Bracelets Life
интересующийсябж
Re: The Bracelets Of Life
Post by интересующийсябж » Tue Dec 10, 2013 6:26
Hello,
I read about the versions 2.5 and 2.7 and for myself concluded -
2.5 increases the number of events, to some extent, this is an increase of chaos.
2.7 increase the amount of energy for the implementation of task events, that is, indirectly affect events.
However, 2.5 and 2.7 have a heterosexual orientation, how to understand it, that is what they have in common?
Thanks in advance.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Dec 10, 2013 7:00
Hello.
2.5 in my opinion is not quite the increase in Chaos (not so easy this task), but rather a manifestation of the demand from the existing Chaos.
I am inclined to 2.7 Neutro shown more Power, but in any 2.x can "show" the whole range of Forces Tenacula, only in a different measure. 2.7 implementing harmonization (finding a dynamic point optimal point of balance Forces) can enhance and Hetero and Homo Forces.
the difference between the versions 2.7 and 2.8 page 1:
Михаил_ wrote:2. BJ 2.7 is associated with the concept of harmony and vitality. It harmonious combination of qualities variation and preserve the succession (stability), i.e. hetero and Homo of the inherent qualities of 2.5 and 2.6. In some cases a good is working with 2.5 or 2.6. For example starting something new that requires innovative and creative solutions, good and useful to use 2.5. version 2.7 is more suitable for the movement of the established course and also as a source of vitality. Will undoubtedly be evident and the quality of maintaining harmony, but in contrast to the tidal forces is the quality maybe not all earn full immediately (experience in the use of new state comes gradually).
the difference between the versions 2.7 and 2.8 page 2:
Маг.нет wrote:Heterosexual Power - All colors of the world.
Hetero is the first fundamental force. It is characterized by the instinct of separation, division and changes, impulsiveness, straightness and initiating role. Her inherent desire everything in its path to diversify, to open, to expand. Its nature – the desire for freedom and independence. Heterosexual power helps to solve automatically, without thinking. She is impatient and erratic, chaotic and unpredictable, operates without any rules, order, rhythm. Hetero force is excessively active, restless, lively, brave and cheerful. This force is always at the forefront, she is spoiling for a fight. "Heterosexual fearlessly begins any action, not having a plan" (Pak, 2005, I, p. 21). Spontaneous and rapid movement Heterosexual lead to unpredictable and unexpected results. Heterosexual power has been working tirelessly search for the next change.
Power natra - Harmony and beauty.
Neutro is the power of harmony, mediation, compromise. She stabilizes, maintains, enhances, connects, helps, integrates. Natro has an endless supply of possibilities, properties, directions. Being self-sufficient, it is binding, balancing and coordinating power. "Neutro able to neutralize the extreme symptoms of both Heterosexual and Homosexual, not allowing them to harm, and even use them to create more perfect harmony" (Pak, 2005, I, p. 31). Neutro manifests as an intermediary to facilitate the achievement of compromise. It helps to take into account all opinions, all sides, to find the best optimal solution in any situation. The result is always the practical result. And it's always a successful outcome. Neutro – efficient and economical strength, flexible and adaptive. "It activates, updates, and develops, creates balance and rhythm, is the power of systematization, organization and organizing" (Pak, 2005, I, p. 44). Neutro focused on ensuring the achievements of guaranteeing the development.
Sincerely, MAG.no 〠<
интересующийсябж
Post by интересующийсябж » Wed Dec 11, 2013 7:55
Thank you.
Марио
Post by Марио » Fri Dec 13, 2013 20:48
Michael_
Bought in late October 4 bracelet Panacea, Svetlitsa Super and hooked up the stream a PC(with the option YDF) and the standard modifiers 2 and 5. At first, the feeling slowly but improved. There was a huge surge of strength and confidence. Sometimes even feel just fine. Then I went on vacation to the tropics for two weeks. There first week she was feeling good, and the second began to deteriorate. And when came back to Russia she began to feel just awful, no strength at all no permanent swelling on the face and some rash, wrinkled what it became. Look in the mirror and the impression is as if I suddenly got old!!! As if not rested, and all night long the wagons were unloaded! Is it possible that the bracelets had somehow passed out, because the impression that they do not work? Or maybe it's overload from broadcast (modifiers 2 and 5 together You are recommended to put)? Of course this can all be attributed to acclimatization, but in the past (before using BJ and other artifacts) I flew in the same country and nothing like this was observed!
С. Альбатрос
Post by С. Альбатрос » Fri Dec 13, 2013 21:54
Maybe it's cleaning so manifests itself? At me such reaction was, after the first ASD, leather gray, bruises under the eyes, wrinkles, then went and became better than it was. Fatigue can also be due to the intense processes in the body, to restore a lot of energy is required.
Post by Михаил_ » Sat Dec 14, 2013 10:23
1. bracelets can't stop working
2. perhaps the Albatross of law
3. I wouldn't rule out the other, a purely physical ability. Is a specific helminths. In the tropics is easy to obtain for example just using the soles of the feet (known precedent). All the description quite fits.
I'd consider both versions
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Sat Dec 14, 2013 11:39
Михаил_ wrote: I wouldn't rule out the other, a purely physical ability. Is a specific helminths. In the tropics is easy to obtain for example just using the soles of the feet (known precedent). All the description quite fits.
If you want to specify, then the money is easiest to do in the Center of "the forerunner" Ugulava on art(like, 100 bucks. there are about 200). There and liquid filth in options against them will also ring out on the performance.
Post by Михаил_ » Sat Dec 14, 2013 14:46
By the way I can't explain it, but some relatives, just under the stream there is a complete disappearance of worms.... horseradish understand why (well, there is no specific for this cases), felts overall condition of the body, in short I can not yet understand what led to their disappearance. Study statistics further.
Post by bofara » Wed Dec 25, 2013 23:26
bofara wrote:children hildren 'quality' is without bracelets and parlor, for example: One child returned the empty box from the tablet to the store and asked for their money, because as the boy said he lost the tablet. The money was returned without opposition. :)
Well, I have personally witnessed how they brought money some women - she had half a pack of coffee, and then decided exactly what this kind of coffee not like it and returned it - money back.. :lol:
When discussing with colleagues was telling me about some man who bought and successfully drank a pint of quality Western whisky, and then returned and said that they didn't like.. of Course the money was returned..
By the way, about the woman-Yin, about which he wrote in the topic 'strange anomaly' yesterday, and she, hearing these stories, told my mom to put it back almost coffee /pack a pound :shock:under the pretext of "not like". Of course returned the money. :lol:
Максим Антилов
Post by Максим Антилов » Sat Jan 04, 2014 19:37
Michael_ and if any of Your products that is able to fight with hair loss of the head? I can say for sure that parasites, infections, etc. etc. is excluded completely!!!
It turns out the reason may be just hormones or stress! Given this what would You suggest?!
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Sat Jan 04, 2014 19:58
bofara many shared their experience on this problem on Ω
Post by bofara » Sat Jan 04, 2014 20:24
I'm /my age 33 years/ still with hair on the head, i.e. it is a normal body hair /a little vampiric, but that's normal given my genetics/. :)
The most versatile the recipe is, IMHO, often do magic, although if you look Zelazny or sit around :?
Любознательная
Been thanked: 7 times
Post by Любознательная » Sun Jan 05, 2014 15:30
hi,I've read that the bracelets work very well in the water, before the new year was taking a shower and so rolled up that BJ hands forgot to remove, washed with BJ, and when they realized that they didn't shoot it,chose to work mentally under the streams of shower, first imagine that the water washes away from me all negative and then mentally integrated modules to different situations and make wishes, desires long-term,not sieminutnoy, of course wished for 3 wishes, I think if I did, maybe it was my bad and I can not get anything from the hidden,but hope still remains.
Максим Антилов
Post by Максим Антилов » Sun Jan 05, 2014 17:18
Михаил_ wrote:everything has many facets.
For example, the authors of the drug Board, make a special version of biopeptide for baldness. Usually at the point of sale it is not, it is necessary to order. They say that helps.
I mean, what the causes may be ancestral, karmic, biological... and maybe a clever combination, including biological causes transmitted through the maternal line - easily. Since the set of Microbiology, in a balanced manner is transferred to the child and not just about him, this set, say (those who study this issue) that he's not improving, i.e., in this parameter, the child receives the status of the mother or one step worse.
I.e. it is possible that the disease is included in the genus. And maybe another, but biological factors I would've cleaned it of ASD, as recommended Albatross bioseptin, course taking of wecoma and so on.
The panacea of youth standar is a great powerful thing.
But I recommend to buy it after, or simultaneously with a pair of 2.1 or panaceas and start using them.
For the reasons stated above.
Michael_Found Your quote about the hair loss, where You suggest to the woman to drink a course of Wecoma and use "Panacea youth standard"! Tell men this advice is relevant, because we have the cause of hair loss in the increased production of testosterone?
С. Альбатрос
Post by С. Альбатрос » Sun Jan 05, 2014 18:59
For men is also quite relevant, you can still add ASD courses. There is still ointment bioseptin specially for hair the manufacturer is the same as that of watoma, but it seems you need to order them separately.
Post by Михаил_ » Sun Jan 05, 2014 19:53
Loss - listen to the lecture Lelyakov, from infection, not from testoterone (also invented), like most of the "age" of the deviations and the outwardly visible factors of "aging" - it's basically food,humidity, air, water, infections, parasites....
well, the psychology, the mentality, which does not go to recovery quickly enough.
Yes, a vet, or rather bioseptin, there is a special from of baldness which is done under the order.
Call-write to the manufacturer, the regional dealers in stock it usually is not, find out how to order.
And the rest (on my recommendation) all of the same type...
p-youth - well it is described, affects the most important factor is the mental attitude to life and self-regeneration including.
Post by ФилиНН » Sun Jan 05, 2014 20:23
And exclusively in addition above:
"How to grow new hair in just 120 days"
"I can guarantee to anyone without any reservations that if he is in the process of hair loss, it can halt the process and reverse it from the moment you begin to follow my recommendations.”
So says an American expert hair-trichologist, author of the sensational methods of restoring hair growth. A sensational all – the simplicity, effectiveness and, finally, the identity of those who were among the clients of this expert, stars in an American movie, television and sports, such as canadian hockey player Phil Esposito, host of the TV show, Phil Donahue etc.
The technique allows for 6 months of its application for 5-10 min daily to start growth of new hair WITH PARTIAL BALDNESS. It does not require any medication and observation of a doctor. It is not excluded that with longer application of the method of hair growth is possible even on a BARE SKULL."
Nahum a STISKIN
Google and biguglia manuals. Harm there's, like, no, this does not fall out. :)
Massage of the skull is sensational. :) :)
Post by Михаил_ » Sun Jan 05, 2014 21:53
well, it is highly likely that effective... I would still pay attention to anti-fungal therapy...
by the way is bioseptin think it is possible to use other drugs. (divorced ASD, the same thiosulfate - of Bopara wrote a review, the same citrosept TD).
The truth of the ASD-baths I have vremenno comes a funny effect - it appears gray at the temples, well the piece is visible,i.e. the individual hairs, I understand that this is due tems that not all is emitted through his feet, but something across the head (from the cold of negativity that ASD cleans), then the effect is to a large extent takes place. Many times I noticed a direct connection.
Then even thought you know how to restore the natural color to anyone, but then a little time passed and the algorithm in my head to lose (attention has shifted, details forgotten).
Ie there is probably all related to the type and direction of flows and secondary factors (consequences of a purely biological).
Максим Антилов
Post by Максим Антилов » Sun Jan 12, 2014 21:22
Михаил_ wrote:3.0 S++ more massive version, which in addition to the multilayer laser processing caused by the composition containing rare meteor brotowasisto - chondrite C1 category with a unique power characteristics.
Michael_ found in the description of the BZ 3.0 S++ that it caused the meteorite substance. Wanted to know if You have any meteorite has unique energy characteristics? Are there any meteorites that negatively affect energy and dangerous to keep at home? Just at home I have a piece of meteorite, so ask!
Post by Михаил_ » Sun Jan 12, 2014 22:45
the answer to this question is given here repeatedly - no, not any.
if I remember correctly the terminology, what we use is a class of chondrite "C1", i.e. not past the thermotransformation in the process of falling (e.g. the internal part of the core of a larger meteorite, where the substance has not been pedersena temperature of transformation).
Others only hurt.
Максим Антилов
Post by Максим Антилов » Mon Jan 13, 2014 0:16
Михаил_ wrote:the answer to this question is given here repeatedly - no, not any.
Others only hurt.
I have a fragment of an iron meteorite (Sikhote-Alin meteorite), if heard. Judging by the melted surface he was hardly part of the core-rather the shard surface. As often have to deal with it what would You suggest, get him away or he's the particular harm may cause?
Post by Михаил_ » Mon Jan 13, 2014 0:18
it was only about using in 3.0, for this condition it is not suitable.
Галатея
Post by Галатея » Wed Jan 15, 2014 17:53
Hello Michael. I have a questions for you: 1. Can I wear the Bracelet of Life 2.6 such disease as obsessive-compulsive disorder? 2. If you can, as in this case, to correctly formulate the goal for recovery? 3. After I want to buy the pendant "Panacea" or in my case, it is better to start with a broad bracelet "Panacea" as it is more weak (so that the psyche is not immediately received a powerful Overdrive)? With Respect To The Galatea.
Post by Михаил_ » Wed Jan 15, 2014 20:13
1. possible, but why? take a 2.2 or a panacea.
2. no, just wear.
3. Yes, it's like....
Галатея
Post by Галатея » Thu Jan 16, 2014 0:52
Thank you very much for the reply. I will listen to you and buy yourself a Panacea. Tell please through what time after the start of wearing the bracelet you can move on to bracelets series 3.0?
