My ALTARIA ))
Thus, the release!
software generator of rectangular pulses, working through COM port.
You only need to collect the key on the transistor n-p-n transistor, the scheme will paint later.
It is connected to pin 7 (signal) and pin 5 (ground).
Adjustable duty cycle and pulse frequency.
So experiment to your health! Can be used as Alfario, Electric, maybe even as a muscle stimulator and other devices where desired rectangular pulses.
Download: http://depositfiles.com/files/mv8wm42j4
http://www.ullasmann.eu/Zip/CesAmplifier.zip OOO!!! we have the same schema))) a voltage doubler
General course bad that we really do not know about the method to use. Well, let's say we borrowed the strength of the current, voltage, place of application of electrodes have Alfaria. But is it possible to change the frequency of the brain feeding the rectangular pulses of the frequency? what should be the duty cycle of the pulse? what form? what is the direction of current?
Signal Alfaria unknown in principle, only guesses.
Scansorial at present in search of information found electric, -anesthesia-anesthesia and stuff, but that's the way to influence the frequency of brain rhythms well, anywhere such is not present. Tried this method on myself - not seen care either in Delta or theta or alpha state. The effect is, but what the other. Maybe if it really worked then it would have long ago been used and described?
About Alfaria that is:
Apparatus "Alfaria" effect on subcortical brain structures via
complex sequences of pulses of current value from 35 to 520 µa period
autocorrelation 10 seconds. This impact leads to the activation of the alpha rhythms of the brain
normalization other brain biorhythms, increasing the concentration of serotonin,acetylcholine, met-
enkephalin and beta-endorphins. Activation of the alpha rhythms of the brain (in the range 8-12 Hz) leads to
the state of relaxation, which reduces tension, stress, normal mood
regulates the perception of different types of pain. The exposure time when the above
the parameters were 20 min. Electrodes-clips placed on the earlobes. Course
treatment consisted of 20 daily sessions of TES.
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
I tried your so-called "Alfaria". Used its in-house virtual square-wave generator impuso via the COM port with transistor key. Flash yeah, there's even at low current. Though not blue and white. But the claimed effect, i.e. the transition to the alpha state (or another kind of frequency put up), I did not notice. Little or felt this way about (though I'm not ears plugged, and to the temples and the nape of the neck), or it should not be.
Incidentally - do my electrodes)))) from women's hair clips for hair))) http://savepic.ru/1420945.jpg
yeah I get that too, the effect by the way this thing me observed how calm and turn off all emotionshe Can so she brings it out in me because I'm a psycho PPPTS))) always somewhere strive and run ,no grams a quiet life,yesterday scheme neurophone saw and raced until 5 in the morning to look for the old))))
p.s. thanks for the scheme, such diversity is not found
after analyzing the chart, I can say:
1. dash up and down not clear: the current goes down then immediately goes up? Nonsense. So ignore them.
2. period: ~2.5 sec.
3. the frequency of 0.4 Hz.
4. amplitude: 100 microamperes.
4. the vibrations though are a little different, but overall similar. Perhaps their form all the time randomly changes slightly.
Software to repeat exactly simple. If you try, you can and hardware. Reverse-inzhenering taxis
Sneaker, you've done 10Hz
By the way I wonder why there is a 0.4 Hz?
