Create your own CDs with psychoacoustics
САМОЛЕТ
Post by САМОЛЕТ » Wed Aug 25, 2010 19:29
Polnofunktsionalnyi version you can only buy from them and the trial version can be downloaded here
http://latentframe.ru/treat.php
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Wed Aug 25, 2010 20:09
PLANE,
I'll tell you a secret, all the same, you can do it in Cool Edit Pro. And it is free. Don't see any reason to buy this "audiodeformator".
And wewbsite, you have a year and a half ago I started a similar theme.
http://www.mindmachine.ru/viewtopic.php ... highlight=
Really for a year and a half so do not try to do yourself?
САМОЛЕТ
Post by САМОЛЕТ » Wed Aug 25, 2010 20:15
There are not only audiodeformator.And more sessions can be created without it.I'm not talking about audio deformer. Yet he did nothing.Was going to,but was postponed this venture.Now decided to do it
Экко
Been thanked: 4 times
Post by Экко » Wed Aug 25, 2010 20:22
The full version of the Deformer I found for free. Honestly a rare thing. To redraw the graphics of the wave takes 20 times more time than in Sound Forge, same thing with opening/saving files. In addition, he is also not all WAV files are open. After this product is not very good impression of the developer. A Latent Frame of Svetozor.
САМОЛЕТ
Post by САМОЛЕТ » Wed Aug 25, 2010 20:25
Blah, Yes, and here's a deformer?! To create sessions need a different program,it there is.
САМОЛЕТ
Post by САМОЛЕТ » Wed Aug 25, 2010 20:26
All go there and see for some reason only the deformer
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Sun Aug 29, 2010 12:33
Use Adobe autdition 1.5 (is the same Cool Edit, only after it bought out of Adobe). Do just - recorded voice multiple audio files:
- affirmations on the topic,
- Short phrases on the assimilation or deepening the state(these stretch pitcher 8-10 times, get a rare growls/gurgles),
suggestions for mastery of the basic affirmations mixed affirmations(these will be accelerated in 8-10 times, it turns Zsuzsanna).
Then on the first entry imposes two second, reducing their volume to a minimum, so as almost not to listen. It's impact on sub-threshold level of perception.
On include mind-machine, and connect the recording to the audio input.
There is another simpler option is to make audiostrobe disc from the recording - does the program MindExplorer SW 3.7 and a suitable session from the mind-machine(supported photosonics and some others) - demo version without any restrictions saves the session in WAV format without loss of quality. And then the first three entries are overlaid on the received file of the session - in this case, you can play time early in the session only include suggestions for immersion and deepening(better the second and third record, the first can be seriously distracting), and the suggestion to start with the moment of the session to which it should be achieved suitable for the promptings of the condition.
Good luck in development)))
Экко
Post by Экко » Sun Aug 29, 2010 17:11
I heard about this method of subliminal suggestion. And if affirmations in the same way to process?
Экко
Post by Экко » Sun Aug 29, 2010 17:56
Agraulis with AM modulation, the thought came, as if to modulate the ultrasound you know what frequencies will it work? The advantage of this method is in the hidden effects can be included in the room and no one can guess about it :)
Post by Андрей Патрушев » Sun Aug 29, 2010 18:11
Экко wrote:Agraulis with AM modulation, the thought came, as if to modulate the ultrasound you know what frequencies will it work? The advantage of this method is in the hidden effects can be included in the room and no one can guess about it :)
Stage hypnotists (foreign :)) apply 12kHz modulated theta frequencies, using normal speakers in the hall. :)
Post by к-13 » Sun Aug 29, 2010 19:16
Yes, no one bothers, of course, but only if the entry needs to be very long))) a Few words clearly goals are usually not articulate, and if repeated several times a few volume of affirmations, stretched 10 times, it will take more than an hour...
Post by к-13 » Sun Aug 29, 2010 19:25
Stage hypnotists (foreign :)) apply 12kHz using normal speakers in the hall. :)
We in the oil shop at the food factory is under press squeezing sunflower seeds. One time he broke the mechanism pulls the excess air and ventilating of the internal compartment with the radiator, it started to "blow" portion of the wind somewhere around 4-7 times a second. When the Windows were open, nothing else, but as soon as it got cold and the room is insulated, the staff in the shop started to drift off - asleep on the go and coffee is not saved. It is possible and the vibrator is adjustable to a sheet of plywood or sheet metal to connect through the rod... the Other thing is that the radius of the "hearing" will be much less than that of ultrasound or 12 kHz...
Экко
Post by Экко » Sun Aug 29, 2010 20:06
we in the oil shop at the food factory is under press squeezing sunflower seeds. One time he broke the mechanism pulls the excess air and ventilating of the internal compartment with the radiator, it started to "blow" portion of the wind somewhere around 4-7 times a second. When the Windows were open, nothing else, but as soon as it got cold and the room is insulated, the staff in the shop started to drift off - asleep on the go and coffee is not saved. It is possible and the vibrator is adjustable to a sheet of plywood or sheet metal to connect through the rod... the Other thing is that the radius of the "hearing" will be much less than that of ultrasound or 12 kHz...
Interesting, great. And what that wind was like? He was hear? About 12kHz is in the range of human hearing, so the sound will be heard, moreover, it is quite unpleasant to hear, I would like frequency for more to take.
Post by к-13 » Sun Aug 29, 2010 20:44
I did not feel, because of this phenomenon only from the stories heard. I was told that it is the workers themselves did not feel(there is quite noisy). But judging by most media(that's the one I saw) blow he had much skin, probably beating the air would be heard...
САМОЛЕТ
Post by САМОЛЕТ » Sun Aug 29, 2010 22:03
K-13
Adobe Autdition 1.5
MindExplorer SW 3.7
Give a link where it can download.
Post by к-13 » Sun Aug 29, 2010 22:57
Adobe autdition 1.5
Is there any suitable program, such as Audacity in Linux, Sony Soundforge, EJay(any version Techno, Dance, Rock or Pop)... if Only there was a function of mixing(blending one record to another, better if multi-track) and stretching. Such programs network is filled up. Companions Google, Yandex, Rambler, Mail and Yahoo(as well as a dozen less popular) know where to download them))) They will tell you where to download MindExplorer SW 3.7(by the way, here Kee gave with a bunch of Goodies - http://www.mindmachine.ru/viewtopic.php ... c&&start=0). Only not download version 3.6 - it is in the demo version only saves first 10 minutes of the session. In addition, you can use the same BrainWaveGenerator or NeuroProgrammer 2 Pro(they also retain their session in an audio file with audiostrobe-track). I do not use pirated software, so to give links to it will not.
With respect.
САМОЛЕТ
Post by САМОЛЕТ » Sun Aug 29, 2010 23:20
ATP! :ay
Post by к-13 » Sun Aug 29, 2010 23:31
Here is a demo ME 3.7 SW - http://krupchenko.by.ru/files/MindExplo ... %203.7.exe
And session her sorted(the old link on the forum died :( ) - http://krupchenko.by.ru/files/NP100-MindExplorer37.rar
Экко
Post by Экко » Sat Sep 04, 2010 7:13
Mind Explorer 3.7 + Patch (crack)
http://depositfiles.com/files/nslyun2pn
Post by Guest » Sat Sep 04, 2010 18:58
Torrent tracker is a program...
Сергей Ивлев
Has thanked: 109 times
Been thanked: 433 times
Re: Creating your own discs with psychoacoustics
Post by Сергей Ивлев » Mon Jan 25, 2016 9:28
Novosibirsk made prog music visualization that reacts not only on the volume but also change the timbre of different musical instruments. 've been looking for. And I'm an expert on audio imposition, arngrove music
Post by Андрей Патрушев » Wed Jan 27, 2016 16:57
к-13 wrote:I myself did not feel, because of this phenomenon only from the stories heard. I was told that it is the workers themselves did not feel(there is quite noisy). But judging by most media(that's the one I saw) blow he had much skin, probably beating the air would be heard...
In the last century, in England, have conducted similar experiments. Subjects were placed in a closed room, one wall of which was a membrane. On the reverse side there was a powerful motor with adjustable speed, which via a gear and a rocker (like a steam engine) forced the membrane to oscillate with a different frequency. The effects were very diverse - up to rupture internal organs...
