Small offtopic.
Алекс С
Has thanked: 2 times
Been thanked: 7 times
Re: Small off-topic.
Post by Алекс С » Tue Apr 28, 2015 15:23
I.e., worldly logic, if the reason is nerable, and applies the Wheel, the rim may be of poor quality and the distance from the drive may not be the minimum but 5-10mm
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Tue Apr 28, 2015 15:37
it's better than no rim at all
Алекс С
Post by Алекс С » Tue Apr 28, 2015 15:48
Thank You, Peter!
НОВЕЛ
Post by НОВЕЛ » Wed Apr 29, 2015 23:34
Michael_
Kindly tell me:
fan to auto the upper and lower lids is best done from steel?
If so the engine can be mounted directly on the lid of a triangle like on this link.
http://rinatshay.chat.ru/Rotator-SCSI-15k.html
Алекс С
Post by Алекс С » Thu Apr 30, 2015 16:28
Decided to say his thoughts out loud, support or refute, please. That's my guess. It seems to me that the Chopper without Wheels and Spinner Wheel – two fundamentally different device.
Chopper without Wheels, being close to the object or via a physical link affects "Muscari" (which, as we know, no) "as it should" – increases the value of the parameter "quality", for example, restores health, provides a "front-loaded", hones blade, increases the octane number of gasoline and the efficiency of the combustion process and restores the batteries, reduces the aging of metals, etc.
Chopper without Wheels is a source of energy, devices on the Subject, can also power the processes, goals and social groups. But Spinner with Wheel with a mental command, the Wheel is unable to sharpen a blade, to increase the octane number of gasoline, to restore batteries.
In other words, for example, one spinner, mounted directly on the car, will do more to fuel economy than ten fans in your home, each with a Wheel, for example five of which are mentally tuned to improve the quality of gasoline in the car, and another five to improve engine operation.
I.e. these are two different device with different purposes and applications.
Correct me if I'm wrong.
Also, maybe I'm wrong, but due to the fact that the Wheel works great with the transformer stations, as well as photos powerful energoobektov, for more energy to feed the person, social structures or devices, it makes no sense specifically for Wheel to make a turn and wasting electricity. The chopper must work as a Spinner.
Who thinks that?
PS Michael, if not difficult, answer a question in PM about which I have now the instance I1, and what a shame, the device is, and use can not...
Post by Михаил_ » Thu Apr 30, 2015 20:07
НОВЕЛ wrote:Michael_
Kindly tell me:
I have never made of steel, some made of wood for example. well, out of plywood (for the second example, from Micarta...
well then you need the black steel, pure metals for which there can be a leak.
In General I do not like "steel the idea of" purely intuitive.
НОВЕЛ
Post by НОВЕЛ » Thu Apr 30, 2015 21:56
Perhaps I misspoke, according to Rinat iron, which is good magnetic .
Want to do without the iron triangle just to the bottom of the engine.
Micarta or PCB I have.The laminate that is in doubt is sawdust little crammed in there plus the upper part is he's always plastic, synthetics.
And the second question . Drew attention to photos of fans of Rinat all have a gap in the top cap.
That would be on disks did not get dirt can be upper and lower lid rims to miss the mark"autoerotic-seal" and do I need holes for air capture.
This will not affect the tightness of the Manchester United thread?
Post by Михаил_ » Thu Apr 30, 2015 22:11
all these questions do not to me, I was not interested in such primeney, I go to the machines on which it is customary to glue back nakleiki FFE :) and that view 365 days a year, dirty :) and the engine -nopiracy :) well, sometimes on the cars.
I used the fan only for purposes other caps not supplied, the idea for the iron lids't like me, I they were usually on the Board (plywood or solid masses).
Алекс С
Post by Алекс С » Fri May 01, 2015 21:24
Michael, please tell me, water and 1 useful without further 1?
Not everyone wants to use the device, but water to drink consistency :)
How do You assess the lifetime utility of the plan to bring in a bottle anyone?
Post by Михаил_ » Sat May 02, 2015 0:28
I do not know, have not studied, I don't think she works for a long time. (well, a few hours). The usefulness of perebarschivat (as with I1 rate not constant)
Алекс С
Post by Алекс С » Sat May 02, 2015 12:57
Thank you!!!
Аннаель
Has thanked: 36 times
Been thanked: 3 times
Post by Аннаель » Sat May 02, 2015 14:14
For small I1 the report. The subject is over 50. Entered the convent with pedicone eyes after 8-10 times, the doctors have said only cut. On the head of course valid, but it seems pretty good. From the application on the face have fewer wrinkles, was fun with one more the other less. He began to withdraw, a wart on the sole. She certainly could not care less, but a very good effect, oddly enough, at the neckline! The skin was from a person in a very poor state, pulled up by ASIC impressions by 40%. Loves to be treated the cat, he asks, the cat had an operation on his head. Good help! But the skin on the hands of girls can not be cured, the effect is almost there.
Post by Михаил_ » Sat May 02, 2015 20:19
The wart is treated with water with ASD or net wrap with ASD for a few minutes/tens of minutes. How many viderit.
Skin girls are probably not so simple, you have to understand the physics of the process and the reasons, the reasons may be quite wrong, that treats the device, such as a hard psychosomatics. It looks like a dry? in which parts of the hands? how long and than tried to influence ? under what situations is worsening?
Аннаель
Post by Аннаель » Sun May 03, 2015 12:37
Thanks Michael! This is my daughter. Yes, in the hands of the strong dry, red and even covered with small red veins. The problem is only on the hands. All this in the cold season. Thought that this soap (doctors said), but no soap is not much better. Found a good cream and the heat is now almost all gone. This year is particularly strong skin problems! Perhaps the stress of moving to other city. Changing schools, homes.
Overall a very healthy and balanced child. We live in Austria. The doctors here treat - "go and don't pretend you are healthy." Know friends and acquaintances, here very low level of medicine. The good doctors of the unit and they can't get in. Although very good everywhere equipment. We are treated themselves. My daughter is 9-years old, from childhood knows that it is impossible to eat at McDonald's and other similar products. But often eat pork from local farmers.
Last summer was in Russia, went to the Russian resort. We certainly made to be examined. To my words that the child is healthy, the doctor said we have no healthy children. And with hands in the summer everything is fine and after the examination she had to admit that there is a healthy. I wondered about that, but when I went to purchase products understand what's going on. I couldn't buy anything, all was solid EEE. Decided to buy at least drying the child, but of the five varieties nebylo no one without HER.
Suddenly the daughter she brought a pack of crackers, with the words: the mother these are good, and they were really without these components. And all this in a small Ural town. Then we suggested to go to the shops with products made only in this town.
Post by Михаил_ » Mon May 04, 2015 11:43
unfortunately the packaging doesn't mean it's all known on the other product without the instructions on the packaging to attach themselves to the same pesticides and other things....
that can really influence:
- water (impurities/chemicals in it, including the micro-doses)
- the state of the digestive tract (including a parasitic component)
- psychosomatics
- substances in food are not useful to the body.
open secret - on my right hand there is a small spot dry when I returned to Russia. Flying itself takes place. Associated with the combination of several factors, including water and food (even when purchased fruits and vegetables such as organic and expensive).
In particular this is undoubtedly due to the use of fresh juices in the cafe (which is unknown squeezed from any fruit) and other factors.
As we know pesticides are present in almost all store-bought greens, the grains of wheat (exceeding up to 10 times the official tests cost analyses by a different method so it does not fall under the exclusions)., apples/bell peppers, etc....
so one McDonald's unfortunately not a panacea.
I used to have this area on the hand floated only in spring (high water, snow melting, wash off something in the water).
Recommendation - buy Izumrud-SI with reverse osmosis and a mineralizer home and look for potential pesticide-containing fruits and vegetables in the diet (less in summer - there are fresh).
However, the presence of the second party in a child's body (physiological predisposition) most likely is an additional factor. Will be in the Moscow area, go a couple of times on sujok signs to my doctor.
PS the redness which side of the hand? with the palm or the opposite?
Аннаель
Post by Аннаель » Mon May 04, 2015 14:18
Yeah, how many? Thank you, will be careful! Redness only on the reverse side. The skin was smooth, but looking as if it has aged and the color then brown. The water here is very good, you are allowed to drink from the tap throughout the country. Plus is Converter water Grandeval (but not cleaner), there is little scale from such water. And everything else is Yes.... Juices and anything else we almost did not drink, but eat a lot of fruit. My daughter is constantly drinking mineral water, local water vöslau. I will watch, thank you! Food to you at the seminar can after be more sensitive to the causes of the problems.
Post by Михаил_ » Tue May 05, 2015 4:20
Mineral water in glass or plastic ? in plastic - very bad :) there is plastic in the water gives a lot of things.
"The water here is very good" is a joke, because in all countries the norms of the filtration and water purification do not insure that it remains in the micro-not very pleasant substances. Including chemicals washed from the fields in residual quantities. Reverse osmosis (full wipe) it solves, but drinking de-mineralized water is bad, and mineralization is different.... need natural.
Then activator water giving ORP negative water is the youth of the body and blood is useful for the whole family, it's good to just water is not replaced, so the recommendation is to put a reverse osmosis with a mineralizer of type "severynka" and Izumrud-si - remains strongly in power... and this water to drink instead of soda - it really is delicious, I feel that its thirsty. and much more useful, it may be half the role play.
A large part of imported fruits, including Europe - more precisely MOSTLY they are not edible at all! t/e/ You looked at "E" on the bags, but for the raw foodists, this is not true. But the fact that almost all greens are in shops, including peppers, apples, cucumbers - there are plenty of pesticides and other almost all manufacturers. The freshly squeezed juices they are the projection of these fruits... we have, I only buy things that deteriorate and looks homely and has a local region of origin or former Soviet republics - such as "apples seasonal" RF. not waxy, brown on the cut, portatile during storage.
T/e/ here I see on the shelves of supermarkets vegetables and fruits from Europe (or seen to sanctions from the point of view of the health of the nation these really useful :) ) well, even just in Israel and there's more - there's almost no edible then.... and feel I usually do not cheat - there is none.
Fruit Chile/Thailand - more or less. Local greenhouse - with a bunch of questions - some are edible. And put in the fridge and they dry out and don't portitsa at all....
Now in Russia will go seasonal fruit/berries you will have at least something to eat... those that are grown and not processed for long transportation.
Although maybe You too have something not processed, I don't know. But sin (for those spots) on the totality of the toxic substances accumulated from food and water.
By the way, as I said, the leader in pesticides are cereals in particular wheat - all grain = 10 times exceeding the norm (if at all, may be the norm for poisons of this type).
PS here or on my forum who=to off is the correct article about the pesticides in the greens/vegetables fruits. And about the wheat I found in research in the network.<
Аннаель
Post by Аннаель » Tue May 05, 2015 12:31
About emerald think of it, thank you! Mineral water here comes out of the earth, we live on mineral water only drink in the glass. I mostly tap, but from your mug. This mineral water well to residents can be free to collect without gas then. Tap certainly not mineral water, and the usual Viennese water. Yesterday, drove in the Turkish market for vegetables, the taste I did not like. So you buy mostly online store vegetables, fruits. But take more time producing vegetables, cheese, fish sometimes Italy. The Austrians are very squeamish to products from other countries and still like everything to be in their region, and preferably done personally knew the manufacturer. So we used to read that on the bag.... There are cheap online store there are great fruits and vegetables, but immediately spoiled, I loved to take, now I understand that in vain. Fruits are imported in winter, of course, how they have not know, but a lot idim only oranges, and apples local often the bad kind.
And so here is where you go not all the fields run the pack of deer, hares and pheasants and other animals on the roads through the villages in spring generally dangerous to travel, animals, jump, corpses everywhere on Dargah shot down. If someone in the fields, they begin to die, the local authorities begin to crack down on the use of chemicals. So, last year banned the sale of chemicals by the owner.
About bread know not eating for almost a year, the daughter is looking at me is very rare. Husband eats black only from local bakeries. And what about fruit no idea... In the forum you have read that you can soak, the grapes are soaked, it is always imported. Fish and animals are of course grown in chemistry, in Russian villages, this is not (in the territories where there are mom). But what to do with this ubiquitous chemical......
Алекс С
Post by Алекс С » Tue May 05, 2015 16:43
Michaeldevelopers I1 probably wrote the manual for its European customers-doctors, as I understand it, in English, German and Hebrew :) Agree, it is very likely. Is it possible to put here or at least give a link to buyers? Video for the moon looked, but I want more information.
Аннаель
Post by Аннаель » Tue May 05, 2015 17:40
Alas, from Michael or others have no adequate words! I use this same vidio for the moon. While treating a heel, and very younger neckline. If there are other striking manifestations of the device will write.
Галатея
Post by Галатея » Wed May 06, 2015 2:18
Michael I have a question: you need to work with a purpose is a choice, that it is better to buy a deck of alpha-Vit or the Smile of the Cheshire Cat? Working with what deck would be more efficient? Unfortunately both decks can not buy.
Post by Михаил_ » Thu May 07, 2015 1:25
Аннаель wrote: While treating the heel, and very younger neckline. If there are other striking manifestations of the device will write.
Because the blood flow is General, and the body lives a bunch of "animals"
Post by Михаил_ » Thu May 07, 2015 1:32
Галатея wrote:Michael I have a question: you need to work with a purpose is a choice, that it is better to buy a deck of alpha-Vit or the Smile of the Cheshire Cat? Working with what deck would be more efficient? Unfortunately both decks can not buy.
I love animals, what better camera or a crossbow? :) And You why :) ?
The question has no clear answer. Both tools are strong and working, and totally different.
Depends on what you want to do and what your personal character.
Alpha-Vit more convenient for constant daily (gamegarden ) work.
The deck is easier for the strong modification of the self and the world, to find a solution outside the plane of his perception and to create serious anomalies.
So despite what has to be done.
Post by Михаил_ » Thu May 07, 2015 1:41
Алекс С wrote:Michaeldevelopers I1 probably wrote the manual for its European customers-doctors, as I understand it, in English, German and Hebrew :) Agree, it is very likely. Is it possible to put here or at least give a link to buyers? Video for the moon looked, but I want more information.
The developer does not sell the devices but it delivers exactly the same organization that leads with their research, and if a "passport" and will have it for their Euro customers who "buy" the devices on. Yet, as far as I know, dozens of them operate in a network of centers performing under a subscription about disclaimer those that do not have a choice. This allows you to work outside the Euro-certification. As far as I know there are a number of devices in the cities of Russia and Ukraine (tens) about the practice of their use I briefly wrote in the message here.
This is a personal experience of doctors (always successful) handed to me by the author orally.
Other sources unfortunately there is not expected.
I created a small supply of several instruments by the results of stir of interest at the seminar, half of the stock now already. (t/e/ hands up 7-10 people, I ordered 8 instruments, 4 are gone, 1 John 4 will come later in the reserve is still there). What will happen to them next - hell knows, the question of their release is not stable it is not a serial product. So it remains to be content with what we have. I am holding for this reason, in the area of his family stock (and I have relatives now more than 6 devices in different places. Sometimes they break..... while we do that through the author solved but it does not guarantee that it will be 100 years old. And a good thing. so I'm from a new batch one here, too, put aside (a much). It is not a good brand but additionally in many other fields. I appreciate them very much :) but documentation is as is.
ДмитрийКО
Post by ДмитрийКО » Sat May 09, 2015 17:12
Not found specifics about the topic to write. Through the program OM abanazer and specials.means handled himself at the cemetery, the wastewater treatment plant, the police Department, his house, his wife's parents on the left, and the image of the city and district. I will see what will result. I understand it is not necessarily to prescribe what I want from this, I do so treat the area, and in this folder location sign "negativity cleansing and harmonization of the surrounding space" (for example) If my formulirovka not correct I think my subconscious understands what it mean. If my Dorm room to process through the cure program OM and ask the algorithm what would they feel safer (i.e. nejtralizovat negativity, etc.-stuff like that.) so, that would not run for example not to draw the matrix. If so much has been written ASEK on "bookmarks" on the houses and other places for drug addicts. Here to find out the house selling drugs and their special equipment, etc. that they would :evil: Remember processed dump one specific. Will work quietly in this direction. Feel like Robin hood. :)
