b) Set the value of the signal "Yes" and "no." Let the brightness, volume or intensity of a signal increases, if the answer is "Yes", and reduced if you get a "no" answer.
3. Separate the behavior of the stereotype of X from the positive intention of the part that is responsible for X. Positive behavior is the only way to achieve any positive goals.
a) Ask the part that is responsible for the stereotype X: "do you want to give me the opportunity to realize that you're trying to do to me using a stereotype X?"
b) If you get a "Yes" response, ask the part to go ahead and say openly that intention. If you get the answer "no", leave this unconscious intention, assuming it exists.
C) Acceptable if it is the intention for consciousness?: Would you like to take part, which would implement this feature?
d) Ask the part that is responsible for the stereotype X, "If you. been known ways of achieving the same goal, which would be as reliable or even more reliable than X, would you be interested to implement them?"
4. Get access to the creative part and ask her that she has generated new behavioral responses to achieve this positive function.
a) will Get access to the experiences kreativnosti and secure them with anchors or ask: "do you Realize that you have a creative part?"
b) Ask the part responsible for the stereotype X, communicate its positive function to the creative part and allow creative part to generate new elections to achieve the same positive goals. Get a part responsible for x, to give 3 choices that are at least as good or better than x. Let part X gives the signal "Yes" every time, if she takes any option as alternative X.
5. Ask part X: "do you want to take the responsibility to use the 3 new options of behavior in the appropriate context?" This will provide connection to the future. Additionally, you can ask the part of X on a subconscious level to identify the sensory cues that will trigger the operation of new behaviors and fully experience the state in which the client would be when these sensory signals are automatically start new reactions, which would easily and automatically.
6. The environmental audit. "Is there inside me, any part of which would have objected to at least one of the three new behaviors?" If the answer is "Yes", return to step 2.
No matter what "obstacles" you may encounter, producing re-formed, you can leave three of them to you in the end, a large number of reactions to these obstacles.
Sincerely, MAG.no<
Sincerely, MAG.no<
- Дмитрий_999
The practice has experienced the method on the book Sinelnikov – I have a very strong "nervyak" on the neck formed spots, like the crust, flaky – addressed to advanced homeopath, it turned out that it is psoriasis.........so after talking with the subconscious through the book twice, the disease is gone – no pills and homeopathic remedies, ointments, etc. are not used.
Стратокастер
Новик
buy the program of the Manifestation it's nice RAD tool for greater efficiency and customize it to attract a sex partner(for best results, some familiar,WMS job,WMS neighbor)and I think she'll bow thrusters,you can still simultaneously to set the program on it to stimulate sexual desire.and if not these tools at hand, throw me your photos,friends and your names will see the effect.Стратокастер wrote:Thanks for the replies.Going to educate yourself Smile
Нетрезвый Сурдопереводчик
- Been thanked: 1 time
in General,urologists in this matter are divided into two camps.people are different,someone from 5 years of abstinence do not have any problems with the prostate gland,and someone snoshu 6 times a day,drinking Prostamol UNOЗОМБИ wrote:pleess give pruflinkНовик wrote:Orlogi unanimously say that multiple orgasms are(without ejaculation) the HARM
in General,laughter...most of there 30,and such problems,multiple orgasms are,wank...where is this World heading?
From day to day, from month to month, from year to year, their precious body constantly produces semen, loses her again and again with furious speed produces, the entire endocrine system can no longer cope with the overload and, roughly speaking, very much suffering, only works with \\\"cum\\\".
Bones become thin, the body \\\"loses\\\" vitamins and nutrients, the hormonal system is disrupted, the body weak, thin, painful, the skin pale, the body begins to function poorly with all the ensuing consequences.
Masturbation leads to the fact that the balance is shifting, and the dominant centre of the body becomes \\\"bottom center\\\". Man loses his natural balance. The balance is broken. Roughly speaking, in the body form a habit to constantly produce and store sperm, not caring about anything else. The body becomes \\\"sharpened\\\" on the production of seed. It happens to everyone, without exception, each young man engaged in Masturbation, sooner or later displaces the vital natural balance of your body for the production of seed.
замечтавшийся
Re: How to quit Masturbation?
It helps not to visit adult sites, the program K9 protection http://www1.k9webprotection.com/ - install, configure, discard the password and you won't be able to watch exciting content even if you want!
As for me - big relief!!!
Vsem privet kak brosit onanizm eto zavisit ot tebya tolko ot tvoey power vley
