we are talking about charging conder from the ground, one wire that was completely discharged. I like the physics of this -
Small offtopic.
passing
Re: Small off-topic.
Well I gave an example of when scientific the science itself refers to the knowledge holders, pays for travel and understand that doesn't understand anything.... because for 70 years, not a step forward, although the Mat model to work in a vacuum given that the matter loops back circles ( why would she?Мастер 108 wrote:Convince him please, it will be not only interesting,but... um, revealing what, for some, who regard themselves as skeptics and apologists scientific scienceМихаил_ wrote: Now convinced by the way one of the inventor to make the cycle of video lessons on real physics
Yes, another "funny" experience when in a high-voltage circuit operates the spark gap and shorted thick copper bus is not prekraschaet his work ( the oxides are removed, the tire is thick, a direct short circuit and the spark gap continues to scribble in full ). But when, instead of thick copper bars to this place put a thin nichrome wire with high internal resistance (for classical physics), the arrestor stops the wire is cold; the Question (rhetorical. discussion is not necessary) - what is it ?
Including, in some cases, there are "fractional" charges.
I can assure you. It was all written earlier, there is relatively available and less accessible sources, and so on, the question is, what to understand and accept after driven into the head of classic models is hardly likely. I have here the above-described experiments, the inventor of the particularly funny does not cause problems and do not even require much of his explanations - I know of a number of these properties of our world long ago, and many on this site work with them in their organogenetic crafts, Rinat turntables and other pieces, and there are all material. But something that I wouldn't have thought to do that and so to demonstrate. Just a man 20 years experimentally "nagging" topic.
There is now recognized cold fusion Rossi - nowhere to go. A group of experts with the generator locked - they had to confirm the reality of the installation; And rumor has it that the Chinese patent was bought and the belt is put.<
the theme of small offtopic described at the outset of topics devoted to alternative science and medicine not directly related to products improvised or not improvised to my brand. It does not involve debate on the topic of reality discussed in a long post. No one wanted to offend, but it has its rules, and Yes strict moderation. That's about it. Wrong 100,000 times it was fun of course. Classics of the genre - the main thing to prove anything
. Typically, these are busy people, but sometimes just those who do not believe in that world more than they are allowed to know.
passing
So in the discharge, in my opinion, less "irregularities", according to the traditional physics than such a charge. It was logical to start with this. I still can't understand the physics of the process charging
You have not considered the resistance of the body. And messed up 5 orders of magnitude therefore, considering the circuit current and internal resistance of 10 ohms not Meg or two.мимоходом wrote:Boris the MX, I was forbidden to write in this thread and my posts RUB you see. I just don't have time to get to charging, having to justify only discharge. To justify fully and in accordance with the laws of physics
So in addition to 3 sheets of anything I didn't see anything, this topic is about something else. Therefore, your posts are not the topic and will be deleted. Goodbye.
and it is possible more in detail about this experience and how to repeat it and the message rubbed early and read nowhere, or at least a link where to find him, Bo Guguli something strange displays in the search text. maybe the author of the site experience is full or it somewhere is describedthis experience as a charge high voltage capacitor one-touch earthen wire to full capacity, with slips maaaaaaaaaaany spark
Unfortunately there is no website or experience in the network. And people light up is not particularly with this wants killed time in his opinion.
I deleted not only the technical objection of the person who counted the contour with the body together =10ω and said "proved everything already."
Experience I've seen in person.
Yes, there are charging is due to the special properties of the medium, which is the condenser. Included little kacher Brovina, even without a spark. Power katscher is such that only the tube lights are not very bright lights. From a bench top power supply 12 volts consumed 0.8 And kacher.
The capacitor is in the field katscher. At the entrance of his half-bridge from special diodes (options are chosen by manual selection from the series, otherwise it does not work anything, if, for example, to use expensive high-speed diodes with the best settings - also not working).
The condenser chamber is discharged to zero, it is checked that it does not accumulate residual charge and so on.
If the earth "to corotate" longer (to keep the ground connected), the capacitor BREAKS.
The land is improvised from scrap and welding wire outside the window. It is an honest zero, nothing left not connected. And there was not and could not stand we aim to "breed".
no additional scheme is not and is not connected to clemam conder, also screwed directly under his nuts (well, Maslennikov there nuts and insulators porcelain) diode legs.
The whole scheme of the experience.
If there again will be - will be removed, although there are not important experience and understanding of the experience ( and certainly not the classics ).
The catch is that the charging spark is very weak, and then the capacity of even a second "gets" residual charge and it is poured "on the ears" -no wonder they explode if the ground is not clean. And in the "foreign" scheme (in coil) walks funny power (10ватт)which theoretically evenly dispersed around. Virtually all of the stands I saw there are in the nature of the show as in watts "powering" input conditions, it is possible to obtain high power and normal current output. Of course this is not the scheme of "industrial" installations.<
Андрей Ермаков
- Has thanked: 3 times
- Been thanked: 15 times
1. Kacher then at least normal, or what is also findability
. By the way I not to see the movie, but at least superficially the idea of the process to hear. For example, kacher creates an anomaly in the condenser (why), the capacitor appears, the charge on both plates (inside himself), and then grounding one end of the reset to zero its charge (and therefore spark a little). Why the diodes ? if the variable component is not... or is.
2. That capacitor which is 12 Volt has 100 times the same diodes and kacher ?.
That has - nothing, no katscher, no diodes, just before the contacts touch different materials, which is charged from any conventional source (we charged from the laboratory model of the power supply). Plus according to that person, not all electrolytes are suitable and the capacity should be matched to the parameters of the body(the one he showed, was chosen on the basis of more or less average statistics as the best, but another person of the former with me not beat at all, and me and the author of the experiment - excellent beater.
Kacher is the most common and generally the other person was doing and gave just the inventor. Coil on 50трубе about 80 cm tall.
Conder was placed on a copper plate without making contact with it, the plate had no contact with kachera. Just like this "stage" is suspended as in the pyramids, about 2/3 of the height. ON top katscher ball in the form of the emitter, slightly less in size than a soccer ball. Of the streamer no.
The bridge on the ground and the field katscher according to the inventor enable us to instantly switch between the spins of charge carriers, receiving electrons from the cold carriers (let's call positrons or DOJ, in short, of what in science is called "holes" in hole conduction), and Vice versa.
He says that the process of "switching" state of the media in General is not expensive and it is the key to the technology, but formed it on the tanks.
And much better work capacity combined with the inductance.
I still hope to post in the coming months several interesting videos with commentary of another person, whose theory corresponds to that practice well.
I saw there's also another fun experiment - like a homemade capacitance LC meter 2мкф not shunts the signal from the frequency generator from 100килогерц to megahertz. Conventional factory - shunts naturally when the container is in a straight line.
By the way there is for plates used different materials.
Also discussed was the point that most do not truly understand the value of R in the circuit don Smith. And smichowski the hodograph, which is generally now hard to find, and which no one understands (such tablichku with slanting lines and circuit parameters).<
[youtube] www.youtube.com/watch?v=qxDTm1AKrbI [/youtube]
Better to do it with the disk in the machine or directly on the motor spindle to evenly, otherwise it can be very hard to unbalance it and will have a strong vibration that will quickly destroy the bearings and is very noisy then.
I was optcial on the turntable, but since the engine is weak HDD, then did bormashenko, not a file.
For my taste not enough 10000, at least 15000 needed.
Sharpened gives some effect, and a little more stream quality, but not so radically.
Michael_If not difficult, and that can be available to read on the "real physics"? I'm also Achowskiego, which by the way is easy to read, is not found. And it is not sure that he is right about everything.
Well, I would try to delve into what he writes Kondratov on your paleotechnology.ru and look at the work of Keeley
About Keeley read, but there, apparently, you need to know resonances. He objects levitate "connecting" to your cocoon. I realizing that no one understood because it was not considered a mental work.
I think no one understood, because they didn't try to understand. The keels have a lot of work. And known only to the 40 laws.
Just Keeley said that everything is structured vibration and the laws of interaction as this information has its own peculiarities. It is so short. And Valera are all VERY well from a position just physics and mental, there is simply not described difficult part of work with one another because it is hard to Express in words ... in Other words it's about one and two components.
Taken from here:
It started in 1980. On examination in the lab
sent a young man with a strange disease. From time to time he
for no apparent reason, increased temperature to 38 degrees. It would seem that nothing
terrible. But this is easily the patient is seriously said to the technicians: "Girls, I
I'm about to die." They did not believe him, because the attending physician
suspected he had only malaria. Its pathogen a month trying to find
in the patient's blood. But never found.
And the patient suddenly doctors very fast, "heavy".
Then they were horrified to discovered he had bacterial endocarditis - infectious
the defeat of the heart muscle, which in the beginning overlooked. To save the guy and not
managed.
Kozmina throw the blood of the deceased. Considering it still
times under the microscope, she suddenly discovered in him the smallest organisms with
tiny core. Been trying for two months to identify them, asking
clinical laboratory technicians, and considering the Atlas of bacteriology, but to no avail.
And finally found something similar in the book of the Moldavian author Shrout.
There were pictures and descriptions of strange microorganisms -
mycoplasmas, which do not have a dense cell wall. Their covers only
a thin membrane, so they can easily change their shape. For example, from
spherical, Mycoplasma can stretch out like a worm - and to squeeze into narrow
time human cells. Is not capable of even viruses, although the size they are
less than spherical Mycoplasma. However, the latter can, without breaking into
the cell to obtain nutrients from it. Most often these pieces
protoplasm just stick to the cells and suck out their juices through the pores.
But, as often happens in science, the first discovery has been given more
questions than answers. In the book of Shrauta the researcher found the second
contender for the role of the causative agent of septic endocarditis. And appearance, and
habits very similar to Mycoplasma was the so-called alforma bacteria.
It appears when the patient begins to treat with penicillin, which
prevents the formation of sheath in bacteria. Previously, doctors thought that without it
parasites are killed. And then it turned out that they can live without the shell, and even
to cause disease, but leaking is very unusual, as the doctors say,
atopiceski. These problems are very difficult to diagnose.
Finally found a third contender for the role of the killer, the
small - chlamydia. Some scientists called it a spore of the fungus, others virus,
but all agreed that this dwarf microcosm freely penetrates
cells and the parasite inside of them.
Now, chlamydia, and Mycoplasma excite disease
the same clinical manifestations. Symptoms it is impossible to determine who
caused disease - or cell membrane of the parasite. Alas, the first attempt to recognize
secret killer has created three versions, each of which could be false.
But these searches were not in vain. Now if Kozmina found in someone's blood
such a "trifle", which is not required to pay attention to the instructions and
manuals, it, nevertheless, raised the alarm that doctors missed
disease, as happened with the poor guy.
AGAIN, TRICHOMONAS!
In 1981, the lab sent a pregnant woman with
a diagnosis of fever of unknown origin. And instructed: "Seek
the causative agent of malaria". Then technicians "sowed" the blood of the patient in a nutrient
environment. A single "seed" has really grown familiar Cosimini and
the other - Oh, the horror! - there are tiny ... trihomonadi. Those
flagellates, which, in the opinion of official medicine, cause only
sexually transmitted disease, and according to "underground" and many other
"diseases of civilization". I sounded the alarm and put on his feet all Belgorod
team - says Kozmin. But they are unable to explain the results
tests. Then I immediately went to Moscow in Institute of Microbiology named after
Gamalei. It confirmed that in the blood of the patient has Mycoplasma. But
to comment on the presence of Trichomonas refused! And not advised how to treat
sick. "But we teach you how to sow Mycoplasma," said me
confused lights of Microbiology. But I that was happy. Thought received
the skills will help me to determine the causative agents of almost all diseases is unknown
etiology. But when in Belgorod beginning to "sow" Mycoplasma, next to these
membrane parasites grew a lot of other little things that I could not
to recognize.
Indeed, these microorganisms were long
variety of shapes: round, oval, similar to a saber, with one core and
multiple, separate and bound in chains. There was a reason to get lost
a medical technician. Then she decided to study the books of classical Microbiology. In
the book of one scientist read that Trichomonas reproduce by spores. As
to understand, because there are spores from the fungus, and Trichomonas is considered to be an animal? If
the scientist is correct, then these flagellates should form in person
mycelium – mycelium.Indeed, in
tests some patients under a microscope it was evident something similar to
mycelium.
At first I wondered what is this thread? recalls Lydia
V.. - Maybe wool? Or patient clothes natryas the dust? But then
was surprised to find that the threads consist of single-celled parasites. However,
not from Trichomonas, and Mycoplasma. So maybe it is one and the same microorganism,
but at different stages in their development? No surprise, then, that Trichomonas
form spores, and Mycoplasma - mycelium. Just in our body grows
mycelium.
Official science has recognized the existence bezichtiging
Trichomonas - but only in the urogenital cavity. And Lidia often
found these parasites in the blood, breast and other organs. How they
got from the genitals, these giants of the microcosm, which reach 30 microns and
can't creep through cracks. Can they really poured the smallest
disputes, which can easily penetrate into the blood and spread throughout the body?
Before I lacked the courage - recognized
the researcher is to tell the urologists that Trichomonas can travel
according to the body. I now have serious grounds for such claims and not
I'm afraid to talk about them specialists. But not only that. Urologists argue
in bezzvuchno form are killed Trichomonas. Supposedly, under the action of
drugs the parasites dropped the "hoof". And, according to Cosimini, Trichomonas these
right as rain.. She found them in the analyses of patients in a few
months after the course of treatment. Trichomonas dead a long time be resorbed, and these
were completely intact. If they really killed, then they probably
rose.
But it is unlikely that the parasites are capable of such wonders. Most likely,
happened to him something similar to what happens to bacteria when
drug treatment: external agencies resolve and internal - remain.
The scales fall from the eyes.
Kozmina continued his research, finding more and more
discrepancies with conventional theories. Very often in the blood of sick people
simultaneously detect two pathogens: chlamydia and Ureaplasma. Among
patients were a lot older women. Moreover, these parasites were from them only
recently, when they could not become infected through sexual intercourse. Where did
agents of sexually transmitted diseases?
Here I must digress. Technicians clinic
ATC are working with a regular contingent of people. Pondering the question, where
took chlamydia and Ureaplasma from innocent grandmothers, they remembered that for many years
ago these patients were found in the analyses of trichomonads. Checked the paperwork
- and just. By the way, something similar happened in men: once they were treated
Trichomonas urethritis, and now their tests were seen small creatures,
resembling Trichomonas, but without flagella.
It was considered that older people had got rid of the pathogens
sexually transmitted diseases: parasites allegedly killed a drug. And test
it turned out that the parasites were alive, but changed their form and habits,
hiding in the body, so as not to cause themselves chemical attack physicians. And
when they've forgotten about Trichomonas, they suddenly came out of hiding again
exciting venereal diseases - to the great shame anchoring the elderly.
How can we explain this metamorphosis?
The key to the mystery was an interesting story, which
occurred in the Republic of Chad. In one year, all children who were born there were sick
encephalopathy, and with all the palm trees somehow fell off unripe coconuts. This fact
interested scientists, and they found that the disease in humans and plants
viswanatham and the same parasite
spiroplasma, which is a relative of the Mycoplasma and Ureaplasma.
The newly minted pathogen was fine and in coconuts, and in
the brain of children, and in the placenta of mothers. It was downright universal parasite,
which freely penetrate into any bodies of people and plants, finding them equally
suitable for life. Who has such amazing abilities?
I've been thinking about this issue - continues to Lidia
V., and a year ago completely unexpectedly received a response. Found him not in
scientific works of the giants of Microbiology, and the Children's encyclopedia edited by
Miryana, the first volume of which recently appeared in the sale. Now, in the second
volume (Biology) there is an article the editor of fungi-the slime mold. And it is this
colorful drawings: the appearance of slime mold and their internal structure, which
seen under a microscope. Looking at these pictures, I was amazed to the depths
souls: these are the microorganisms for many years was found in the tests, but didn't
to identify. And here - everything was explained very simply and clearly. I am very
Misurano grateful for this discovery. It would seem that what has
the fungus is a slime mold to the smallest microorganisms that quarter of a century eyeing
in the microscope Lidia? The most direct. Writes Maisuryan, the slime mold
goes through several stages of development: the spores grow "uebki" and flagellate!
They frolic in the mucosal mass of the fungus, merging into larger cells with
multiple cores. And then form a fruit tree of the slime mold - classic
mushroom on a stem, which zasyhaya throws spores. And everything is repeated.
First Kozmin did not believe my eyes. Shoveled a lot
the research literature on the slime mold - and found in it many confirmations of his
guess. In appearance and in properties producing tentacles "uebki" was
strikingly similar to Ureaplasma, the "zoospores" with two flagella of Trichomonas,
and discard the flagella and deprived shell of Mycoplasma, and so on.
Fruiting bodies of the slime mold is surprisingly similar to ... polyps in the nasopharynx and
the gastrointestinal tract, of papilloma on the skin, squamous cell carcinoma and other
of the tumor.
It turned out that our body lives the fungus is a slime mold - the
the most that can be seen on rotten logs and stumps. Previously, scientists could not
to recognize it due to the narrow specialization: some studied chlamydia, others
mycoplasmas, and others - Trichomonas. None of them never thought it
three growth stages of the same fungus, which studied the fourth. Fungi-slime mold
known a great many. The largest of them, fuligo has up to half a meter
in diameter. And the smallest can be seen only under the microscope. What
it is the slime mold is living with us?
They can be a lot - explains Kozmina, but until I know for
identified only one. Ego is the most common slime mold - "wolf Tits"
(scientifically - lycogala).It is usually
crawling on stumps between the bark and wood, loves the darkness and dampness, so
gets out only in wet weather. Botanists even learned to draw
this creature from under the bark. On the stump, pull the end of the filter paper,
moistened with water, and everything is served with a dark hood. A few hours
raise the hood and see on the stump creamy flat creature with water
balls that crawled out to get drunk.
In ancient times lycogala have adapted to life in
the human body. And since happy moved from the stump to the crude,
dark and warm "home" on two legs. Traces of lycogala - her arguments and
Trichomonas in various stages - I have found in the maxillary cavity, breast
gland, cervix, prostate, bladder and other organs.
Lycogala very cleverly evades the immune forces
of the human body. If the body is weakened, it fails to recognize and
to defuse the rapidly changing cells which compose lycogala. In
it manages to throw spores, which spread by blood, sprout
convenient and form fruit bodies ...
Lidia does not claim that found
universal pathogen for all diseases of "unknown origin." While she
sure is only that the fungus is a slime mold lycogala causes papillomas, cysts,
polyps and squamous cell carcinoma. According to her, the tumor does not form a degenerate
human cells and elements of ripe fruit bodies of the slime mold. They have already passed
stage Ureaplasma, of binucleate amoeboids, Trichomonas, Plasmodium, chlamydia and now
form a cancerous tumor.
Doctors can't explain, why tumors are sometimes
disintegrate. But if we assume that the tumor is fruit body
slime mold, then, according to Cosimini, everything becomes clear. Because of the nature of these
body inevitably die every year - like rhythm persists in the body
person. Fruit bodies die, to throw away the spores and is reborn again,
forming a Plasmodium in other organs. Happens all known
metastasis of tumors.
However, it rarely appears in the singular.
Usually are formed, as they say oncologists, primary multiple tumors at once
in a few places. Lidia explains this mystery the natural
property of slime mold: the same lycogala forms several balls.
Now doctors and scientists have hope that finally
identified the primary biological enemy of the human race - the universal exciter
diseases of unknown etiology. Previously, specialists have considered it
parts, who "horns" who "legs" or "tail". But only the synthesis of knowledge
allowed to recognize superparadise and find his Achilles heel.
First tried to do it Kozmina. But she was surprised to
found out that the underbelly of slime mold has long felt traditional healers. They
learned to treat many diseases that, in their opinion, is causing the mucus (read
- the "slime mold").
Parasites like gluttons and lazy.
That said I Lidia during the next
his studies in Moscow at the courses of improvement of doctors: If we are few
to move, lots to eat, drink, sleep, indulge in other excesses, then
turn your body into a dustbin with rotting food, which will rapidly
to multiply disease-causing germs. And they will begin to devour our bodies, that is
our body will decompose to inorganic substances. We literally
words become like rotten stumps, which grow fungi-slime mold. After all
mushrooms play a major role in our expansion... do not think that I
opened. About the mushrooms-the killers knew the medieval doctors.
Indeed, in the book of Gennady Malakhov, "the Healing force"
there is a curious story about how imagine the development of diseases ancient
Armenian doctors. Exposing corpses and the dead, they found in
gastrointestinal tract a lot of slime and mold. But not all the dead, and
only those who in life indulged in laziness, gluttony and other excesses,
getting punished numerous diseases.
Doctors believed that if a person eats a lot and little moves
not all food is digested. Part of it is rotten, covered with slime and
mold. That is, in the stomach starts to grow mycelium. Mold throws out spores
microscopic seeds of the fungi that nutrients get into
blood and are carried throughout the body. In the weakened bodies of the spores begin
to germinate, forming a fruit body of the fungus. So begins cancer.
Ancient doctors believed that the first fungi emit
"white Paradise" - plaques and clots in blood vessels with white. The second stage -
"gray heaven": the mushrooms form a tumor of joints and other tumors
grayish color. Finally, the "black heaven" corresponds to the current value
this word. Not only is he black because of a malignant tumor and
metastases have this color. Rather, it is the color of the aura of the affected organs.
Of course, we all don't die from cancer, and although our
the body is a huge number of spores, they are, in the opinion of Kozmino not
harm, while we support health at a high level. But the debate
sprout and turn into mushrooms, if we lose immunity. However, and then
do not despair: traditional healers have found a justice on these mushrooms.
STICKY, TOADSTOOL!
None of my business - to treat cancer, previous disease, -
says Kozmin. My goal is early diagnosis. And I surely do her in
one particular case is when the patient is facing a squamous cell carcinoma. This is a very
widespread disease: for example, 80 percent of malignant diseases
causes squamous cell lung cancer, that is the slime mold "lycogala epidamnum". I
well aware of all the stages of its development. But I hope that scientists will help me
to create methods and for identification of causative agents of other diseases. Lidia
wants to find among the many slime mold pathogens of specific types of cancer
and other illnesses of civilization. But why is she confident that all of them also cause
mushrooms, not any other parasites? Maybe because such
views are held by almost all doctors and healers who know how
to treat the cancer.
So, Vladimir A. Ivanov from Minsk in his book
"Wisdom of practice" (St. Petersburg) describes a method of purification of citric
juice and olive oil. If you apply it correctly, that from the liver without pain
go cholesterol tube and bilirubin stones. But the greatest good luck, at
the opinion of the healer, if you will slime. In this case, it guarantees to the patient that
soon he faces liver cancer. Like the Armenian doctors
of the middle ages, Ivanov said that the mucus causes cancer and the best prevention
the terrible disease the excretion of mucus from the body.
And his known associate Gennady Petrovich Malakhov
calls mucus cause of all the disorders that occur in an organism is higher
diaphragm. But to treat them it offers with the help of urine therapy. And
strange, gets excellent results. However, it explains them too technical and confusing -
in the spirit of Eastern teachings. They say that the mucus is "cool" and the urine "stirs",
Yang energy overcomes the energy of Yin and so on.
According to Cosimini much easier. The causative agent of many
diseases "of unknown origin" - Ureaplasma - fed urea. This
the parasite can lure his "favorite delicacy." For example, if we drink
my urine then gets Ureaplasma in the gastrointestinal tract and through him
leaves our body. But sometimes you can lure the parasite through the skin - making
on the sore spot lotions or compresses from urine.
Well, if it's disgusting to be treated in the urine, possible to treat slime mold
another drink that and you'll probably have to taste.
Walker, Bragg and other famous healers suggest in the morning
fasting is grated carrot and beetroot or drink made from fresh juice.
This, in their opinion, the best prevention of many ailments.
HOW TO TAKE OUT AILMENTS.
Not only Kozmin considers fungi pathogens
century. The famous healer from Kiev, Boris Vasilevich Bolotov has come to similar
the conclusion: he believes cancer is parasitism in plant cells and in animals. But
plants have an alkaline environment, and animals acidic. Therefore, to get rid of
parasites, we always have to acidify your body, making them
existence in it is unbearable. Bolotov advises to drink brew
there are salted and pickled vegetables, bitterness, and so on. With him in solidarity, not less
famous doctor from Novosibirsk Konstantin Pavlovich Buteyko. In his opinion,
soda and beer is acidified blood. But the best thing to do
with shallow breathing, then the body accumulates a lot of carbon dioxide
gas much more than it can give drinks. And carbon dioxide, according to
Buteyko are afraid of any parasites. Therefore absorbed in the body
any mucus.
A more severe method of healing was developed by healer of
Simferopol Vladimir Tishchenko. He offers his patients to drink a poisonous infusion
Hemlock. Not to poison, and to expel the slime mold.
But not through the gastrointestinal tract and directly through the skin. For this we need to do
from carrot or beet juice lotion to the affected organ.
I saw how effective can be such
methods, says Kozmin. - One of our patient developed tumor
a lump in the breast. And punctate I discovered Mycoplasma and
ameboidy. So, the slime mold has already begun to form fruit body - a woman was threatened
cancer. But our experienced surgeon Nikolai Khristoforovich Sirenko instead
surgery offered the patient to ingest a normal anti-inflammatory
the medicine, and on the chest to make a... poultice of beet pulp. And, "ogorchenie"
medicine, the slime mold climbed to the bait directly through the skin: seal
softened on his chest broke the abscess. To the surprise of the other doctors, this
seriously ill began to recover.
Once Sirenko was the man who had been operated twice
other surgeons, but could do nothing to help him, cancer gave extensive metastases.
Sirenko did not consider the patient's hopeless; given the "strange" advice, which
advances in modern medicine combined with people's experience. Every year
"hopeless" was held VTEK, and 10 years later received the permanent disability.
All the doctors marveled except Sirenko and Cosimini. In their opinion, the patient
remained alive, because the mycelium in his body as if preserved - on
it was not formed fruiting bodies, which could destroy the bodies and
to cause death. Kozmina believes that with proper care could live a long time
other patients in whom cancer has already given extensive metastases. The main thing - not
allow slime mold to bear fruit. But it is better not to bring up "black
cancer" and fight it out on "white" and "gray" stages as did Armenian
the doctors of the middle ages.
For example, fine treats rheumatoid arthritis Director of the house
stay "Krasava" Borisovsky district, Belgorod region Vasily Mikhailovich
Lysiak. He offers a course ... of 17 barrels of decoctions of medicinal herbs. Patients on
debt soak sitting neck-deep in warm water, and at the end of the course surprised
make sure that the joints had shrunk the tumor from which they could not
to get rid of a lot of years.
According to Kozmino from these people crawled out of the slime mould:
the mushrooms seemed much nicer in a warm herbal decoction than in patients
organisms, where they every day are poisoned with antibiotics and other muck.
If pestering diseases of the gastrointestinal tract, then
a barrel of water will have to take... inside. Of course, not simple, and mineral. And
of course, not in one sitting. Lidia explains the success of hydrotherapy to those
it is a natural method of removing slime mold from our body.
No wonder at the end of the course of a patient leaves a large amount of mucus. After that
aggravation immediately comes relief, and after a month or significantly
the improved condition of the patient. After all, he got rid of the main causative agent of
"diseases of civilizations". But, let's not upset those who have nowhere to get enough
"Narzan", not to mention seventeen barrels of herbal decoctions. There are no less
effective folk remedies.
For example, a herbalist from the Belgorod region Anatoly
Petrovic, p. banishes slime mold of the maxillary sinus in a single session. He gives
the patient to drink a poisonous decoction of sweet and bitter nightshade. The nose offers
bury the juice of the bulbs of cyclamen, and then wash it
infusion of letters. The poison from the slime mold becomes ill, he seeks salvation and
finds him in a sweet infusion. The result is come out by the roots polyps and even
of the cyst. At this time, the person starts to sneeze so hard that the fruit body
fly out of your nose like a cork. Don't need any surgery!
However, we must remember that all healers recommend
use only fresh juices from raw vegetables and fruits of good quality. No
in any case not to take the tainted fruit. Otherwise, as shown, is
use you can get harm. And no wonder. In the last century, scientists have discovered
several types of slime mold, which stimulate various diseases in
plants. Some cause swollen on the roots of cabbage (Clubroot of cabbage), other cancer
potatoes, tomatoes and other Solanaceae (scab). It is possible that such
parasites of plants turn into people. Caused the same pathogen
mass disease of coconuts and people in the African nation of Chad.
DO NOT ALLOW
Hard to get.
The fungus can be years
to live in the human body in the form of a nasal mass, which does not cause a special
harm - says in the conclusion of Lidia. But in favorable conditions it
able to form a fruiting body for 3-4 days. Then fight it will be
it is extremely difficult. Therefore, the task of physicians - in time to bring the mucus out
body. According to Kozmino, the slime mold is very delicate and timid creature
which is afraid of everything. It can be easy to flush from their homes. On the other
hand, he's very trusting - it's easy to get the sweet juice. Why not
to kill slime mold is necessary, and gently to force him outside. If we start to fight with
slime mold, you will inevitably fail. After all, he's a much better person
adapt to adverse environmental conditions. With a strong cold,
the absence of food, the pressure drops, high doses of radiation and such
the scrapes, the Plasmodium transforms into a sclerotium - thick solid mass in
which cells are like in a lethargic sleep. In this state, they can
to be decades - without food and water. For example, the famous case:
the sclerotium of fuligo have lain in the herbarium for 20 years, and then suddenly came to life. Here
why Kozmina believes that to treat a tetracycline disease caused
chlamydia is not advisable. These parasites die while other parts of slime mold
remain. But he "fright" turns into a sclerotium. A similar effect cause
and many other medications.
It is very difficult to revive the sclerotium in the human body, so
it is not necessary to bring the poor slime mold to that extreme. Better to please him,
slowly surviving from the body. For example, bring the mushroom (and yourself) a glass of
bitter wine, relax with him in the bath and then to part, wishing
goodbye lightweight pair. Do not take these words as a joke. Because the Russian people from time immemorial
all ailments were driven out in the bath. Say, the great commander Alexander Vasilyevich
Suvorov advised the soldiers to sell the latest boots, to drink in the bath glass
vodka.
Of course, I urge to do this often and without any
cause, when you and so healthy. But if not a joke was sick, then you probably
bred of the slime mold. And it's time to kick him out according to the method of Suvorov or any other
your people's way.
Recipe entice fungus lycogala from the nasopharynx:
1) 2 drops of tincture of nightshade sweet-bitter 50-100 grams of water to drink
on an empty stomach;
2) after 2 hours drip into one era<
managed.
AGAIN, TRICHOMONAS!
to recognize.
mycelium.
mycelium.
rose.
of the tumor.
STICKY, TOADSTOOL!
any mucus.
DO NOT ALLOW
Hard to get.
vodka.
your people's way.
in principle, nothing new, moreover, this is clearly not the whole picture but part of it and a bit one-sided position (in the article), but some of the details in this form have not previously been known. In short, for the greater perception of the problem and more detail is very useful IMHO.
http://newsru.com/russia/17jun2015/medal.html and others will continue to look for "genetic disposition" despite the fact that data about Ralph / Lohovskogo or is there an Italian doctor baking soda treated patients in the later stages - it's all there in the network and known very very many. It is a pity that the stereotypes of hard to break. The better that there are still people who do this and devote a lot of time.
In this case, the scientist is probably very good and intelligent man, but he's blinkered by official science.
I wanted to write that was the old traditional methods of treatment of advanced cases of cancer stafilokoccom removed from the TSB with the new versions (previously was in the encyclopedia as articles) and search by Yandex gave an interesting forum http://rak.flyboard.ru/topic443.html
Well, I like a healthy is not necessary, but it was full of people, as I understand, who defeated the disease and people's experiences. It is certainly not our party, where more about cleansing and healing, but still. There can be a lot of useful knowledge.
On the forum one of the most respected leading (nickname "Petrovich") wrote the book(several volumes) the "reasonable Man" S. P. Kurenkov under the name "Dr. Zdorovenki". In raspolzlas. Recommend.Михаил_ wrote:interesting forum http://rak.flyboard.ru/topic443.html
\He himself in his youth "was cignoli" stomach cancer. Then he, the engineer, got into the topic and found that of.medicine nifiga not know that treats. Now doctors on the subject advises.\
