Sleep
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Wed Oct 14, 2009 11:48
Dimas wrote:awaken
Георгий_19
Александр79
Try to remove from the reality of the presence of the wall (edges etc.).And the obstacle will disappear :)
Dmitry, You did it, or is it just an idea?
Post by Dimas » Wed Oct 14, 2009 11:51
Георгий_19
Try to describe only your experience. Do so.
Post by Шалтай Балтай » Wed Oct 14, 2009 12:06
Dimas wrote:Георгий_19
then pliz more
what's a wall in real life?
Post by Dimas » Wed Oct 14, 2009 12:18
Георгий_19
The fact is (as I hold this glance at the work of the subconscious) that for the subconscious there is no difference between the events occurring in "reality," imagination in a dream. Therefore, if You realize (believe) that there is no wall,no barriers,no krakoziabliki in the form of elementals, entities, and like, cough..., ri, then in the dream it will be nothing. :) And Vice versa, if You're in a dream will acquire certain patterns of behavior, these patterns are not primenet opportunity to manifest itself in Your everyday "reality" :)
Димитрий
Post by Димитрий » Wed Oct 14, 2009 12:19
demAs az
Post by Шалтай Балтай » Wed Oct 14, 2009 12:28
Thank you.
But this is a very common phrase.
Well, here for example,
I love Wasps to fly. If I try to fly on the "far" distance, this little work, I feel the obstacle.
To fight with him, I have not tried it, intuition tells it, forget it.
Just rasslablyatsya and fall or throws in another place, or about to spill that in General the same.
And what to do in the real world, that would "fix" this in the wasps?
Post by Dimas » Wed Oct 14, 2009 12:44
Георгий_19
Well, like I gave a clear direction of what to do :? To change the way of thinking. Flying, knowing that there are no problems there. But in real life, create confidence in it. Will share a little secret :wink: Intention and confidence develops better when You are modeling a future event vector directing attention not to the future but to the past. That is, You would remember in detail the desired event, it has ALREADY happened and You don't need to worry about that it may not be :) You are calm, You got it, therefore no emotional attachment, which severely hampered. It takes a little practice, but will pay off handsomely :wink: I think You understand that the same can be done not only with the simulation OS. 8)
Post by Шалтай Балтай » Wed Oct 14, 2009 12:55
does it work?
frankly, a stretch. :-)
crazy training for personal growth :?
Post by Dimas » Wed Oct 14, 2009 13:13
Георгий_19
works :lol:
Rather than psihotrening, but the magic :wiz Although what comes first the same question :wink:
Post by Шалтай Балтай » Wed Oct 14, 2009 14:04
OK
saved
will poke :)
By the way, long turns phase to keep?
With a depth of no problems, once I remember, poked poked 5-7 minutes of that time, i.e. a minute and a half of this, came to the conclusion that in real life :-)
But with the duration....
Here that can advise?
Post by Dimas » Wed Oct 14, 2009 14:13
Георгий_19
and the duration of this exercise is acquired :)
Post by Шалтай Балтай » Wed Oct 14, 2009 14:35
can't argue with that ... :)
only the practice makes perfect
оуаакун
Post by оуаакун » Thu Oct 15, 2009 3:51
Георгий_19 wrote: Hackers say that the network does not tolerate hacking.
You have then no "strange" events in real life did not happen after these attempts?
I sleep generally about any hackers and the walls did not know and were not even aware.
It is in the dream, I found myself inside the hologram and tried to get out of it... three times in a week... but was awakened by a bright light and crackling... And it started after looking in the Mirror at night... :?
Жека3000
Post by Жека3000 » Fri Oct 16, 2009 0:58
Well, like I gave a clear direction of what to do to Change the way of thinking. Flying, knowing that there are no problems there. But in real life, create confidence in it. Will share a little secret Intention and confidence develops better when You are modeling a future event vector directing attention not to the future but to the past. That is, You would remember in detail the desired event, it has ALREADY happened and You don't need to worry about that it may not be You are calm, You got it, therefore no emotional attachment, which severely hampered. It takes a little practice, but will pay off handsomely I Think You understand that the same can be done not only with the simulation OS.
Here is Dimas! This is good!:)
:ay So simple! I didn't think of it :wiz
Post by Шалтай Балтай » Fri Oct 16, 2009 10:43
The hardest part is just to simplify thing, make something simple, primitive.
"All brilliant - just"
To complicate things and confuse ... can any figure
For example, Everyone knows that God is
everyone has heard about life after death
... what? :)
Димитрий
Post by Димитрий » Fri Oct 16, 2009 18:37
Александрий wrote:Simulate consciousness, synthesis and transformation in antimetric.
That's awesome - that's right!! :roll: :roll: :roll:
Александр79
Post by Александр79 » Sun Oct 18, 2009 10:30
Георгий_19 wrote:The hardest part is just to simplify thing, make something simple, primitive.
... what? :)
Like that :) This changes everything. But to see and understand that "everything" allows only the inner experience of the soul and consciousness.
The most difficult thing in spiritual development is to apply the he experience itself, and the easiest way to find their way... Just need to make an effort. Work, work and work again.
Жека3000
Post by Жека3000 » Mon Oct 19, 2009 17:29
Александр79 wrote:and the most simple, to find their way
Александр79 wrote:Just have to make the effort. Work, work and work again.
That phrase is contradicting itself polucilasi...
