as the cyanide:)МерКаБа wrote:Василий_V So a Chamber to deal with.
The structure of the SS, SA - a question to ASD
Subscribe to RSS,you will have all the messages and supposedly deleted.Recently I deleted one message from reviews of the parlor without comment,which was written after the purchase of parlor people stopped working,and he tumbled the money,considering it is not an opinion ,and samosogrevanie topics.Василий_V wrote:by the Way I noticed that the messages appear in the parlor and then walk them some Shine forum!
funny...
Александр79
Александр79
Александр79
Приобретатель
In 2009 and 2010, a description of the Svetlitsa - Super is not changed. From the execution of the SS (in the round or in the form of cards) description not changed.Приобретатель wrote:has Gained the Chamber in 2009 (SS - plastic body). Today's purchasers (SS - map) showed a new, more intuitive annotation. I would like to see. Also, what improvements were made?
Svetlitsa-Super is available in two versions: 1. Plastic card http://www.mindmachine.ru/infokonstruktor/index.htmВоффка wrote:can you Tell me what the performance is now sold Svetlitsa super(preferably a photo)?
Will she be able to structure a 4-liter jar of water, if Yes then how much time it will take for the first time and how when you re topping up the water? What volume of water most efficiently to structure a room and what is the maximum volume that it can effectively handle?
Have You heard about the device for structurization of water Aqua disk, what is the difference of drawing rooms from this device (in terms of dealing with water of course)?
Thank you!
2. Plastic round tablet with a diameter of 50 mm
You can structure and 4 liters or more (up to 200). 4 litres is sufficient time for structural transfer is approximately 1 hour (effective time depends on the volume and material of the packaging). Later time will be less if you leave a little bit of structured water (20-30 minutes).
With Aquatica not only familiar, but also cooperate with the developers - OOO Aqua. Aqua disk forms a structure similar to the source of St. Sergius of Radonezh. This remarkable structure, which is pleasant and beautiful (see pictures of water crystals).
To compare structures is a thankless job. What are the criteria to compare? How to measure it? There is no Cutlery and unambiguous evaluation criteria.
Every developer believes their offspring best, as every parent recognizes the best for his child.
We are different. We have a different ideology - the maximum increase of the complexity (dimension) of the structure. Our ideology is the ideology of building structural ties, which could Express the qualities of water that are needed in a particular place at a particular time. Some assessment of this process can be done from photographs of water crystals that we did in OOO Aqua.
The photo clearly shows that the crystals of the Baikal water change during the interaction with the Svetlitsa-Super. It is seen that the inside of the crystal appears the secondary axis of crystallization, the crystals become three-dimensional. It just shows the growth of dimensionality of the crystals. Therefore, the interaction with the SS, the person increases the dimensionality of its liquid crystal (which we mostly consist of 80%). The presence of structures larger dimension of the man allows him to process more complex information and make better decisions. Ie, the person becomes more accurate and efficient, less stressed and does not waste energy for nothing. Hence increases the feasibility of desires, as it increases the connectivity with the display systems of our reality.<
Новик
ASD
Now sold only the new version of Svetlitsy map?
As I understand from our conversation "tablet" this is an old version of Svetlitsy and it is not roizvoditsya?Svetlitsa-Super is available in two versions: 1. Plastic card http://www.mindmachine.ru/infokonstruktor/index.htm
Tablet or map - two versions of the SS. Some want a pill. The structure is the same. Produce both versions. Although there are slight differences in the pill one structure in the map along with two.Новик wrote:ASDAs I understand from our conversation "tablet" this is an old version of Svetlitsy and it is not roizvoditsya?Svetlitsa-Super is available in two versions: 1. Plastic card http://www.mindmachine.ru/infokonstruktor/index.htm
Новик
From konstruktivnych. The map shows two structures. This somewhat strengthens her work. That's done. Where previously it was written that the distance must be more?Маг.нет wrote:Unidirectional? For what reasons the second? Backup? And why 3 see, earlier it was written that the distance should be more.АСД wrote:Two identical structures at the distance of 3 cm from each other.
Sincerely, MAG.no
