The keys to the Svetlitsa - Blaga
Post by Шалтай Балтай » Thu Oct 08, 2009 11:10
АСД wrote: 3. Explain the activation key. Each key has a number. A user who purchased the key at this site sends number +79161647474 SMS message: register the key number (key number) in the card number (card number). In response it needs to obtain SMS with the text: the card number is activated.
Yes, it's really not clear
you can at least in General terms to explain how it "lives"?
thank you
Post by Шалтай Балтай » Fri Oct 09, 2009 11:15
and another question to the heap.
like which side the keys to the card is applied?
Жека3000
Post by Жека3000 » Fri Oct 09, 2009 12:12
Weird! ASD yesterday. And interesting question about the keys not answered...
Apparently this is another uncomfortable question for him?
The explanation I'd love to see!
АСД
Post by АСД » Fri Oct 09, 2009 19:11
Жека3000 wrote: Now that's interesting!:) And how activated the keys from the numbers you have provided?
From the point of view of a hoax You offer, we can assume that this room is "office of Heaven" where a message is sent to the owner of Svetlitsy good no....... entitled to great Benefits because it is paid and confirmation of payment has no key. So?:) In this case, these keys must be under the protection of the scratch-off layer, and then Malolo somebody already activated for his security? It is not clear. With the keys the whole story even more confused!
Clarify how a mobile phone affects the activation? What happens to the other side of the telephone line after sending the SMS?
Well, I can understand if you had to wear them together, where the key performs the function of the amplifier. And here nothing is clear... to send SMS, prieiti the key to SB for 30 minutes... How to understand Sergei Denovich? Because in SB, as in the other parlor used technology potoprens, to create structures, and after drawing the structure, apply the keys, do not apply the structure of the SAT will not change! And to increase the AC power of the security Council, it is logical to assume that should change the dimension of the structure! :?
And another interesting point ASD writes: "a User who purchased the key for this site"!!! What's the difference where the user bought the key?
The activation key is implemented by the user through the acquisition of key and applying it to the card. Thus increases the level of connectedness of the fractal structure of the drawing rooms - the Good and the cardholder. This one-time procedure. And to avoid any temptation resale key after using it, the key number is entered into a database and linked to the card number. To do this, and is sent as an SMS message. Thus, the system checks in the database that this key nobody used before. Hence, the confirmation of activation.
Probably You are right, the key number should be close. Consider Your remark.
The users who bought keys from other of our representatives, send SMS to other numbers. Then all numbers are reduced into a single database. It might create a single number for SMS.<
АСД
Post by АСД » Fri Oct 09, 2009 19:15
Георгий_19 wrote:and another question to the heap.
Side of the latch does not matter.
Noticed a typo in my first message. A reply SMS will be as follows: key no. is activated.
АСД
Post by АСД » Fri Oct 09, 2009 20:06
Жека3000 wrote: Well, I can understand if you had to wear them together, where the key performs the function of the amplifier. And here nothing is clear... to send SMS, prieiti the key to SB for 30 minutes... How to understand Sergei Denovich? Because in SB, as in the other parlor used technology potoprens, to create structures, and after drawing the structure, apply the keys, do not apply the structure of the SAT will not change! And to increase the AC power of the security Council, it is logical to assume that should change the dimension of the structure! :?
The keys are not amplifiers. The cards Svetlitsa - Blaga ensure the connectivity of the fractal structure of the person and the structure of the Svetlitsa - Blaga. But the scale of this connection can be different. The keys increase the degree of fractal connectivity of these structures. All keys of the same scale have the same structure. An analogy - rack gear rail, can be associated with one tooth, two, three, etc., but can be linked in two rail, three, four, etc. Or another analogy: cornucopia (flow of goods). It can be heterogeneous and consist of separate tubes. The keys add the number of tubes, increasing the total flow of benefits. But add in the specific flow, providing a resource of a particular person, the user of the Svetlitsa - Blaga with a specific number.
Жека3000
Post by Жека3000 » Fri Oct 09, 2009 22:22
ASD
Damn it! Again wanted Good!:) And so I think what you need to activate SMS to send and if not send an SMS that is not activated.
And if we assume that all the same key has already been activated but the user has not been sent SMS about the activation key and sold to another, who also sent an SMS that goes out that does not track! Because people, for example the distributor (network marketing) and have activated everything such as 10 keys and sell them! This in theory is possible! And can not keep track! Remains in the context of the key word for the seller, and the people are known, are dishonest! Protection is very weak, based on the consciousness.
Interestingly, the level of connectedness increases(the meaning is clear, but the mechanism of this of course is not!) With the structure of Chamber Benefits what happens with the structure of the key? Should something happen, once one card becomes stronger and the other gives the power and gives it only once. But in the parlor, no magnetic components and some material variables. Physically then nothing can not be changed! :?
In General, I thought! If the keys are so easily activated and their numbers are participating indirectly in the process of activation(i.e., activation is possible without a number), then any key can be activated unscrupulous seller or even someone who has access to them, even if to make a protective layer of the key number! What is the theme of keys as it is not thought out!
And, you can assume that Keys and room Good lay next to and part or all of the keys are activated, even without the participation of the seller...
Константин Дзябко
Post by Константин Дзябко » Sun Oct 11, 2009 3:54
Dear ASD,
1. could you tell me please where and at what price you can buy the keys for the SAT?
2.If the key expiration date after purchase? let's say I bought 3 keys, activated 1, after 2 months, activated another, and another after 2 months, the third key.
3.what would be more efficient to activate 3 keys at once at one time or one key every 2 months?
Thanks for the replies.
МерКаБа
Post by МерКаБа » Sun Oct 11, 2009 15:10
Sergei Dinovich, please tell me:
1. How many keys you need to buy Svetlitsa Blaga, consistent with the dimensions of the Svetlitsa Blaga gold?
2. Two cards Svetlitsa - Blaga, have twice the dimension than one card? Does it make sense, instead of keys, to buy another SB card?
Thank you.
Post by Андрей Кабанков » Sun Oct 11, 2009 15:23
Constantine Zebco
You can buy from us
https://mindmachine.ru/catalog/shop/cat ... tsa-blaga/
АСД
Post by АСД » Sun Oct 11, 2009 16:04
Константин Дзябко wrote:Dear ASD,
Expiry date no, but the warranty is 2 years and all of our products. It is possible to activate with any frequency, but it is assumed that the user is doing it consciously, observing the changes and increasing the flow of goods. That is, he puts in the keys part from the added flow. And how much to invest he decides for himself. Although it is clear that it is to track very difficult as the outside world affects the dynamics. So the schedule in the description is rather arbitrary. If the overall negative trend set by external conditions is greater than the scale of the drawing rooms - Good, then it would seem that the Svetlitsa - Blaga is not affected, although some temporaryuse the effect is certainly present but is only often not purely in financial terms, and in General optimization of temporal processes (the emergence of new opportunities, acceleration of events, organization of new connections).
3 keys at a time is more efficient, as they give greater dynamics.
Артур К.
Post by Артур К. » Sun Oct 11, 2009 16:07
ASD
And the warranty on that ? The mechanical wear and tear ? Or suddenly crack the case from the chamber ?
Post by Guest » Sun Oct 11, 2009 20:52
Андрей Кабанков wrote:Constantine Zebco
You can buy from us
Andrew,
thanks for the reply, didn't notice that there and the keys are also indicated.
Post by Шалтай Балтай » Mon Oct 12, 2009 11:04
Cough...
Well, you can then simply attach the key, thus using it, and in the database - not to register, and then resell....
This can potentially benefit the seller.
Something You have here IMHO, not thought.
Somehow we must manage to ensure the safety of the key.
Post by Шалтай Балтай » Mon Oct 12, 2009 14:41
By the way, IMHO
Sergei Dinovich,
The idea mnogorazemny keys and their exchange, not devoid of originality.
Жека3000
Post by Жека3000 » Mon Oct 12, 2009 17:20
Георгий_19 wrote:the Idea of mnogorazemny keys and their exchange, not devoid of originality.
Not Lishin sense! Because it's likely that the keys are reusable! In the key because nothing is magnetized, as in SB! Another plus, the key is not losing "power" on the basis of the claimed properties in the description. It says that key after activation can be used for the structuring of water!
Unfortunately the objective to check the possibility of the activation key multiple times on different SB is not possible! And even if it was possible that neither ASD nor any of the competent, interested people will not tell about it.
АСД
Post by АСД » Mon Oct 12, 2009 23:40
Артур К. wrote:ASD
Guarantee for performance. For the integrity liable.
АСД
Post by АСД » Mon Oct 12, 2009 23:54
I understand your concern, which is caused by ambiguities in understanding the operation of the system of structural-informational servicing Svetlitsa - Blaga. Do not worry as there is another transaction about which you forgot. This action on payment. This is also part of the activation process key and without it the whole procedure is piecemeal and does not work. So nedobrosovestnyh dealer maybe even a pack of keys to hold down on the map, he will not get anything from this operation, and the keys will not spoil.
You say, and as keys (Svetlitsa-Blaga) learn about prepay. The fact that it is necessary to consider the structure of a Chamber-Good in interaction with the structure of a person. And the man realized the necessity of acquiring key and paid for it, the structure changes and becomes able to interact with the key. More about this talk on the seminar.
МерКаБа
Post by МерКаБа » Tue Oct 13, 2009 0:30
АСД wrote:And the man realized the necessity of acquiring key and paid for it, the structure changes and becomes able to interact with the key. More about this talk on the seminar.
:shock:
And what to do to those who cannot attend the workshop, but really wants to obtain this information?
Жека3000
Post by Жека3000 » Tue Oct 13, 2009 0:33
Merkaba
After the workshop, ask me a question and I will answer!:) Or maybe the video again remove.
АСД
Post by АСД » Tue Oct 13, 2009 0:36
:shock:
You can creatively approach this issue and to organize the seminar on place of residence.
МерКаБа
Post by МерКаБа » Tue Oct 13, 2009 0:44
Жека3000 az
Жека3000
Post by Жека3000 » Tue Oct 13, 2009 2:16
АСД wrote:Can creatively approach this issue and to organize the seminar at the place of residence
You need to know the necessary conditions of the workshop! Minimum number of participants, price participation in the minimum/maximum amount, Your "rider" during your stay in the city, etc if You provide this information for public access, wanting to organize will be more. Likely that so wanting is not enough, but You're also interested in workshops in the cities where still never spent! Because this is advanced, and osvedomlennosti and as a consequence the location of potential buyers! And still can be at the seminars to sell products FACE to those who have bought and came to the seminar for the sake of expanding horizons.
Post by Шалтай Балтай » Tue Oct 13, 2009 11:14
АСД wrote: I understand your concern, which is caused by ambiguities in understanding the operation of the system of structural-informational servicing Svetlitsa - Blaga. Do not worry as there is another transaction about which you forgot. This action on payment. This is also part of the activation process key and without it the whole procedure is piecemeal and does not work. So nedobrosovestnyh dealer maybe even a pack of keys to hold down on the map, he will not get anything from this operation, and the keys will not spoil.
Some things can only comment on one word and that word is "yoprst"
"live till seminar" az
ТоринГость
Post by ТоринГость » Tue Oct 13, 2009 23:27
In General, it is clear that nothing is clear. Can someone give a plausible answer (besides of course the promise at a workshop) How? maybe the key describing a kind of artifact information potametum to interact with the card Good, where the other artifact information is recorded in the same potametum i.e. not changeable at all? And how these two photos can affect the integrity of a certain energy-informational structure of a person in accordance with the purity of his intentions?
I would be grateful for an answer.
P/S/ Still I think Landau said that if a physicist can't explain what he was doing, he needlessly gets the money.
