Structurer water
Искатель-2
Re: Structurer water
Post by Искатель-2 » Wed Aug 15, 2012 13:13
sent test reports, certificates, etc for the products of grander.
You need someone ?
here
http://narod.ru/disk/59423266001.b5ae69 ... t.rar.html
Ирина Ли
Post by Ирина Ли » Thu Mar 21, 2013 20:03
I have a Aqua disk, the water really is milder in flavor.
Искатель-2
Post by Искатель-2 » Fri Mar 22, 2013 0:11
Irina Lee
just crack it in six months, and planted activation
Post by Михаил_ » Wed Mar 27, 2013 22:43
and not necessarily.
Искатель-2
Post by Искатель-2 » Thu Mar 28, 2013 4:33
Michael_
you mean Aqua disk ?
and so:
Конст
Post by Конст » Mon Jul 29, 2013 14:07
And you heard something about running the outliner ? What people think about this http://topion.ru/ ???
Искатель-2
Post by Искатель-2 » Sat Aug 10, 2013 13:41
Konst think you're from their website, I decided this is tricky to do
you have one message only
ВикторРусс
Post by ВикторРусс » Sat Aug 10, 2013 14:29
I wonder what magnetic pole is a magnet to water, not the South by chance? someone would have to ask..
Анна Соколова
Post by Анна Соколова » Tue Dec 03, 2013 14:45
In order to prepare magnetized beverage, is enough to put the Magnetic wand into a glass with a drink for 15 minutes. After which the drink will become magnetized ( ~ 800 Gauss).
This water can be used for 3-4 days. The life-giving water activates bowel and quickly adjusts even the complex disorders associated with digestion. Such water can be drunk and the youngest members of Your family - children from the first day of life. This water relieves the babies from colic and improves sleep.
Post by Михаил_ » Thu Dec 05, 2013 21:03
and stimulates some types of tumours
Альтаир
Post by Альтаир » Thu Jan 16, 2014 20:30
And I'm a fan of defrosted water .
Take the 3 liter plastic bottle filled with water from the tap and in the fridge overnight.
In the morning take out and put it out to thaw .
That thawed - drained into another bottle .
So from 3 liters to 1.5, take the first defrosted and the rest is discarded .
Beautiful water .
Stored in the same plastic bottle is not more than a day .
Ie, its a day to drink , otherwise it changes the taste .
Store the closed tube .
I personally like it .
Yes . bottle certainly not plastic , so they just call , but actually it's polystyrene soda , kvass , beer .
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Fri Jan 17, 2014 0:07
Альтаир wrote:So from 3 liters to 1.5, take the first defrosted and the rest is discarded .
I read somewhere that when water is frozen, there is no need to give her all to freeze. Before freezing, drain ostanek water, called brine. He Somerset last. probably melts in the first place. It turns out that You Pite the brine and clean water throw? Or is it not so?
Been thanked: 2 times
Post by ЗОМБИ » Fri Jan 17, 2014 0:41
Михаил_ wrote:and stimulates some types of tumours
and the water after the magnetic stirrer is suitable for drinking? for example boiled to organize talk in a magnetic stirrer and then pour through a magnetic funnel
Lancelot
Yes, the brine freezes later, when I froze, proteal to brine a hole and was leaking, then more hot water was byteval, something that he managed to freeze, the ice should be transparent like. Ie seems to need to melt the top layer a couple of millimeters and inside it to transparent ice.
Альтаир
Post by Альтаир » Fri Jan 17, 2014 17:16
Honestly the subtleties I won't say this technique I remember from the Soviet times , then , in his youth had read somewhere ...
Now , sometimes "indulge" myself a little water ...
That's right - as you described her make and drink .
Like someone I like .
Just put the frozen bottle in the sink , well, let there ...
Unfreeze half , opened the tube , poured the water and the rest to ramarajya and poured ... it is not tasty ...
Ланцелот
Post by Ланцелот » Fri Jan 17, 2014 21:10
Understood. So I was wrong.
Эдуард
Has thanked: 4 times
Re:
Post by Эдуард » Tue Jan 27, 2015 14:59
Иннокентий Думка wrote:the Ancestors make some device for 10 min. "live" and "dead" water of the ordinary, the image quality-VA water, the device heats up/does not heat up.
If you can write the name of the device and where you bought it your ancestors.
Инкас
Post by Инкас » Tue Jul 21, 2015 3:03
I read somewhere that when water is frozen, there is no need to give her all to freeze. Before freezing, drain the remaining water, called brine. He Somerset last. probably melts in the first place. It turns out that You byte the brine and clean water throw? Or is it not so?
No, but that's all right, merge that will not freeze immediately, pour it is harmful substances, they remain in the middle of white usually, when defrosting defrosts initially around a core after as it is in the cold remains.
