Svetlitsa Windows
Руст
Post by Руст » Mon Feb 28, 2011 21:59
Hello! Received my order today, won a Chamber-Super and a Chamber-Window.
Prompt, please, a rectangular card is pasted on the left or right side of the frame? Or is it irrelevant? For some reason I want to stick with the left...
Post by Маг.нет » Mon Feb 28, 2011 22:11
АСД wrote:the easiest way to determine the location of the labels: mentally draw a square window with sides of 1 meter to one of the corners was on the frame and at least one corner on the glass. For any diagonal of the square place the stickers, but that one fell on the frame, and the other on the glass.
Like - glue:)
Sincerely, MAG.no
Руст
Post by Руст » Mon Feb 28, 2011 22:40
Маг.нет wrote:Want to - glue
Thanks for the quick reply!
Had to stick with the right, because the left the balcony door(a lot of questions from guests will fall, and once on the outer part not very comfortable) and in addition a small, curious child :)
Ксюта10
Re: The Parlor Window
Post by Ксюта10 » Thu Dec 15, 2011 7:23
Bought-the Window (yesterday, a package came for)
Just do not understand how to fasten a large plastic card :roll: twirling, twirling it but I really don't see in the end prislala the frame to the double-sided tape :?
Тяфа
Post by Тяфа » Thu Dec 15, 2011 11:35
Well done, I also have to tape to the frame attached bi
Ксюта10
Post by Ксюта10 » Thu Dec 15, 2011 14:07
the Yip :)
Петр Петрович
Post by Петр Петрович » Thu Nov 15, 2012 19:22
Stuck in the office. The performance went up drastically. From the office moved out unnecessary people and took his place need :wink: . However, today the chief said that it is deposited a month and a half, but I think this time he'll change his mind :)
Ростислав
Post by Ростислав » Thu Nov 15, 2012 19:40
:ay Windows in General real device I got the whole house plastered them all like we have)))
Ярый
Post by Ярый » Sun Nov 18, 2012 14:18
Hello!
Then it was said that both labels should be located in the same plane. The question is: in the room, plastic window with two sections. One section blank, the second opens and is almost always in the mode of ventilation, i.e. the lower side of the leaf in place, and the top half open and drooping. In this case, both labels need to glue only a blank section of the window?
АСД
Post by АСД » Mon Nov 19, 2012 1:30
Ярый wrote:Hello!
Preferably in the same plane, but in Your case, the misalignment is not too large and has little effect on the efficiency of the device
Ярый
Post by Ярый » Mon Nov 19, 2012 10:27
Thank you! Now I thought that in summer the window is almost always open, i.e. it is better to glue on the dead leaf? Or due to the fact that the stickers not the whole window will block the efficiency will be lower?
Ростислав
Post by Ростислав » Wed Nov 21, 2012 22:32
I have pasted on the non-opening side
Ярый
Post by Ярый » Thu Nov 22, 2012 8:24
Well, Yes, logically, it turns out that not opening the flap should be glued. Thank you!
Россомаха
Post by Россомаха » Fri Mar 15, 2013 11:30
And what is the size across the width of the sticker that is attached to the frame? And then suddenly will not fit.
Ростислав
Post by Ростислав » Fri Mar 15, 2013 11:37
the amount of the Bank card
Россомаха
Post by Россомаха » Fri Mar 15, 2013 12:30
Ростислав wrote:size of Bank card
In centimeters can write how much?
Ростислав
Post by Ростислав » Sat Mar 16, 2013 22:18
8,5x5,5
Горизонт
Post by Горизонт » Sun Mar 17, 2013 12:56
Tell me how pravilnee place With Windows in operating cash (e-currency). There are no Windows on the street, there is only a small armored window, and it goes on the street and in the vestibule (vestibule). If this is a small window to stick will it be effective? or better on the front door or on the wall which looks into the street?
Россомаха
Post by Россомаха » Mon Mar 18, 2013 15:39
Ростислав wrote:8,5x5,5
I have a frame width less than 5.5 cm then How to paste?
АСД
Post by АСД » Tue Mar 19, 2013 2:24
Let slightly protrudes over the frame.
АСД
Post by АСД » Tue Mar 19, 2013 2:27
Горизонт wrote:how pravilnee place With Windows in operating cash (e-currency). There are no Windows on the street, there is only a small armored window, and it goes on the street and in the vestibule (vestibule). If this is a small window to stick will it be effective? or better on the front door or on the wall which looks into the street?
Better on the wall, which is on the street watching. In addition to visible light, there is also the invisible that can pass through walls. So the wall mentally, draw a square with sides of meter and diagonal of a square stick to the wall of the front Room Window.
Нопасаран
Post by Нопасаран » Fri May 03, 2013 1:38
Welcome! Today I received and installed it on the window in the room the Parlor Window. The window is divided into opening the door to the balcony (open type) and a remote part. Mounted on the blank portion, as the door opens fully very often. The card is in the left corner of the frame, and the circle, the diagonal in the upper right corner on the glass.
The question is: we have the Windows feature blinds. Is there a difference, lowered or not? That is, when they are omitted, then cover the top of the circle...)
Thanks in advance for the answer!
Кимили
Post by Кимили » Fri May 03, 2013 12:48
From 8 Windows Svetlichny two Windows.
Side - South East - South, as a result, hot.
From March, the temperature in the rooms( while off the battery) comes to 32-33 °C.
In this regard, the window Fully closes paid-outs...
Myself, and a stranger to the Parlor for SOME reason, people choose the one Streak of light or like a slice of space, which is at a right angle from the window in the Parlor-Window.
The answer to your question: Yes, it works!
Нопасаран
Post by Нопасаран » Sat May 04, 2013 0:49
аитвюооня wrote:the Answer to your question: Yes, it works!
if it's me, then thanks!)
АльфМ
Post by АльфМ » Sat May 04, 2013 1:52
Today I just read here that the card should be glued to the frame. Found , stuck.)
