The normal operation of audiostrobe is exclusively governed by the volume of Your audio player.Техас wrote:In Mind-Spa to me that we don't like two things:
1. eats batteries very quickly (I use 2 times a day) is enough for two weeks.
2. And certain audiostrobe, the signal in the glasses, is virtually unchanged, the LEDs are always lit, even on a low brightness.
MindSpa 6th generation
- Contact:
Yes there is no such button. To the right is the entrance to usb and aux. and in the instructions there is no information about audiostrobe. neither Russian nor English. version. But I see that Texas writes about audiostrobe, you know that somewhere hitch. Where not see.Right there is a button "AUS" - audiostrobe. Read the instructions how to use it
Texas!
thank you very much! yellow button does work but the only inscription which it is present is under blacklight and in the instructions there is no word about the function of audiostrobe (just in case studied again because this thought is not new connections between neurons thanks to the machine occur, and opens previously established)
Andrew other
I'm interested in how you're doing with audiostrobe there's a blinking in the glasses. Yesterday once again tried to adjust the volume of the player, subtract the volume of the diodes glow less pribislaw more, there is no flashing there.
Maybe when you transfer to the fleshpleera WMA, cut the frequency.
- Contact:
- Contact:
And which ROM?Техас wrote:Andrew other
- Contact:
In fact, the manual I translated - I remember that something was... Looked - indeed, the new instruction word about it... - so was not in the original... That's taken from the first, I hope all the same:андрей другой wrote:Texas!
Using AudioStrobe®AudioStrobe® is a patented technology developed in Germany. AudioStrobe® sinhroniziruete music and pulsating light in the glasses, creating an interesting complex sensory effect. Special CDs when played through MindSpa, the AudioStrobe device decoded" and translated into digital signals for control points. These digital signals recorded at frequencies lying above the level of normal hearing, so the quality of the musical material is fully preserved.
In order to enable AudioStrobe®: place player special AudioStrobe® CD-ROM. Then one end of the connector of the stereo cable (included) insert into the headphone Jack of your player, and the second connect with MindSpa via external input (see above).
• Press and hold for about two seconds to activate the "Backlight" (above the ON/OFF button/PAUSE button until appears on the display of the letters "AS". This suggests that the MindSpa is now in AudioStrobe mode®.
• Install Gramsci sound in the player for about 3/4 of its maximum;
• Turn on the player the "bass boost" if you have it there;
• The brightness of the light in the glasses is adjustable in the usual way (see above).
• When to start music, adjust the brightness of the light.
Note: the AudioStrobe Mode® disables the auto-off function, so take care you turn off the device when finished.<
Okay, okay, the question was asked is not correct. Try even so without MM, because I think that her role in conjunction with Your drives, not so significant...Андрей Патрушев wrote:On laptops are usually very poor sound card...Anonymous wrote:Andrei Patrushev
as far as reduced efficiency from listening to Your CDs that with AudioStrobe, if you listen to them without MM and with a laptop?
Texas
Andrei Patrushevthanks for the comment. At random, he had come to this
Yes, all the same. However, when you reduce the volume on the player, the diodes start to blink weak and in the same mode.I'm interested in how you're doing with audiostrobe there's a blinking in the glasses. Yesterday once again tried to adjust the volume of the player, subtract the volume of the diodes glow less pribislaw more, no flashing no
And for the simple reason that these funny manufacturers have taken a standard CD (no MP3) player, changed his cover, and which has sebaciel all the stuffing.Dimas wrote:Guest
there are Zen-master.We not only sell,according to a very unreliable device,rests on the strength of 4 months,I don't know why
As a result, when listening to discs with AudioStrobe, for example, wild cod. He learned to "bypass", but to the producers in the correspondence was almost convinced that it was for my own good.
Hello! Help to understand with 6th generation MindSPA, everywhere a detailed description of the previous version, even in the instructions are only scant tabaci in dlitelnosti sessions and indication of frequencies (theta, alpha, etc.). Want to learn more now what to do, what to listen to at what time and what the result should be
- Владимир Никонов 2
- Has thanked: 20 times
- Been thanked: 28 times
- Contact:
Additional sessions I downloaded on http://www.avstim.comФденс wrote:tell me where you can download additional session matching this version?? thanks in advance...
