Electrodes
In English is not strong, but in the American counterpart, it seems, can change the lining clips. It is better to change pads than the clips, and put them in a bigger zip Alfaria. http://www.alpha-stim.com/default.htm
a question for the manufacturer: ALTARIA is a full copy ( in another case ) imported products? And then all of the information set out on http://www.alpha-stim.com fair for her?Евгений Л wrote:...but in the American counterpart, it seems, can change the lining clips. http://www.alpha-stim.com/default.htm
Not quite complete. Alfaria an improved version and brought to mind. One of the Latvian sellers of alpha-stim and other similar products said ALTARIA is much stronger and more effective (he tried it at our office).Anonymous wrote:a question for the manufacturer: ALTARIA is a full copy ( in another case ) imported products? And then all of the information set out on http://www.alpha-stim.com fair for her?Евгений Л wrote:...but in the American counterpart, it seems, can change the lining clips. http://www.alpha-stim.com/default.htm
Г0сть
Re: Electrodes
I would like to Alfario uluchshenii:
1. The display output is not just a "dumb" number-level, and the real amperage
Think like electronics it is not difficult. But how many advantages:
a) you really see how the current flows,
b) here contact no contact. Removed the subjectivity, it is important not how you "tingle" and the real current passing through your brain (is that right ?).
in)Will see release clips or not. In this case it would be good to make some sort of sound.
2. Clip. Fly. Must be wet the Pads came off after four sessions.
There is not a bad solution samoupravleniya strips, it is implemented in many devices electro stimulation.
And if you combine these contacts with the headphones would be awesome ( two versions with small headphones mobile option, stationary and large be used in conjunction with MM.
In General, the device is a good effect from it on me, like from a disk Endorphins, although now its use in complex MM -CONDUCTOR/HEALING + ALTARIA = OBVIOUS.
So if the roof will go just do not tell.
Re: Electrodes
This question to the manufacturer Alfaria on their website.МОЛЧУН wrote:I would Like to Alfario uluchshenii:1. The display output is not just a "dumb" number-level, and the real power will takadama as electronics it is not difficult. But how many advantages: a) you really see how the current flows, b) here the contact is no contact. Removed the subjectivity, it is important not how you "tingle" and the actual current passing through your brain (is that right ?). in)Will see release clips or not. In this case it would be good to make some sort of sound.2. Clip. Fly. Must be wet the Pads came off after four sessions. There is not a bad solution samoupravleniya strips, it is implemented in many devices electro stimulation.
Re: Electrodes
Typically, the TES devices for security purposes stabiliziruemost current, not voltage. Although, what's in Alfarim unknown to me.
Re: Electrodes
Hello, prompt than to moisten the ears to the suction Cup to attach?
and how to moisten these electrode? just under the water to rip them off or something just to wipe? and then after the procedure, as they wipe down dry?
Re: Electrodes
froddo888 wrote:Hello, prompt than to moisten the ears to the suction Cup to attach?
You must soak clips in water ,shake off Lishou water.During the procedure they dry out from the body. You can just leave open to air and they dry out.
Re: Electrodes
ie nothing will happen to them if I fully with these plastmasski in the water they are wet?
shall not close as they say?=)
Re: Electrodes
Hello , I bought alfaria you have a month and a half ago. moistened with water. during those six weeks, I have worn one clip. she wadded the basis of almost otavalos. hence the question, where can I prioreschi of spare clips? or warranty to pass this unit. second question. a month and a half of use, not so often used on the 10th level, you won't feel the tingling of the electrodes. and feeling what is not what it was before. the batteries are changed. one and the same. waiting for an answer Komrad. thank you
Re: Electrodes
Clips are a consumable item ,if not use carefully,together with earlobes,cotton puff come off .You can buy in the office .froddo888 wrote:Hello , I bought alfaria you have a month and a half ago. moistened with water. during those six weeks, I have worn one clip. she wadded the basis of almost otavalos. hence the question, where can I prioreschi of spare clips? or warranty to pass this unit. second question. a month and a half of use, not so often used on the 10th level, you won't feel the tingling of the electrodes. and feeling what is not what it was before. the batteries are changed. one and the same. waiting for an answer Komrad. thank you
