You can, but why?
Advice from Andrei Patrushev
Ridge
You can, but why?
You can, but why?
Welcome Andrew, THANKS for the reply.Well, what I don't have EPILEPSY it is one hundred percent,that is SIGNIFICANTLY degraded blood circulation in the head but it is a fact,but UNLESS it is a direct contraindication?And the most unpleasant is that it is not in the attack and the attack itself was not and it was here that(and this is repeated every day now until take Relanium)namely:I Wake up Wake up the world and nothing special about normal paint normal thoughts in my head,but once three hours and this is the time when I spent an extreme session,then in my mind something starts to happen that is STARTING to grow as if the brightness of the surrounding world,thoughts begin to swim as typically as I accustomed to and begin to uscertsa,and like THEMSELVES are NEGATIVE thoughts at the beginning then and there,but then the brightness of the world around me comes to a HIGHER peak somewhere around seven o'clock, and then the thought came that it's all over here and die this is the end.I like squeezes and the body just happened all down,and reaches that AT the peak,I realize that I'm not the body that I was so MUCH more and that would now not happened, I REALLY nothing threatening,but at the same time AWARENESS and condition, somewhere in the depths of my soul, showing UP the terrible sadness and I that is the identity and what not?It is very difficult to explain this condition but some I can explain it this way:with one of my left side I am not afraid of ANYTHING and just SuperCab but the world around me,and the other on the right side of the body I'm AFRAID of everything,and most importantly sudden death.And I at that time and now CLEARLY understand that it is a CLEAR contact with my astral body but WHY I Need IT so the physical body was so afraid.Consulted with Kuchinawa he said that firstly there is NECESSARILY a deterioration krovotoka and even if the reason is not in it then it does its job,esche, he suggested that since I took some time drugs that are inhibitors of both serotonin and epinephrine(particularly tramadol) and the peak of the action just had those most of my watches which are written and time from the last medication passed nothing at all it is APPROPRIATE to assume that the brain had based such as and even enhanced it!and I am inclined with this assumption to accept,as assumine that happen to me after the session WELL, VERY similar to those of assessee which was at the peak concentrations of these drugs.But how, then, WRITE what alfaria may be applied even DURING the application of such drugs?What he referred to the fact that everyone has their own reaction.Question:do you think that the brain is indeed able to STRENGTHEN their existing mental state after taking the TRAMADOL(since it is a component inhibiting norepinephrine)?But if this is so then how calming and relaxing effect of alpha rhythms and the possibility of JOINT use of drugs and alpha rhythms?Thanks in advance for your answer.<
Passer-by
Attacks can occur a variety of diseases.
Drugs no rational explanation are not...
Welcome Andrew and thanks for the reply.And now about the fact that you call dope:as you told me when we WISELY and RIGHTLY protested about Phenotropil compared to amphetamine:"WHAT is PHENOTROPIL and NEAR him LAY,"and I will in turn argue that TRAMADOL NO DOPE weaker than morphine in it :6,000 times,and it is only a partial AGONIST of opioid receptors.I was assigned to be my ATTENDING neurologist in connection with the POSTHERPETIC neuralgia(probably you don't need to explain what excruciating pain it causes)a recipe(and not red)in the dose of 2 capsules per day,but I drank it in just 1 capsule,and furthermore the drug VELAXIN the most popular antidepressant it's the same tramal only "obezdolennyh"in terms of the effect on opioid receptors(it is not quite true obezdolennyh),so we can safely ASSUME that I JUST take a STRONG ANTIDEPRESSANT with analgesic effect.given the fact that the West and tramal is prescribed for depression accompanied by severe pain syndromes.But given the forum RULES that we do not discuss here the influence of psychotropic drugs these remarks I will limit myself,Today my question for you is EXCLUSIVELY and only on the topic of MM, but rather on INFORMATION related to MM.So today I got MORE or less plausible explanation about WHAT happened to me these days and most importantly why and WHY and here is the place to be MY way to say VERY little literacy in terms of understanding WHAT actually the mechanism of action of MM.so was CONFUSED in what and why is happening to me I went to the doctor who suggested I be treated for MM under his control,great was my surprise when he said quietly мне6а I KNEW you were coming,considering SPECIFICALLY for your problem you can't handle yourself,at least at first.and I had to agree with him and the first question he asked me was:do I know the MECHANISM of action of MM on the brain and exactly WHAT is not PURELY physiological and ENERGY change brings with it a change in frequency,but the MAIN thing is not about that and IF I KNOW the difference between how the change occurs in a completely MENTALLY healthy person, let's say someone has my kind of problem.I said that the answers to these questions available to me in the MOST General terms.In General, according to him overlooked the fact that if you change the OUTSIDE frequency brain frequency brain changed at the LEVEL of perception of the CONSCIOUSNESS of the individual that is of a PURELY physical range of perception, the CONSCIOUSNESS begins to perceive the world that is all the space on a different frequency THAT is happening as if in simple words moving the mind of the INDIVIDUAL and accordingly the mind on the ASTRAL plane with the result that there is a change of perception such as we describe on the forum the depth of focus flowers in the audibility of sounds, and the like,KNECHNO someone more, someone less!But according to him came out of that FIRST with what vstrechaetsya THERE people is with its own ASTRAL mind and HE is not a man in any way has the KNOWLEDGE and capabilities of his ASTRAL body in its entirety but only in part on the lowest level .That is a man with a SERIOUS internal problem such as a neurosis of obsessions(intense) about whatever he was thinking during the SESSION, according to the doctor anyway after a while will be embroiled in the internal conflict that is ALL his obsessions he will have to work in the HERE and NOW,but only in the ABSOLUTELY new conditions of the intermediate astral plane in which it moves the ALPHA rhythm,but here it is necessary of course to mention not everyone and not always such a MERGENCE of consciousnesses,but according to the doctor just in people with SERIOUS mental problems, it it happens often,but only in the States where they sell MM people in DETAIL and correctly explain WHY and HOW the EXPENSE of what IS happening to them and a BIG rolein played by the Robert Monroe Institute.We have no ONE explains limited by the fact that only the psychiatrist and explain to you all!And sorry Andrew, where the average psychiatrist KNOWS all the ins and outs of what process is launching MM?Only very experienced and not a psychiatrist and TRANSPERSONAL psychologist with GOOD experience!And find this is VERY easy.My question to you Andrew and all the same on what is on the website so little information about what I told my doctor?And I certainly understand that it is completely safe to use a MM can only be completely healthy person WITHOUT serious internal conflicts,such as psychoses and neuroses.But in the States(and my doctor's been there)has accumulated experience in the application of MM for people EVEN with mild Schizophrenia with the right medication and precautions,i.e. which and how many drugs can or cannot be used with MM,and similar data.after all, for people with PROBLEMS of SELF-application MM WITHOUT such KNOWLEDGE and information can be VERY dangerous(to put it mildly)for people with serious problems in the form of PSYCHOSIS or severe neurosis can sometimes be VERY negative impact on their mental state and it is MUCH worse.So why not attract some Knowledgeable transpersonal psychologist on these matters,may be paid,because the conventional shrink very little can help in a similar situation.Thanks in advance for your answer.<
Hello, Andrey! Advise, pliz, for reincarnation therapy disk or program disk. But we should not just climb on past lives, and the situation is such that you want something to pull out, not very pleasant. Know what you need to haul, you know that it is very unpleasant, so broken... and should be pulling... What would you recommend? Thank you!
Olya.ru
Hello.
Alas, I can not advise anything.
Hello.
Good day Andrew,I am very sorry that you ignored my appeal to you about the ALMOST complete lack of UNDERLYING REAL mechanisms of action of MM,i.e. the information which REVEALS not a purely physiological processes.As monamine or neuropeptide produced and how the brain as a result of exposure to the ALPHA rhythm and that are already the consequences of those CAUSAL but these ENERGY processes can even say the LAWS which reconfigures the brain and that is VERY about available to me the understanding I described in previous message to you and that are really PRIMARY.Yes, of course, COMPLETELY mentally HEALTHY or having a VERY minor mental disorders(such as neurasthenia or seasonal depression)people MORE know and do not need to AGREE with the fact who can TELL me what MM was created for a FULL so to speak mentally to people and I know this and argue with that I'm NOT going.Yes it is,but people with serious mental problems so to speak is also POSSIBLE to apply MM only the process is MUCH more time consuming and complex and most IMPORTANTLY the INFORMATION and costly.Because according to my doctor in the States where zakupayus devices developed and successfully schemes are applicable for the treatment of SEVERE NEUROSES,psychoses and even in SOME cases of SCHIZOPHRENIA,well, I agree in terms of SCHIZOPHRENIA is an extremely complex process which according to my doctor is only in clinic.I understand that we have MM the device is brand new and no such experience can not be but there it is and PERFECTLY described.There's a PERFECTLY non-secret data which drugs mostly and in what doses are applicable and in what time intervals.Why this information cannot be provided to those who wish as I'm looking for?Yes,I understand no one will take otvetstvennosti and that there is someone in absentia(except vitamins)to recommend,but you can at least LET those who have such problems about the material that has accumulated abroad can be give some reference,can be to create a thread in the forum in which to refer interested persons to the information that has been ACCUMULATED in the West,WITHOUT any sort of specific RECOMMENDATIONS,and let them do and razbirayutsya if they need it and maybe someone will need and people just SAY, no you can not you when you receive psychotropic drugs to use MM,and okazyvaetsya POSSIBLE and even necessary and this experience has SUFFICIENTLY accumulated in the United States,England and Israel where tranquilizers ID are used as correctors of the problems which DEFINITELY will raise ANY session in a person with SEVERE disabilities.Yes Ansel Dr. top-level advice but it is SO expensive for me that I gladly did the research on different kinds of resources containing such information.You say WELL, we'll give this information where people will find doctors PROPER level?I agree a difficult question but the ladies at least will be the selection will be INFORMATION and not think that everything pustatina in all serious,but this is not so not all of us morons and psychopaths are ready for everything at breakneck speed, many will take note of would study and then draw conclusions by them to be treated or to seek TRANSPERSONAL psychologist,but at least the person will have a choice.Generally one I have for you a question now,I hope you'll answer it:THERE is such experience in the WEST is lying to me or my doctor?Thanks in advance for the answer!<
Good day,THANKS for sharing Natalie!As VIDIMOMU he decided not to answer my question.And something more about what you write,where and what to look for in what so to speak direction.Thanks in advance for your answer.
Дмитрий.Дмтирий
Hello friends! Interested in audio. Loved the reviews of Andrey Patrushev and reviews of Alexander Sviyash is Empire technology.Everywhere interesting descriptions.Waste time didn't much like. Can you help?
your writing style Irritates Mosk... it's hard to read, not what to replyПрохожий wrote:as VIDIMOMU he decided not to answer my question.
changes, Yes, if engaged outside the walls of the concrete boxes... most importantly, who will you adjust? because you can just invent any... I know of a woman walking on qigong in local minisante, they have such a big face the upstarts when they meet on the street-such as "I know (what do not knowНаталиа wrote:why don't You exercise qigong? which is obviously more powerful effect on the psyche and the body as a whole, changing its energy literally for a month or two
and MM now fashionable bare tie so that the result was controlled quantitatively and visually
I have long been answered more than once, and to understand other people's speculations I have no time.Прохожий wrote:as VIDIMOMU he decided not to answer my question.
of Natalia
about the boss (actually a whole section about him is)
viewtopic.php?f=3&t=87
viewtopic.php?f=3&t=937
viewtopic.php?f=12&t=5139
the program for the integration of AVS and barefoot
viewtopic.php?f=12&t=4017
Hello, Andrey Makarevich. I have an exam in a foreign language, where there is an oral part. I get very nervous in situations when I know that I personally appreciate (writing assignments such reactions do not cause). Tension in the body, shaking, the fog in my head. Are there any techniques that help remove/weaken such a reaction? What techniques can be applied to? Have Your CDs and MM, I often do.
Dear Andrey Vadimovich,tell me please,what is the range of frequencies recorded your CDs from the lowest to the highest?Want to know what headphones range ideal...
Дмитрий.Дмтирий
Hello, Andrey! Started to listen to the program: Conductor 05-00 in the morning and Healing night at 23-00. After auditions 15 days, during a break what will advise a program to listen to? Want to listen to 14 disks. Thank you for your attention.
Sappho
Hello.
This technique of anchoring a desired state. The simplest is while working with mashinoy calmly repeated himself, "I am calm and focused", or "I are calm and collected", or etc., etc.
Then at a critical moment, when You have signs of unrest should be in the same tempo a few times to repeat this phrase.
Hello.
Stasevich
Headphones with a range of 20Hz-20kHz.
Dmitry.Dmtiry
Depends on Your goals...
Thank you.Another question.What color audiostrobe points better for the respective discs:Healing,Guide,Hypnosis and self-hypnosis,inner voyage?
I found that the endorphins - white.
As far as the regime of colortrac universal in this sense?Thank you.
Stasevich
Universal colors - white and red, still a good choice of red-blue (Indigo).
Дмитрий.Дмтирий
Hi Andrew! Want to strike memory, attention and concentration. You need to work. Can not in time to react to the questions and after some time.Андрей Патрушев wrote:Dmitry.Dmtiry
Dmitry.Dmtiry
Then Star traveler, a vacation is a Massage of the Brain.
