Do not forget to run a clinical trial of your music.Маста Майкс wrote:I'm going to do a modern medical music
It may be that it is not medical...
Sorry slicha not in the subject began. And now the question:Generally speaking such low frequencies could not be transmitted by means of usual autocredit (and perceive with normal ears), that's why they invented this thing with the stereo. Two channel start wave with the difference frequency corresponding to the desired state of consciousness, so for example, if you want to get the THETA rhythm of 5 Hz (fast sleep) - allowed in the left channel, say 400 Hz, and 405 right. Be sure to listen with headphones, otherwise no effect will be! You will feel like the left and right channels converge and diverge in the space of the sound field with a frequency of 5 times per secondThe habit may be a little dizzy behind the wheel not to sit in no case, etc. etc. In General, this case should be treated seriously enough.
And what does help? Take a group of people divide it into two parts. Analyze the state of their health prior to experimentation. Then give One to listen to normal music, others his medical. At the end of the period of time the tests again in both groups. And then simple mathematical calculations reveal the degree of "liczebnosci" your music. In short so.Маста Майкс wrote:Thanks for the advice. I think you, as experts in their field, will help in this.
Please use the Search button in the upper left corner of the page.Маста Майкс wrote:I-Doser works on the same system as BWG, or is there another system?
Have used. Thanks for help )please Use the Search button in the upper left corner of the page.
Well, as said won't help ) but I'm absolutely not good at math, and I believe that this is the work of other people. Simple algorithms acoustics and quintesence can deduct, and the rest of it is all right. Easier money to payTake a group of people divide it into two parts......
What do you mean better? More buzz?Гость wrote:the Machine according to any beam
okay, but how do you explain that some files still have on people effects, and this is clearly not a suggestion, because it is too strong. like we're lying?Джим wrote:2 pred. lent, of course, mine.
Again -- if it be the kind permission of the moderators / admins -- can share short source code of a program, a decryption drg file in the description, the picture and the actual script.
Example script (I think the most expensive session of docere ("Hand of God")):
h5: pink/100 5+.5/95
h1: pink/5 100+1/95
h2: pink/5 200+2/95
h4: pink/5 400+4/95
alloff: -
NOW h5
+00:05:00 h5 ->
+00:06:00 h1
+00:13:00 h1 ->
+00:14:00 h2
+00:22:00 h2 ->
+00:23:00 h4
+00:28:00 h4 ->
+00:30:00 alloff
as you can see, "typical" **not working** Delta тета2 session "backwards". Stimulates cerebral blood flow (if you are very lucky) (According to A. Patrushev), (if not lucky = = -- likely a waste of time and effort listening to models of industrial noise.)
And why did You decide that self-hypnosis should be weak? Some of the autosuggestion exactly die...Anonymous wrote:okay, but how do you explain that some files still have on people effects, and this is clearly not a suggestion, because it is too strong. like we're lying?Джим wrote:2 pred. lent, of course, mine.
h1: pink/5 100+1/95
h2: pink/5 200+2/95
h4: pink/5 400+4/95
alloff: -
NOW h5
+00:05:00 h5 ->
+00:06:00 h1
+00:13:00 h1 ->
+00:14:00 h2
+00:22:00 h2 ->
+00:23:00 h4
+00:28:00 h4 ->
+00:30:00 alloff
I-doser dangerous as you think?Андрей Патрушев wrote:And why did You decide that self-hypnosis should be weak? Some of the autosuggestion exactly die...Anonymous wrote:okay, but how do you explain that some files still have on people effects, and this is clearly not a suggestion, because it is too strong. like we're lying?Джим wrote:2 pred. lent, of course, mine.
h1: pink/5 100+1/95
h2: pink/5 200+2/95
h4: pink/5 400+4/95
alloff: -
NOW h5
+00:05:00 h5 ->
+00:06:00 h1
+00:13:00 h1 ->
+00:14:00 h2
+00:22:00 h2 ->
+00:23:00 h4
+00:28:00 h4 ->
+00:30:00 alloff
as you can see, "typical" **not working** Delta тета2 session "backwards". Stimulates cerebral blood flow (if you are very lucky) (According to A. Patrushev), (if not lucky = = -- likely a waste of time and effort listening to models of industrial noise.)I have already described the mechanism of action: SAUCE (status, environment, setting, witnesses)... Binaural beats provide relaxation and enhance suggestibility, all the rest You do yourself...
I wonder which end You mean?Anonymous wrote:But in greater detail and more scientifically someone might have something to say? Because of all these binaural waves have not been studied, right? You can, any of you can confidently say that all of these experiments with MM, autoserum and other thing 100 percent safe and in the future will not respond broken psyche?
