For what?:)Пророк wrote:What mode is better to use points, ColorTraсk or colored if colored, what color?
A couple of questions on mind machines
АлексЗетейч
Good day!
Acquired Inner Pulse, tell me how to find out what the capacity of the battery or battery ends?
My last session in the middle of the disc "Healing" is missing the display in the glasses.
Assume that indicator are synchronously blinking dots that appear when a display session, for example, instead of AuS shows A. u.S. right?
AlexZh
AlexZh
True.АлексЗетейч wrote:Good day!
AlexZh
Недоушелец
Sorry Gator,but I'm confused a little. Rule 15/21 day and then break..
1) Break all around,and in MM and wheels Andrew?
2)Break in the discs and MM, you can listen without interruption?
and one more question, if the alpha-UTB drive Healing, and recommend starting with alpha, and also, sometimes, Andrea advises to start with a Guide?
1. Break one thing. The break is associated on the one hand with adaptation (efficiency drops), the other - with the necessity of building your own rhythms.Недоушелец wrote:Sorry Gator,but I'm confused a little. Rule 15/21 day and then break..
2. Break not with disks, and disk. Have mindmachine, if you change the session, then a break can do.
3. The conductor acts on the other (philosophical) level.
Недоушелец
Andrew,thank you very muchАндрей Патрушев wrote:1. Break one thing. The break is associated on the one hand with adaptation (efficiency drops), the other - with the necessity of building your own rhythms.Недоушелец wrote:Sorry Gator,but I'm confused a little. Rule 15/21 day and then break..
Plus,like You said, is the place to be individual characteristics, etc., etc
yesterday, listening to Theta-OS, a super easy,relaxed,saw a lot of dreams and well-rested,the body is very pretty))
Серёга
Hello!Серёга wrote:Andrey,Hello! Bought an Inner Pulse and drive two of your "Star traveler" and "Endorphins"
1.Is it possible in one day (with a break separately of course) to use any session out of the car and drives?
2.What are your drives (not just these two) have audiostrobe?
1. You can break 2.5-3 hours.
2. Star traveler - without audiostrobe. With another gate Conductor, Healing and Music for self-hypnosis.
Серёга
Just reread an old post and was touched:
In General, speech support sessions-something extremely important but I would, at least, would strongly recommend never using any hood. literature. And meaningful music, way too. - Especially valuable to you.
I am writing this, because it is not that a common mistake of beginners, but, nevertheless, in my practice of the popularization of technology met...
I would even categorically told -- +-3 hour session (regardless of its frequency profile) don't need to read something serious (and mostly, anything that causes your emotions -- here is a tutorial on the Mat. analysis, or, for example, a tutorial in German -- is not only possible, but necessary
About any audio -- not sure. Taking, as an extremely negative example, the audio netlenki Franz Kafka's "the trial" (by Chapter, for example) - can significantly complicate your own life...Андрей Патрушев wrote:Anonymous wrote(a):
And a few more questions
Can I apply to the session recording of the speech?
If sessions, Nova Pro 100 to InnerPulse, and if appropriate, where to get them separately?
Can any audio recording.
Suitable after simple transformation (to upload into the editor and resave it).
Хорека
