if necessary lay out.
there are interesting prog but no crackswho doesn't Have oscila tank here http://xgurux.ucoz.ru/tester.rar
as will picks open lay out with a Paci.
R. S. guest I
Why to complicate your life? before the LM567 decoders to drive the RF filter on OU.I was thinking about it. In any modern computer has a sound card with multiple channels of audio output. If You have a burning desire to collect AudioStrobe decoder, why not output sound and AudioStrobe signal through separate outputs of the sound card. Enough to dig online and find many sound editors and multi-channel mixers, allowing to create the necessary number of audio tracks. Now, taking any AudioStrobe disk, you can save it as two files, one original and the other with the cut-off frequencies up to 19200 Hz. Then send the audio from these files on two independent channels. To the channel, reproducing the AudioStrobe signal, you can connect a simple device (even simpler than the decoder LM567), consisting of a RF detector diode, a transistor operating in key mode, and several parts (like a simple light setup). By the way, somewhere around the circuit on optocouplers enable you to control the brightness of the LEDs depending on the output level. Who should - share.
Good luck!
You want to say can be written and sine and square wave, and triangular wave visual stimulati? At LMa in the scheme of MDM is said all the time, use a digital output. Is always a square wave.Андрей Патрушев wrote:In normal strb-decoder signal points served depending on the disc signal.Тасев Александр wrote:I thought that there must be two flashes: "soft" sinusoidal "hard" rectangular. Like all mindmachine...
