Could You easily explain in "the usual model of the world" the phenomenon of decline WITH the car in 10 times under the action of Ekonorma and modifying parameters of cells in a few times under the influence of Parlor and other facts presented in the reports on the website. Very interesting.Anonymous wrote:thanks ... but if translated into plain language you are saying that THERE is a PHENOMENON which can NOT EXPLAIN the SCIENCE ? And I am supposed to repeat what they say there is no science of explanation and the fact no ?Андрей Кабанков wrote:Guest
Science is only a model of the world.A lot of models.Most are familiar with the models that describe our daily existence,in a very narrow range of parameters.Models describing the micro world will seem to you just "Miracles".
If existing phenomenon fails to describe the usual models,this does not mean that the phenomenon cannot be.
YOU're CATEGORICALLY not about that !!!!!!! I say that to sum up your research database needs then when there is the phenomenon of and you are just challenging pseudoscientific theories explain what is easily explained in the usual model of the world and most IMPORTANTLY IT CAN be REPEATED .... your hypothesis is how to describe the reason for the bad mood radiation aliens ... also a lot to prove and prove and then to offer a special shield from erchonia the size of a coin and the mood will immediately go up .... escheb such fears saved
Room, Mirror
In the usual model of the world and my including no conceptual framework describing these processes.
ASD wrote that ekonorm can be considered as an external catalyst for the process of combustion.
I understand these facts as the effect of the interaction of informational structures ,the manifestation of which in our four-dimensional world is matter and energy ,with devices LIK.
Information structure and their interaction in familiar ,everyday models of the world are not described.
And that thinner mirrors do not fit?АСД wrote:Labels will be placed vertically along the Central axis of the mirror approximately at the level of the person. The thickness of the mirror glass needs to be 4-5 mm.Андрей Кабанков wrote:has anyone sekkala On the reverse side paste these two structures at a distance of 15 cm,look not in them,and in the mirror.
Just want to know, you need to maintain between labels 15cm or not?
And yet,the shiny foil on the labels of the "Mirror of ISIS" is to protect the adhesive layer?
The thickness of the glass depends on the efficiency of the mirror. Glass is created at the structural level, the optically active environment that enables the reversal of the wave front for the light coming from the human eye. The thinner the glass, the less the vibrational spectroscopy of light with the environment. Therefore, the use of mirrors with glass thickness less than 4 mm is possible, but not advisable.
The distance between the centers of the labels can vary from 5 to 15 centimeters without derating. Plan to launch labels in a single card measuring 90 by 50 mm.
Foil is not a working structure. It protects the working structure from damage.
Depends what task You decide. If the task of organizing collective interaction of family members, let them all look. If the task is tune of their own ancestral lines, restore a personal sense of way and design their own future, it is best to have individual mirror.МерКаБа wrote:ASD,
Please tell me, in the mirror you can see all family members? If not adjusted a mirror in a certain vibration of one man?
Солнышко :-)
Солнышко :-)
Or maybe it's just an ordinary mirror? And how many eyes not proglyadyval nothing new to see?Солнышко :-) wrote:Logik
Maybe it will take time to see the result. And can it is necessary somehow especially it ( with a mirror) to work , specifically to set some goals and look in the mirror. Believe that You are still ahead. I don't have a mirror.
You don't have a mirror? I think you mean that which is "miraculous" and not the mirror at all. If I'm right then you have not completely lost and can still improve! Don't waste time and money on miracles to solve! Even the author, apparently, doesn't know how it works!
The inventor himself can not clearly describe the principles of construction and operation of its wireless!
Dear ASD If You are sharlotan, go to my topic "Chamber! The doubts and reflections!" and answer my questions! The absence of You in my subject will be regarded as unwillingness and disregard for the customers, or Your inconsistency and misunderstanding of the principle designs and your inventions!
(Anyone not want to offend you, me trying to get light of knowledge and receive information without the cost here and now)
Well, a month passed, and no special experience.Жека3000 wrote:it's been a month! Please share your impressions!
If younger, then very little. I, outwardly, not much.
Gave view 70. and give.
Of course, if you shave, get a haircut, change a worn denim jacket for a leather....
Well, not that-I hadn't felt anything...Жека3000 wrote:Logik
Interesting! Apparently here in the forum I'm not one to feel subtle energy.
Sit in front of the mirror and after about five minutes, all the muscles relax (especially the hands). There is a feeling that some Energeticheskiy exchange goes. Sometimes looking in the mirror is very invigorating.
But the rejuvenating effect...
I have after 5 days of fasting, the wrinkles have almost disappeared (but then reappeared). After a month of looking in the mirror, I do not see such a clear effect.
Logik
Well if You were younger as in advertising the Vichy cream - it would be a miracle!:) Reduction of the biological age seems to me not so clearly seen.
You're not for this, I bought a mirror?
For me, a valuable feature is the cut off generic bindings(negative). With that you have something changed? Any changes in life? Maybe more energy, more won opportunities or something else?
In General, the description of the mirror is a direct contradiction of transerfinga, etc. exercise!
Karma and fate is that some of the religions! Maybe it is written just for better understanding and no more? Or is it still written with an investment of meaning?
