Advice from Andrei Patrushev
Дмитрий.Дмтирий
Andrew, thanks for the reply. If in the morning the "Star wanderer", and in the evening "a journey through the inner worlds."
Dmitry.Dmtiry
It is possible and so. Sleeping will be interesting.
Дмитрий.Дмтирий
Andrew,thank you for your attention.
Andrew, good day! Tell me please, finally able to listen to drive awareness of a dream 45 minutes, or can be reduced to 30 minutes?
Ridge
You can even to 15 minutes.
Thanks Andrew for the great answer!
Andrew Hello! two years ago.looking for some information.accidentally went to the website and downloaded Ultramesh.I tried to learn English-the result is great.though I listened 5 times.the problem was with sleep.full bodrstvovanie.but do not understand the fears were.After a certain period of time the opening of the 6 chakras.opened the channel of clairvoyance.you see the other world.Your program could contribute? and as can now be affected by your program Massage of the brain.you want to buy.in order to be a good memory.concentration.
Natalia
Hello.
After does not mean because of. Ultramesh helps normalize sleep, and not Vice versa, and to other world it is irrelevant.
In my opinion, You are contraindicated to do with any psychoacoustic programs.
Hello.
Andrew.thanks for the reply.mentally I'm good.just a question is.what can I listen to your CDs.people with certain abilities like mine?
Дубасова Татьяна
Hi Andrew.Please be advised that you can listen from Your disk and in what order to lose weight.This annoying topic,but very serious.THANKS in advance.
Dubasov Tatiana
Hello.
Nothing special, but the Conductor, as a universal problem solver can help.
Hello.
Дубасова Татьяна
Thank you so much.
Hello! 17 years ago happened in my lifetime event, after such events, many losing their lives or change their place of residence. I stayed in my village, not enough willpower or spirit, I don't know,,, Made shop, things went uphill, got married. Threw myself into work, became a leader of its region in its field, but I'm not interested. All this time, are in hell. Now I have three children, the oldest 12 years old, the second 9,and third in six years. it seems that in the village they began to hint that what their father, vanished friends, were repressed and shy. I left my job last year seregil 11 months after the weight has fallen below 55 kg (weighed 100 kg, height 1.87) returned to regular food. Today is the fifth day, I listen to MM, there is a lot of negative thoughts, depression strong. Please advise me what to listen , what to do.
Kuzi, here is the topic:Кузи wrote:Hello Alexander!
here Alexander.. like.. no.the Advice from Andrei Patrushev
Sorry, Andrew!) Yesterday, listening to the symphonies of Tchaikovsky, tension white plastic wire mesh is gone, now were in the field on the charge, "returned to itself"))bofara wrote:Kuzi, here is the topic:Кузи wrote:Hello Alexander!here Alexander.. like.. no.the Advice from Andrei Patrushev
Bought the discs to begin with, a guide and a healing. They say there is unprotected mental copy? Can I convert to MP3 to listen through the player or it is necessary to use FLAC format to without losing it? and if you can konvertovat what's the threshold for what the next MP3 starts teryatsya audio?
Hatred
Disks can only be converted into WAV format.
And I'm in ALAC(apple lossless audio codec)stabbed discs to your iPhone to listen.MM were connected via - a gate works even on the lowest volume...Theta hiss very high quality!
Begin to listen to the course conductor for the night (on the Navigator)and star traveler in the morning, so now I sleep for 10-12 hours
after star wanderer well so cut down
by the way bells 3rd track?
listen only the 4th day
why do I sleep so long now
though like myself consistently waking up at 6-7 after listening to the AP I want to sleep
don't sleep on the bells though periods and there fail, well on others too sometimes
Stavr
Disk applied 3D sound processing and fractal technology for the synthesis of sound. All this was done in order to ensure development of the flexibility of the brain. When the brain is faced with a harmonious, but a little predictable (in various senses) sounds, it automatically begins to search for them in the system. This leads to the development of a neural network and training the brain to discern complex system of levels and to operate with them. In short,
getting smarter and more flexible. Something like making jazz music (where improvisation).
When the "clash" with some new knowledge (in all senses) is first populated with "RAM". Transfer the contents of RAM on hard drive is in sleep. Therefore, the need for sleep at the time of learning is greatly increased. This is also evident when getting into a new unfamiliar environment.
then over time all will be restored
however after this course of 21 days, I'm going to listen to the healing and MM, is also 21 days
after endorphins and journey through the inner worlds, there may be obtained the same effects?
Stavr
Yes, it is possible.
But the technology is about the same, so at least the intensity of these effects will go downward.
Andrei Patrushev
Thank you, so we'll get used
a year ago this was not
Stavr
Then it's basic fatigue.
Andrei Patrushev
and then this possible to do?
