Structured water
Good luck!И-Ван wrote:Andrew, thanks for the reply. Seen in the sale of such alkali, but for some reason she was in solid form, such 5 mm tapered Sparky.
what you need.
Buy a plastic mask to protect the face and gloves.
a must!
Andrew, but if water with a pH of 10-11 units?
Too slow.
Today come try.
Andrew was recently in a fan of home theater. Myself am a TV and movie cool, in a General way. All as usual: projector, good acoustics, but he still has some ustroystvo through which are driven two iron pieces, on which are placed the rear legs of the couch sitting where watching a movie. Two devices simultaneously with different frequency and strength physically reproduce low frequency audio path of the receiver. If the car goes through potholes, the sofa and jumps almost as well.
The next day I cut the disk a clean sine wave with a frequency of from 1 Hz to 15 Hz in increments of 1 Hz from 15 to 25 with step of 5 Hz, etc. up to 400 Hz.
To the surprise of all plays 1 Hz. The force of the blow on the sofa is adjustable from minimal to weak.
At BWG I recorded a gradual increase of frequency from 5 to 10 Hz. Gradual increase also plays.
What is the difference if I lie on this couch and this device works and I whole body perceive the frequency of 6 Hz at a comfortable force of the blow or I lie there and just listen with headphones those 6 Hz 106 Hz minus 100 Hz without this thing. In my opinion the difference should be. Different physics and frequency is formed by the subtraction of frequencies, and real.
So, Andrew, opinion?
Cool, of course, and promotes relaxation, but in terms of "repetition frequency" vibration is not working. Optimally 170-180Гц for relaxation hard to not get carried away - maybe back specifically to take.И-Ван wrote:Andrew, was recently the guest of the fan of home theater. Myself am a TV and movie cool, in a General way. All as usual: projector, good acoustics, but he still has some ustroystvo through which are driven two iron pieces, on which are placed the rear legs of the couch sitting where watching a movie. Two devices simultaneously with different frequency and strength physically reproduce low frequency audio path of the receiver. If the car goes through potholes, the sofa and jumps almost as well.
Andrei Patrushev
can you comment on this :
"Such education clusters — do not give rest to researchers. They took a question: is it possible to use water to store information? Bits and bytes could correspond to separate clusters. So is the water, like a ferromagnetic layer on the tape cassettes, can store, for example, said? And maybe we will learn to read from the tape water news of bygone times?
Questions follow questions, one weirder than the other. Water has a memory? And maybe soul? What if all our feelings, all the experience accumulated in the water? So the nice people? Listens to the music of Mozart and Chopin?
However, there is an immutable law: any media needs a long time to be in at least two different stable States. In this case, we can encode information in binary system. For example, a semiconductor transistor, or a current flows or not flows.
That's how it mess with the cluster? Hydrogen bonds are unstable; at room temperature, they instantly drop to immediately — from one water molecule to another to spread the new bridge. The question is how unstable these connections.
The phenomenon of "water memory" are interested in even the editors of the authoritative journal "Nature". On its pages was a published report about an experiment conducted by the staff of the University of Toronto and Institute named after max born in Berlin. It showed that water is one of the most "forgetful" substances in the world.
In this experiment, it was directed by T. elzesser and D. Miller were generated vibrations of the atoms comprising a molecule of water. However, after 50 femtoseconds oscillations were damped (1 femtosecond = 10-15 seconds). Obviously, the reason was the weakness of the hydrogen bridges, which allow water molecules to rotate, to tilt, to tip over. In formed they network constantly, there were fluctuations, but because the water instantly forgot their previous structure for the same 50 femtoseconds of her had not disappeared.
The water is simply no time to get something to remember. Its structure resembles the least stable. It is as difficult to guess some kind of order, like ripples in flashing on the waves, to recognize the world map, or in the eternal game of clouds to see a prototype. Everything that is written on the water, up in the air. If you want to store the information of a few femtoseconds, you can burn it to a new and exotic media — a bottle of water. Another trillionth of a second — and your record is hopelessly outdated. "
full article here http://www.inauka.ru/prognoz/article81424.html<
Pseudo-scientific set of words. Even given the fact that it was written by a reporter and actually meant something else, the experiment is not at all about this...In this experiment — it was directed by T. elzesser and D. Miller were generated vibrations of the atoms comprising a molecule of water. However, after 50 femtoseconds oscillations were damped (1 femtosecond = 10-15 seconds). Obviously, the reason was the weakness of the hydrogen bridges, which allow water molecules to rotate, to tilt, to tip over. In formed they network constantly, there were fluctuations, but because the water instantly forgot their previous structure for the same 50 femtoseconds of her had not disappeared.
The cluster is fairly stable. There is a volume effect. For example, a 0.5 liter bottle, the memory effect takes place for two hours and 40 liters for about a week... of Course, we are not talking about recording some kind of information, like the movie, but the biological value varies. Water with a high degree of polarization of the molecules and, therefore, the cluster promotes the synthesis of proteins more dense with less energy consumption for the body.
- Князевский
Андрей Патрушев wrote:Pseudo-scientific set of words. Even given the fact that it was written by a reporter and actually meant something else, the experiment is not at all about this...In this experiment — it was directed by T. elzesser and D. Miller were generated vibrations of the atoms comprising a molecule of water. However, after 50 femtoseconds oscillations were damped (1 femtosecond = 10-15 seconds). Obviously, the reason was the weakness of the hydrogen bridges, which allow water molecules to rotate, to tilt, to tip over. In formed they network constantly, there were fluctuations, but because the water instantly forgot their previous structure for the same 50 femtoseconds of her had not disappeared.
on the border of what discoveries we are!
Seen in the sale of so-called Aqua disk (wooden disk, with a diameter of 10-15 cm, height 1.5-2cm ) fragrant pine needles and bee products. Information on their website. How to use: Put on disk pitcher ( supplied ), water is stirred with a wooden stick counterclockwise 1 min. Left 6 hours. All ready. Read somewhere review: the Water spoiled with consistent and predictable results ( Apparently fell into the water, blue-green algae on the walls and a film was formed from the slime in aquarium ). Inside is enshrined in a solid mass, again products from the forest for beekeeping, spring is in the form of a solenoid on a broad base, tapering to a pyramidal top ). Apparently the spring was somehow charged. How to check efficiency in the home, no one knows. Service life of 5 years. All this is doubtful...
Myself used electric filter production NPO Screen, with the stated miraculous properties of water at the exit: it's about the antioxidant properties of water with a modified potential:
Appliances installation EMERALD for cleaning and conditioning the water are commercially available JSC “NPO “the SCREEN” in 1990. Install EMERALD are unique and have no analogues. The main element of the plants are electrochemical reactors of the patented diaphragm flow-through electrochemical modular elements PEM-3.
Install EMERALD are fundamentally different from all installations for water purification the following:
the water treatment processes carried out at the expense of oxidation and reduction reactions occurring in the selection of electrons from the water or entering of electrons in water in a flow electrochemical cell of PEM-3;
give the water a physiologically functional properties that have a beneficial effect on the entire body;
purify the water from pathogens of all kinds and shapes;
purify the water from microbial toxins;
in IZUMRUD not accumulate and does not breed microbes;
purify water from heavy metal ions;
purify the water from harmful organic compounds;
the basic elements of plants, which occur oxidation and reduction reactions, have unlimited resource and do not require replacement;
Currently developed and will be released soon in serial production install EMERALD new generation model 2006 under the trading names of EMERALD-M1, EMERALD-EMERALD-K1 and-K1-A.
In IZUMRUD new generation eliminated the only disadvantage of previous installations - there is no smell of oxidants while preserving all unique properties of the treated plants EMERALD water. The appearance of IZUMRUD models 2006 became possible due to significant improvements of the installations – diaphragm flow-through electrochemical modular elements PEM-3.
Install EMERALD produced commercially since 2006, only two companies in the world: the limited liability company “Laboratory of Electrotechnology” and the division of electrochemical medical equipment open joint-stock company “NPO “the SCREEN” and distributed through authorized representatives of the manufacturer. To authenticate the installation of EMERALD (there are fake units, manufactured, for example, the St. Petersburg company EMERALD), as well as to verify the credentials of the representative of the manufacturer, can be accomplished by visiting the sites http://www.vbinstitute.ru and http://www.npoekran.ru or contact by phone (495) 683-9748 and (495) 187-3146.
The principle of operation
Install EMERALD models 2006 EMERALD-M1, EMERALD-and EMERALD K1-K1-A different hydraulic schemes for purification and conditioning of water.
All patented technological processes of water purification in the IZUMRUD aimed at water purification from microorganisms of all types and forms, microbial toxins, heavy metal ions and harmful organic compounds, and giving the water a physiologically functional properties.
In every technological process of water purification in any of the modifications of IZUMRUD models 2006 included the following mandatory (base) sequence of the technological processes of purification:
Water treatment in the anode chamber of the electrochemical reactor for the destruction of microorganisms and microbial toxins, oxidative degradation of organic compounds, giving the water properties of the active oxygen carrier.
The separation in the flotation reactor parts are anodic treated water with koagulyatsii particles of organic material adhering to the bubbles of oxygen or ozone. Flotation reactor performs the function not only of the separator for separating koagulirovat organic particles, but the mixing reactor, where the slowing water flow and a corresponding increase in the exposure time of the highly reactive oxidant formed during anodic treatment of the water with microorganisms and microbial toxins.
Treatment of water in a catalytic reactor with the objective of making possible a small amount of chlorine-containing oxidizing agents formed during the anodic treatment of water, into peroxides and hydroperoxides.
Water treatment in a cathode chamber of the electrochemical reactor in order to convert the heavy metal ions into insoluble hydroxides and give the water antioxidant properties. In IZUMRUD-M1, EMERALD-and EMERALD K1-K1-A is made cathodic treatment of a smaller volume of water than anodic treatment. This allows for more complete conversion of heavy metal ions into insoluble hydroxides, and also provides a more significant change in the redox potential of water to enhance the antioxidant properties.
The removal of hydroxides of heavy metals in the external removable cartridge the filter. This cartridge filter makes it easy to detain the insoluble particles of hydroxides of heavy metals and salts, which ensures the transparency of the water and ensures no sediment. In this case the filter material no microorganisms, and filtration takes place in conditions conducive to the increased yield.
Purified water
There is a misconception, if household water purifier should remove from the water all. Similar installations exist. But they remove the essential minerals for the body, deficiency of which can not be replenished by eating. Long-term use of filtered demineralized water with properties similar to distilled, can cause disturbances in the body's water-mineral metabolism and other complications. In addition, a mechanical filter and a sorption device does not produce antioxidant water.
As you know, spring water is filtered through layers of mountain and sedimentary rocks, where they are enriched by biomicroelements and exposed taurichesky currents also cause the weak effect of electrochemical activation. In plants “Emerald” electrochemical activation of water is manifested to a greater extent.
Installation for treatment and conditioning of water EMERALD give the water a physiologically functional properties that have a beneficial effect on the body by use of water in the composition of the usual diet.
In IZUMRUD main processes are oxidation-reduction reactions in an inert (exchange with purified water only electrons) the electrodes. On a spectrum of numerous physico-chemical reactions occurring in IZUMRUD, they are as close to natural processes of water purification in nature, as well as to reactions of phagocytosis in the body of warm-blooded animals and humans in the destruction of microorganisms and foreign substances.
Also have no analogues in the known schemes of water purification processes of structural change of water, the process of giving water the properties of an electron donor, an antioxidant with hidden properties of the electron acceptor (active oxygen carrier). These processes can take place only in water treatment in a compact diaphragm flow-through electrochemical modular elements PEM-3. Antioxidant properties of water appear within 3 days from the time of processing. Water molecules from IZUMRUD to form associates (clusters) is optimal in size and biological activity. One cluster “emerald” water consists of 5 to 7 molecules of H2O, while clusters stale (“stale”) of water containing 20 molecules, and decomposed, an unpleasant taste the water does not have a clustered structure.
“Emerald” antioxidant water protects the body from the action of a strong toxic oxidizing agents (derivatives of isoprene). Water from the IZUMRUD reports the protective antioxidant properties of the internal environment of the organism and thus provides protection against toxic oxidants not only in water but also in air, in food, and also reduces the effect of ionizing radiation (radioprotective effect inherent to antioxidant drinks). Antioxidant water improves passive immunity and General state of the organism.
Install EMERALD purify the treated water from micro-organisms of all types and forms, microbial toxins, heavy metal ions and harmful organic compounds. This is achieved in that in the process of anodic oxidation reactions in microorganisms, microbial toxins and organic compounds (herbicides, pesticides, phenols) are destroyed. Heavy metal ions are converted into insoluble hydroxides at the cathode result of the recovery and then removed with the help of additional devices in the flotation and electrokinetic reactor or other filters.
Water treated in IZUMRUD, meets the requirements of hygienic standards. It retains the necessary for the body useful trace elements: potassium, sodium, calcium, magnesium, lithium, fluorine, iodine and others.
When boiled in water treated in IZUMRUD, might further deposition of hardness salts (scale), that it is safe for the body and an additional factor of water purification from excessive stiffness. In case of accidental ingestion of salt scale did not dissolve in gastric juice, and are associated (adsorbed) on protein compounds and excreted from the gastrointestinal tract in a natural way.
Installation of the EMERALD high performance. They allow a few minutes to sufficient water for consumption within 1 – 2 days. To store such water in glass lined containers or containers made of glass. Long-term storage “emerald” waters, if once in 1-2 days, you can get a fresh batch, does not make sense.
So, used top-end ( now discontinued ) model Diamond, after contact with purified water ( 1.5-2 liters per day ) I and my household was covered by the erosion of the back of the tongue. Took this unit to the manufacturer. To the credit of the manufacturer, after explanation, a shrug, and at the same time revealing to me the machine, checking the water some sort of potentiometer ( which is somewhat overwhelming. As I explained it is very desirable, and I say, incredibly lucky..., taste and noting the somewhat unusual taste, returned the money in full.
PS have Business with by the manufacturer!
Maybe still two reactors is a bit much, but the idea of really like...
Purified water
- Князевский
Can you recommend a device for structuring water?Андрей Патрушев wrote:Pseudo-scientific set of words. Even given the fact that it was written by a reporter and actually meant something else, the experiment is not at all about this...In this experiment — it was directed by T. elzesser and D. Miller were generated vibrations of the atoms comprising a molecule of water. However, after 50 femtoseconds oscillations were damped (1 femtosecond = 10-15 seconds). Obviously, the reason was the weakness of the hydrogen bridges, which allow water molecules to rotate, to tilt, to tip over. In formed they network constantly, there were fluctuations, but because the water instantly forgot their previous structure for the same 50 femtoseconds of her had not disappeared.
Why do You ask?:shock:Андрей Патрушев wrote:Hmm, how did the highlanders manage to live so long is almost distilled water?
If Ref IZUMRUD, the manufacturer says that
"Water treated in IZUMRUD, meets the requirements of hygienic standards. It retains the necessary for the body useful trace elements: potassium, sodium, calcium, magnesium, lithium, fluorine, iodine and others." So that on distillation no claim.
Andrei Patrushev responded to the drug.Карил wrote:Can you recommend a device for structuring water?Андрей Патрушев wrote:Pseudo-scientific set of words. Even given the fact that it was written by a reporter and actually meant something else, the experiment is not at all about this...In this experiment — it was directed by T. elzesser and D. Miller were generated vibrations of the atoms comprising a molecule of water. However, after 50 femtoseconds oscillations were damped (1 femtosecond = 10-15 seconds). Obviously, the reason was the weakness of the hydrogen bridges, which allow water molecules to rotate, to tilt, to tip over. In formed they network constantly, there were fluctuations, but because the water instantly forgot their previous structure for the same 50 femtoseconds of her had not disappeared.
You need to take a stack of CDs, put them on a metal Cup with water. I left it for the night. The water really tastes different from the one that was in that Cup, but stood on the table. In action similar to the Cylinders.
Алексей Маринин
I would like to touch on the subject of BOILED WATER!Benefit or harm?My personal opinion useless (meaning cold water)! My parents drink only boiled and do not recognize any other , and I cannot convince them! The only thing I did was to freezing water from the tap in the freezer , but they boil for a few hours and, after cooling drink!Prompt who that knows! It is desirable with deep arguments!!! Thanks in advance!ALEXIS!
Алексей Маринин
вишня.друзья
give structure to the water through a matrix of structurer and food in the refrigerator in silver water with silver ionizer sites www.matrix.com.ru www.aires.spb.ru www.nevoton.ru
If you have time search the Internet Galina Shatalova Human Health: Philosophy, physiology, prevention. In this book Goritsa about structuring water vkusnosti. Very rare to meet such smart women. As she writes structured water is the best, the juice obtained from the fruits or vegetables in this juice it is the structure of water, even gives an example don't remember what people or in the Amazon or somewhere else as they drink from any fruit juice and really feel great. By the way about the longevity of the mountaineers, and Yakuts are articles about why they live long. Galina Shatalova she worked in various fields: space, surgeon at Burdenko and now spends with the people Hiking in the Crimea, lectures, and incidentally helps us to understand why there are many diseases and helps to cure them. To me personally this book has helped open your eyes to many diseases and most of her 90 years living in their system of healing, with respect Tolanic.
Баффетт
