Борис.И - Posts:2
Post
by Борис.И » Mon May 04, 2009 22:01
Used modulators another lab(I will not advertise). Checked the results on the diagnostic complex of AMSAT. The three of us got tested before using the modulator, and then the two of us put the modulators and tested again. Overall health was improved obviously and without doubt. But the third who did not experience device, as after the re-diagnosis has clearly deteriorated. That is, we prevenirii. I suggest to you an experiment to do. I used this modulator and then a couple of years, and in my opinion relationships with people have become synthetic, cold. Subconsciously, people understand that something is wrong.
Арчи
Post
by Арчи » Mon May 04, 2009 22:25
Boris.And
Want to say that the chamber takes the energy of other people ? As the authors can comment on this ?
Post
by Dimas » Mon May 04, 2009 23:09
Archie
Like the author wrote the use of modulators of OTHER laboratories
I have improved relationships with loved ones,as if everything is drawn to me,even those who previously were at best neutral.
Борис.И - Posts:2
Post
by Борис.И » Mon May 04, 2009 23:17
Арчи wrote:Boris.And
I described my experience of using bioresonance modulator subtle field of a person is another developer. About the chamber can not say anything. You can spend the same experience and test chamber.
Новик
Post
by Новик » Tue May 05, 2009 10:10
Boris.And
Well, you at least write his name(modulator), the link is not necessarily....
Themselves in Neti find
And Yes, I thought about it, where the modulators take the energy??? well there is to recovery tools, benefits, etc.
Ибн Дауд
Post
by Ибн Дауд » Tue May 05, 2009 13:02
What is vertical axis? What is the unit of measure? What made the photo?
Post
by Dimas » Tue May 05, 2009 15:11
Ibn Daud
Photos taken using compact GDV (Kirlian technique).About the axis, and units of measurement can not say yet,how will we-share)
Post
by Dimas » Tue May 12, 2009 15:46
removed today I went into work.Let's just say,the glow is quite different than it was before they started to wear Swietlicki.To increase you need to click on the image.
Other guys too "removed",but without their permission I can not put.
Гостья
Post
by Гостья » Tue May 12, 2009 22:41
Dimas wrote:took off today,as I came to work.Let's just say,the glow is quite different than it was before they started to wear Swietlicki.To increase you need to click on the image.
Please explain what these two charts.
Can I see Your previous results to assess the dynamics ?
Post
by Dimas » Tue May 12, 2009 23:32
Гостья wrote:Dimas wrote:took off today,as I came to work.Let's just say,the glow is quite different than it was before they started to wear Swietlicki.To increase you need to click on the image.
Yes, of course,you can see the pictures in the first message of this topic.The field has changed visually at least...Noticeable compaction and no breakouts.
Гостья
Post
by Гостья » Tue May 12, 2009 23:39
Please tell me what the corresponding upper and lower similar graphs (to the right of the figures sitting in the Lotus position man) ? They are one and the same time and are, so to speak, for the emotional and physical manifestations ?
Post
by Dimas » Tue May 12, 2009 23:46
Гостья wrote:Dimas
Yes,quite right,it is the interpretation of the same picture in emotional and physical aspect.
Карил
Post
by Карил » Wed May 13, 2009 11:14
Dimas wrote:the Other guys too "removed",but without their permission I can not put.
And I wonder why they are against or the results suck, and have something to hide?
Especially I would like to see the auras of Andrey and Vladislav...
Post
by Dimas » Wed May 13, 2009 11:57
Carilo
Vice versa is great.Who said that they are against?Can't without their knowledge,as it is not culturally so to speak
Vladislav there is generally a plague,did not expect.And Andrei and Marina there,they are on a month to the States went off,so I didn't take a picture
Карил
Post
by Карил » Wed May 13, 2009 13:03
Duc super well, what are you waiting for? Photography in the Studio and in the journal on the front page.
I understand that after two weeks of wearing bright-rooms measurement?
Карил
Post
by Карил » Wed May 13, 2009 14:14
One man sure enough, but it looks like habituation to the chamber-with no.
The pattern is very similar to the first measurement after the chamber. A failure on the right foot after cigarettes, just like the demos. I wonder where cigarettes such a dislike to the lower extremities.
Идущая вперед - Posts:722
Post
by Идущая вперед » Wed May 13, 2009 16:06
but on the pictures you can see that chakras are shifted - they are in the middle of the axis should be... and how exciting to move to the center???
I'm 19 days finally and I can't wait to programignorelist.
Мирта
Post
by Мирта » Wed May 13, 2009 21:09
Карил wrote: I Wonder where cigarettes such a dislike to the lower extremities.
Smokers are one of the typical problems - obliterating endarteritis of lower extremities vessels, so all is in topic:ay
Карил
Post
by Карил » Wed May 13, 2009 21:41
Myrtle
It turns out that the auras on GDV picture in some degree still shows the real situation. Remove the glow from the fingers (sort of), and not the body or legs there for example.
Мирта
Post
by Мирта » Wed May 13, 2009 21:54
Карил wrote:Mirta
While I am inclined to think so, although the founders of this project, wrote that in the diagnosis of internal diseases the technology is still weak and buggy, which was a pity. And the "aura" you can endlessly speculate without confirmation by modern analytical methods.
Алексей C
Post
by Алексей C » Thu May 14, 2009 0:08
A photo with the window and without
Алексей C on Thu May 14, 2009 11:24, edited 1 time in total.
