I need a pattern email. key.
In short, to headphones instead of speakers to hook up LEDs that have their diet. Lumiere make
Alex, what You doing now far overrides all the parameters and capabilities of these devices.Алексей Крячко wrote:the Function of vision correction, as far as I understood (I warn you that I'm not a doctor, and electronics) - a side effect in mindmachine. However, the effectiveness could be greatly increased if to use certain frequencies of light stimulation.
Actually there is a whole class of special devices of ophthalmotilapia, which is based on the injection of light pulses with frequencies close to rhythms of the Central blood flow or even synchronized them with the help of special sensors. When this happens, as it sync with these rhythms in individual organs. Selective action on a particular organ is determined by the wavelength (in other words the color of the LEDs).
Devices based on this method are available. You can see the device "Look" from NPP "PHOEBUS"
http://www.febz.ru/project/pribor3.php
Or device Teterina :
http://www.ntpo.com/patents_medicine/me ... e_81.shtml
The General name for such devices in Russia, "the device for correction of functional systems of the human body".
I have a similar "Look" the device, developed by one of Novosibirsk institutions.
Theoretically (and practically) it would be possible to combine these functions with mindmachines. And it seems to me that it would be enough just to correct the firmware mindmachine and to obtain correction of the functional systems of the body as one of the routines selectable by the user. I think that the developers mindmachine ever before guess
Hmm.. gugliermina the word "ophthalmotilapia", led me to the above sites, plus more medspravki.narod.ru/litra/apek.html so more like a fake. And to correct visual acuity by means of light effects (not laser )- it is doubtful somehow.. Max what I can offer is the removal of spasm of accommodation the ciliary muscle in some forms of myopia.<Алексей Крячко wrote:the Function of vision correction, as far as I understood (I warn you that I'm not a doctor, and electronics) - a side effect in mindmachine. However, the effectiveness could be greatly increased if to use certain frequencies of light stimulation.
Teterina Tatyana Prokhorova not only the inventor but also the researcher in particular occurring processes (reactions) in the eye when viewing any color and when exposed to light. impact on organism and psyche.<Гость wrote:function of vision correction, as far as I understood (I warn you that I'm not a doctor, and electronics) - a side effect in mindmachine. However, the effectiveness could be greatly increased if to use certain frequencies of light stimulation.
Андрей Патрушев wrote:well, Well...
Dear Andrewwell there are no funds to work with light in mind cars. Impossible vnutripolostnoe modulation with such a short length of the pulses in the session to close up. If you just segments for 4 seconds at a frequency of 9Hz be modulated, neither in the single mode phase shift will correspond to that device. In short it does not say, but an exact copy will not receive. If you know how to make exactly as written on the site, write here the settings. And it is better to prove by making such a simple session and lay out hereсайт производителя wrote:the duration of the light pulses of 4.0 ± 0.5 s, pulse duration of vnutripolostnoe modulation of 1.0 MS, pulse repetition frequency vnutripolostnoe modulation of 9.2 ± 0.2 Hz, the switching time of the working impulse from one eye to the other is 0.9 – 1.1 with the emission wavelength (525 ± 25) nm.
Yes, You are right 1ms to fail. But, I guess there is error page - not one millisecond, and 11мс, since 1 MS at the exposure does not have a physiologically active action (well, as far as I know, of courseПутешественник wrote:Андрей Патрушев wrote:well, Well...Dear Andrewwell there are no funds to work with light in mind cars. Impossible vnutripolostnoe modulation with such a short length of the pulses in the session to close up. If you just segments for 4 seconds at a frequency of 9Hz be modulated, neither in the single mode phase shift will correspond to that device. In short it does not say, but an exact copy will not receive. If you know how to make exactly as written on the site, write here the settings. And it is better to prove by making such a simple session and lay out hereсайт производителя wrote:the duration of the light pulses of 4.0 ± 0.5 s, pulse duration of vnutripolostnoe modulation of 1.0 MS, pulse repetition frequency vnutripolostnoe modulation of 9.2 ± 0.2 Hz, the switching time of the working impulse from one eye to the other is 0.9 – 1.1 with the emission wavelength (525 ± 25) nm.. My IMHO, to repeat it by means of the mind of the machine, at least photosonics, it is impossible. And imitation is another. Will be like, and even then not too much is high.
Zombie, do not worry. As the assistant MM of course light can not, but such effects it can be achieved, though slightly different way. But most of the things she can make that device unavailable in any form. For quality relaxation, including eye, good alpha.
PS: my Previous message.
