Around and about - useful "side" of the phenomenon
Василиса
Post by Василиса » Thu Aug 07, 2008 20:01
And I courses for operators working with DENAS explained that in case of thrombophlebitis also can not treat the area below the clot will not come off and not occlude the vessel. but there is hidden blood clots. isn't it contraindications?
And why in Your statements manifested aggressiveness, dear FDES. I wrote that every good your product is, and what I forgot in the medical register? Do not be angry, and DENAS good and pianacci, and much more.... :)
Фденс
Post by Фденс » Thu Aug 07, 2008 21:51
SW. Vasilisa, no offense , but that is a nodding acquaintance with the work of this equipment confirms: at the beginning there is INSTRUCTION and only then - action.
When working with thrombophlebitis it is impossible to move the apparatus, and can be trimmed.
We do not understand the subject of the dispute : it about something else - about the interaction techniques and if there are any developments we would be very grateful. az
Post by Андрей Патрушев » Fri Feb 06, 2009 16:22
Glowing glasses will restore biorhythms
To overcome the problem of sharp change of time zones when you travel long distances to help special luminous points, which, according to creators, "transfer direction" of the internal clock of a person. In these glasses there are LEDs that emit blue and green light, which helps the brain to adapt to the need to sleep and Wake up at a different time.
This device was created by researchers from the Flinders University in Adelaide under the leadership of Lejon Lacquer (Leon Lack). "Bright light is the tool which adjusts the clock in our body," explains the researcher. He said that his invention should be put into three hours over two days before the flight and for three hours during the flight.
As found by the correspondent of the newspaper the Daily Mail, in the frame of regular sunglasses built LEDs, and are powered by batteries in his pocket. Emitted by the led light influences the secretion of certain hormones, what causes the adaptation of the human body to the violation of the usual daily cycle of day and night.
It is reported that the invention, allowing to solve the difficulties associated with the rapid change of time zones are already interested in Australian athletes who have to travel considerable distances to participate in international competitions. According to David Pyne (David Pyne) from the Australian Institute of sport, the glasses could afford to start training on the first day.
Source Mednovosti.ru - 30.07.02
LEDs will save you from losing your vision
LEDs will save from the consequences of poisoning with poor-quality alcohol. As for American scientists in experiments on laboratory rats in which with methyl alcohol caused the defeat of the retina and optic nerve, their light has a therapeutic effect, helps to restore the affected tissues and prevents the onset of blindness.
This study was conducted under the direction of Dr. Harry Whelan (Harry Whelan) from the medical College of Wisconsin in Milwaukee. Within three days his eyes had been blinded by alcohol, rats were exposed to LEDs. As a result, the animals ' vision was restored to 95 percent. They have also not detected any changes in the retina.
As explained by Dr. Whelan in interview to magazine New Scientist, lighting stimulated the regeneration of tissues and neurons. Without it, rats become permanently blind within two days. Laser-like powerful LEDs, which were originally developed by NASA experts, can find wide application in medicine.
As explained by the authors of the study, its results can help not only the poisoning of low-quality alcoholic drinks containing methanol, but in other cases where there is a risk of abrupt loss of vision, and when you lose sight of the bright light. While research is at an early stage, and to establish specific mechanisms of therapeutic action of light yet.
Even before the scientists proved that the use of LEDs may be useful in the treatment of one of the complications of cancer chemotherapy - mucositis, which is accompanied by formation of painful ulcers in the mouth and throat. Management of food and medicines USA sanctioned the continuation of clinical trials of LEDs for these purposes.
The results of the research actions led to the threat of blindness will be published in the journal Proceedings of the National Academy of Sciences.
Source lenta.ru - 11.07.02<
мим
Post by мим » Tue Mar 10, 2009 12:05
Listening about the DETA-15 cures all diseases of the electromagnetic field. The frequencies are the same as with the MM fully. IF you WIND the COIL AND connect to the MM wakes is therapeutic effect???
Post by Андрей Патрушев » Tue Mar 10, 2009 19:59
мим wrote:heard about the DETA-15 cures all diseases of the electromagnetic field. The frequencies are the same as with the MM fully. IF you WIND the COIL AND connect to the MM wakes is therapeutic effect???
Will, but the power is too small.
ТЕД77
Re: around and Around - useful "side" of the phenomenon
Post by ТЕД77 » Thu Mar 12, 2009 0:07
Андрей Патрушев wrote:....on the basis of a new perspective method of influence on the tissues of the body scattered rays of visible red and invisible infrared light...
Actually, any red led also emits in the infrared range, and very well. This is due to the production technology, where the proportion of impurities in the crystal define the width of the radiated range. The purest crystals of lasers, because the radiation is coherent. So this "dune-T" IMHO, are common red LEDs, and therefore, innerasia glasses no worse. The main thing to know is where to apply.... :)
Post by Андрей Патрушев » Sun Oct 11, 2009 13:09
The ADD/ADHD Revolution: Treatments that work by LaVonne Kirkpatrick, Ed.D & Rick Kirkpatrick, L. C. S. W; 2005, 226p; iUniverse, Inc. New York Lincoln Shanghai (www.iuniverse.com) ISBN-13:978-0-595-36935-5 (pbk)This book, which says that AVS and binaural beats today are one of the most effective means for the treatment of attention deficit disorder (with and without hyperactivity).
Александр86
Post by Александр86 » Sun Oct 11, 2009 13:39
http://www.duna-t.ru/naznacheniye.htm
It's this camera ? Can buy ? And then I have white glasses, they don't fit ?
Александр86
Post by Александр86 » Sun Oct 11, 2009 13:40
Damn, I your website killer be ... :evil:
Александр86
Post by Александр86 » Mon Oct 12, 2009 14:21
That's what I has found, like this unit :
http://www.scarlett.ru/production/healt ... l?lang=rus
for several years is :) it turns out this massager + there's just red diodes built-in.
Or it must be a special bulb?
Семен
Post by Семен » Tue Nov 17, 2009 0:42
Skeptical to all sorts of devices to influence the health of the organism , and especially any correction. Used Vitafon - the principle of course quite different, but the essence does not change. In my experience once again convinced that the main thing - faith. The emotional state and the development of his abilities also largely depends on the personality. By the way no one gave a clear explanation to many phenomena of self-healing. Example: removing completely Yachmenev a simple bottle of beer, but for some reason only the old Soviet production, regardless of color and will notice these that is definitely not to cure, but only to open; cure chronic pain from sprain, dislocation of joints only red thread wrapped around the patient's joint, and only after the thread is broken itself; the removal of headaches by applying a silver coin. And more regardless of whether the individual believes or not. The human soul can do much more.
Колисто
Post by Колисто » Tue Nov 17, 2009 0:45
It's all just one sentence is called the Placebo effect.
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Mon Dec 07, 2009 20:35
About heart failure as a result of application of DENAS was applied for by a competent conclusion to the head. our Department - that is also first hand....
and what is the competent conclusion of the head.of your Department?
Post by Нетрезвый Сурдопереводчик » Mon Dec 07, 2009 20:36
Колисто wrote:It's all just one sentence is called the Placebo effect.
by the way,very effective and the effect(sorry for eugenics).works flawlessly. az az az
Post by Андрей Патрушев » Tue Dec 08, 2009 19:29
It happens that the parameters of the signal randomly coincide with those for body and El.signal pounding the pacemaker... not only stopping the heart but also other violations.
By the way, a recent conference Denisov in Ekaterinburg there have been several reports of cardiac arrest...
Post by Андрей Патрушев » Tue Dec 08, 2009 19:32
In one place You write that it is "auditory training," another "placebo"... You really like something, you decide :) Or You are one and the same? :roll:
Post by Нетрезвый Сурдопереводчик » Tue Dec 08, 2009 22:07
Андрей Патрушев wrote: It happens that the parameters of the signal randomly coincide with those for body and El.signal pounding the pacemaker... not only stopping the heart but also other violations.
it is clear,then,to determine in advance the coincidence signal and the pacemaker does,empirically,on the patient--not something I want...I wanted to use a variation of the device,intended for the treatment of cervical degenerative disc disease..
Дмитрий1
Post by Дмитрий1 » Tue Jan 05, 2010 12:54
Why, metal rims more like in the 17th century Bernard invented, so putting the coins in the usual galvanization
Post by Андрей Патрушев » Fri Jun 03, 2011 17:10
http://www.dankon.ru/lib20.htm
LEDS, AND HUMAN HEALTH
The LEDs will help to keep the skin in excellent condition.
German scientists found that intense visible light emitted by the LEDs can smooth wrinkles and improve skin elasticity.
About the therapeutic effects of radiation in the visible spectrum emitted by LEDs known for a long time - for example, it for a long time used to accelerate the healing of wounds. However, until now the mechanisms of this effect of light was unknown.
Researchers from Germany Andrei Sommer (Andrei P. Sommer) and a Tribute to Zhu (Zhu Dan) found that when exposed to intense light sources of led lighting every day for a few weeks, the skin becomes more elastic and younger looking, the complexion is improved and the wrinkle depth is considerably reduced.
Scientists also found molecular basis of this light. The molecules of protein elastin that forms the elastic framework of the skin can gidratirovana - covered with a "film" of water molecules. Hydrated elastin fibers partially lose their elasticity which leads to decreased elasticity of the skin. It turned out that visible light of high intensity emitted by the LEDs, penetrates into the thick skin and gradually cleaves the water from elastin fibers, restoring skin elasticity.
The researchers believe that their finding could be the basis for new and effective rejuvenation programs. In General, it should be noted that until now, neither a medical institution nor only not proven, but not found any one reason for the negative effect of led lighting on health of living organisms.
LEDs will save you from losing your vision.
LEDs will save from the consequences of poisoning with poor-quality alcohol. As for American scientists in experiments on laboratory rats in which with methyl alcohol caused the defeat of the retina and optic nerve, their light (the visible spectrum emitted by the LEDs) has a therapeutic effect, helps to restore the affected tissues and prevents the onset of blindness.
As explained by Dr. Whelan, in an interview with correspondents of the magazine "New Scientist", the light stimulated the regeneration of tissues and neurons. Without it, rats become permanently blind within two days. Laser-like powerful LEDs, which were originally developed by NASA experts, can find wide application in medicine.
The results of the research actions led to the threat of blindness will be published in the journal Proceedings of the National Academy of Sciences.<
Post by Андрей Патрушев » Tue May 08, 2018 19:03
Non-invasive magnetic brain stimulation has been used for the successful disposal of patients with resistant depression dealing with suicidal thoughts. The researchers stimulated the dorsolateral part of the prefrontal cortex — the area of the brain responsible for control over many Executive functions, including working memory and decision-making. In addition to suicidal tendencies, the procedure has helped to reduce the severity of symptoms in General.
Ростислав
Has thanked: 35 times
Been thanked: 28 times
Post by Ростислав » Wed May 09, 2018 21:40
Victory Day friends! :D
