Manifestation and Astro-Dynamic program
- Has thanked: 1 time
- Been thanked: 182 times
- Contact:
- Contact:
https://mindmachine.ru/catalog/shop/elektrosmog/
Now everywhere will be generated DOR ,in residential areas in particular,in accordance with the decision of the government on the transition to energy-saving lamps.Important convert it into a living orgone.![Smile :)](./images/smilies/icon_smile.gif)
So this Klondike if to prove that the radiation of the lamps is harmful and if to prove that orgone generators to neutralize radiation!
Only 2 'If'... what kind of research is supported by the allegations in this article?
Also open question about the negative impact of television tubes, mobile phones... are there experiments confirmed the facts of harmfulness?
![Wink ;)](./images/smilies/icon_wink.gif)
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
- Contact:
IMHOАураведа wrote:radiation lamps and malicious if to prove that orgone generators to neutralize radiation
there need not orgone-generators and what is called "ORGANICA" (organic - orgonite)
here for example: http://www.orgonite.info/ http://www.thebluesun.co.uk/orgonite.htm
- Шалтай Балтай
- Contact:
IMHO - interesting topicШалтай Балтай wrote: is called "ORGANICA" (organic - orgonite)
http://video.ariom.ru/t/orgonite.html
The theme is interesting, of course. But after much thought, I came to this conclusion: is this worth it? In a sense, the transformation of the dead orgone into pulsating with orgonite. Organic - the artificial material, and therefore a patent on it there. The problem is that in Russia (other countries not say) energy-saving lamps,having put them a period of time will be taken to a General landfill. There also will be served their plate orgonite, or the entire orgone generators. Electromagnetic garbage we may win, but will create a waste of material.
By the way, does anyone know the service life orgone generator? And methods of disposal? Does orgonite or orgone generator residual radiation as copper wire, for example?
Humpty Baltay, perhaps organic can run without orgone generator? In my opinion, it performs only the functions of the amplifier, transmitter and receiver, but not self-sufficient.
Organic patented, the 20-year patent term has not yet expired. And already there were the recipes of cooking in the home, whether organic they mean? Hardly - even patented the name, not just the chemical composition.
As a variant it is possible that Welz did not have time to patent organic in all countries of its proposed sale. But again the question arises: why the Network put free what you can sell?
- Шалтай Балтай
- Contact:
IMHO - organic - just the Converter/accumulator of agrona. Generator to it is optional.Ванька-встанька wrote:Humpty Baltay, perhaps organic can run without orgone generator?
Don't knowВанька-встанька wrote:Organic patented, the 20-year patent term has not yet expired.
Patent saw?
At home You can cook anything, that's use to commercial purposes is a different matter.Ванька-встанька wrote:And already there were the recipes of cooking in the home, whether organic they mean?
At the mention of the word "organic" standing next to the R in a circle - Reserved.Шалтай Балтай wrote:Patent saw?
That is, no patent, and commercial use is prohibited? But the question was different: as a result of mixing obtained organic similar Walczewska, or something else?Шалтай Балтай wrote:At home You can cook anything, that's use to commercial purposes is a different matter.
- Шалтай Балтай
- Contact:
And still the device will need "...the scientist Soon realized that the throbbing orgone energy (which generates orgone generator or a rotating planet) transformerait dead orgone (DOR) back into orgone energy..." at least in order to get Orgon to throb. In General, to organic started to work, you need a rotating EMF because of the earth's electromagnetic field in the case of increased DOR-education is not enough, most likely
- Шалтай Балтай
- Contact:
- Шалтай Балтай
- Contact:
http://www.mindmachine.ru/viewtopic.php?p=41956#41956how to combine work program and RAD? thanks for the help.
- Contact:
http://www.mindmachine.ru/radionics/man ... manual.pdf
Description of the program,while in English,we will translate soon.
- Шалтай Балтай
- Contact:
I'm going to ask Carl trail questions:
If you have any questions - write here, I'll messenger everything over to Karl.
- Are there additional templates for the Manifest?
- There is a manual that explains how to correctly do templates?
- The attitude of arcturans codes and sacred geometry in General ()
- If instead a link to the SD to use a different a couple of pictures, your photo for example.
Offer 2: 1)Than is objectively possible to measure the power of orgone(or force - I don't know the units)on the output of the device?; 2)he determines that the orgone device And allocates a greater than/less than X times than the device In (relatively, of course - but the point is clear, I think)? The questions may seem silly, but the answers will be interesting not only to me, I think. Thank you!
Hmm... it would be interesting to know... I'm a little googled, but nothing found except a Bovis Biometer...Ванька-встанька wrote:Offer 2: 1)Than is objectively possible to measure the power of orgone(or force - I don't know the units)on the output of the device?; 2)he determines that the orgone device And allocates a greater than/less than X times than the device In (relatively, of course - but the point is clear, I think)? The questions may seem silly, but the answers will be interesting not only to me, I think. Thank you!
http://www.xtrememind.com/Ultraradx.htm
However, since this is the Bovis Biometer "works"VERIFIED TO EMIT FORCE ENERGY: Thorough testing ascertains that the RAD-X emits commendable quantities of chi energy. At least 120,000 units bovis detected, plus copious amounts of Gold, Ultraviolet, Infrared, Blue and negative green energy! To be life sustaining, an energy. source must emit at least 7,000 bovis units plus three of the aforementioned subtle energies.
(as I understand) is only in contact with the operator (as the frame of lithodes), to talk about the objectivity of such measurements is problematic.
http://answers.google.com/answers/threadview?id=28671
http://en.wikipedia.org/wiki/Bovis_scale
Probably the conclusion about capacity is based on the design features of these generators (the type, the more there some elements, the more powerful) + subjective feelings.
I have another 4 questions. They relate to amplifiers, PBT and PBT 2400 2400HD:
3)what is the principle lies in their ability to enhance the amount of generated orgone several times?
4)which principle underlies the interaction between the transmitting and the receiving sides in the transfer pair and why they should be replaced only in pairs (for example, in case of loss of one of them)?
5)based on what division of the amps and amps HD series: according to the material from which they are made, by weight izrashoduete this material or something else?
6)if we attach to each of the orgone generators of such a device, such as the ATG 12, the amplifier series PBT 2400 HD, will it make power gains? And if you will, how many times?
Thanks again!
Thanks again!
- Владимир Никонов 2
- Has thanked: 20 times
- Been thanked: 28 times
- Contact:
Translation of user guides for the program
http://www.mindmachine.ru/radionics/man ... rogram.doc
- Шалтай Балтай
- Contact:
http://www.mindmachine.ru/viewtopic.php?p=42307#42307Шалтай Балтай wrote:If you have any questions - write here, I'll messenger everything over to Karl.
Yes, about the Power booster is interesting.Ванька-встанька wrote:I have another 4 questions. They relate to amplifiers, PBT and PBT 2400 2400HD:
Haven't had time yet to ask.... later
