Advice from Andrei Patrushev
Post by Андрей Патрушев » Sat Jan 19, 2013 16:00
Roman Logosa
Yes, track superbacana you can do more than 45 minutes a day, but the Integrator must listen one time at the end of all lessons.
Роман Логоша
Post by Роман Логоша » Mon Jan 28, 2013 17:32
Andrei Patrushev, In principle, everything is clear on the program "Ultramag". But one clear thing is that all of it individually
but I would like to know how long will it take for the brain training that he was actively working without the use of the program.Perhaps there is already some statistics at least average in terms of brain activation to work without the disc.
Post by Андрей Патрушев » Mon Jan 28, 2013 22:37
Roman Logosa
About three weeks of regular classes.
Ярый
Post by Ярый » Wed Jan 30, 2013 7:13
Andrei Patrushevas You see, the famous test of "Dancing ballerina" http://ggeizer.forumbook.ru/t265-topic really good reflection of what hemisphere of the brain is currently more active? Whether to use this test as a simulator (figure to expand in one direction and then the other)?
And another question: in MM InnerPulse session p06 and p08 are considered "pravopreemnitsy". The effect of them appears only briefly after listening to or if to work out their rate in 21 days, you will remain a training and right brain will work more actively?
PS also, in parallel with these sessions, working with Your CD "brain Massage" to synchronize the hemispheres. I.e. in the evenings working with sessions in the morning with the disc.
Post by Андрей Патрушев » Wed Jan 30, 2013 16:52
an Ardent
It is unlikely this test, IMHO, reflects the activity of the hemispheres.
The relative activity of the hemispheres functional and depends on the current task. In any case (on any task) hemispheres work simultaneously and systematically.
Artificial misalignment of the hemispheres with the help of machine for a healthy brain, IMHO, is harmful. For example, with a strong dominance of the right hemisphere You will have difficulty adequately expressing their thoughts in words, deteriorate the immune system. Can begin to develop a fungal disease on the left half of the body...
Ярый
Post by Ярый » Wed Jan 30, 2013 22:21
Understood. But to be honest, still will continue to work on the above scheme, the reason I came... I Decided to trust my instincts. If you notice any unfavorable changes immediately unsubscribe here!
Прохожий
Post by Прохожий » Thu Jan 31, 2013 23:47
Good time of day.Andrew I have a question.Not so long ago, I was prescribed treatment for the liver,and all would be well but his complex is an ANTIDEPRESSANT of TRITICO,is a drug which is probably not even an antidepressant and a tranquilizer as it has some alpha adrenoblokirtee action and a very mild antidepressant that is UNLIKE other antidepressants PRACTICALLY does not affect dopamine and norepinephrine,and serotonin it affects only those types which do not cause alarm.And appointed me his in the MOST miniscule dose of 1/5 of the smallest therapeutic.And most importantly that without it the WHOLE scheme will not work.My question is:CAN I use MM in the power saving mode, the I perceived a light session.I know that YOU personally do not approve of the combination,but still,is it possible, or at least what could be if I COMBINE so to say MM and this drug.Saw that here in the forum primenyayut MEXIDOL but by and large it's not just the drug.And if this antidepressant, thus increasing the content of SEROTONIN by preventing his opposite number for a longer time,MEXIDOL that just increases the content of dopamine in the brain.Know what light tranquilizers the type of Relanium in miniscule doses it is permissible to combine and how all the same with THE so to speak light-depressant?Thanks in advance for your answer.
Прохожий
Post by Прохожий » Thu Jan 31, 2013 23:56
Yes, and another point at the same time, so to speak,BECAUSE the device ALFARIA I KNOW it is possible to combine with all but THE strongest doses,that is, with the trunks and anticipate,why so strict with MM.What is the fundamental difference?
Been thanked: 2 times
Post by ЗОМБИ » Fri Feb 01, 2013 0:20
will real clever... you can try to add to a proven scheme Mexidol+Cerebrolysin still Phenotropil... and alfario simultaneously with MM... don't forget tripreport :D
Прохожий
Post by Прохожий » Fri Feb 01, 2013 12:10
THANK you so much.He is trying to I don't decide but I think that those who decide on it WILL be very boring if he do that THEN it will be.No my question is much more modest.And I would very much like to hear the opinion of Andrew SPECIFICALLY on my question.
Post by Андрей Патрушев » Fri Feb 01, 2013 13:28
Passer-by
You can, but the drug is organize in two hours or three after machine.
Really no difference, in terms of a combination with the drugs for machin and alfaria no...
Прохожий
Post by Прохожий » Fri Feb 01, 2013 14:55
Thank you very much for the reply.I understand you about time here I was lucky as TRITICO in my case is scheduled for the night,and I can hold a session in its best time, namely 4 hours.Esche's what I wanted to ask.I understand that the action of MM in two words can not explain but all the same, if I understand correctly that MM generates so to speak the alpha waves in the first state, the body ITSELF thinking where and what to subtract or add I in the work plan serotonin and other systems, not just makes the body hard to work out exactly serotonin and ANOTHER point in the instructions to alfaria read about that along with all so to speak RETARDING relaxing and calming neurotransmitters -IT: generates and ACETYLCHOLINE and I know he's responsible for the excitation of the CNS and for anxiety depression or neurosis is NOT needed.That's what puzzles me the most as one thing the betta overabundance of endorphins or metenkephalin or even GABA systems.they called effects think anxious as won't harm you even in excess but QUITE another noradrenaline and ACETYLCHOLINE is a completely different effect,and even from dopamine anxiety can Oh how to shake down,with a seemingly COMPLETELY harmless tablets of MEXIDOL,which promotes MINDFULNESS so to speak by increasing norepinephrine,because originally MEXIDOL causes robust increases in the PRECURSOR of norepinephrine-DOPAMINE.And as familiarity with SIMILAR effects I have had the most direct.And since YOU said yourself that the difference between MM and ALTARIA In principle, no particular that I'm interested in this account because THEN the effect of ACETYLCHOLINE production possible and using MM.Or I something misunderstood and then I have two options:either acetylcholine DO not vyrabatyvaetsya during alpha session, and only in beta(but seems to be as far as I know alfaria betta sessions no...),or on the contrary induces the PRODUCTION of this hormone in excess this causes ANTI the effect of that is, of stimulating it to become INHIBITORY.Or HE might vyrabatyvaetsya in LARGE quantity, and become as it has an inhibitory mediator.Or is there something else was obyasneniyami would be if possible to know your opinion...Or that is probably closest to the truth at the time of the session when the brain receives signals alpha rhythm is so to say self-regulation and vyrabatyvaetsya what you need and how much do you need?That is, I mean that the ALPHA wave is a self-regulating multi-faceted system.And not that these waves produce only serotonin,this I to not have an overabundance that is serotonin syndrome.Although, in principle, the dose of antidepressant I have a minimal,but still I just in case asked.Do I understand correctly?Thanks in advance for your answer.<
Странникс
Post by Странникс » Sat Feb 02, 2013 23:27
Andrew, good evening.
My grandfather develops multiple sclerosis, the doctors suspected a possible initial stage of Alzheimer's.
Due to the fact that he used a Conductor, then a certain amount of trust to your products is, the question is - is there anything in your range Tool for such cases? Maybe "Healing" ?
Post by Андрей Патрушев » Sat Feb 02, 2013 23:46
Passer-by
Although, according to foreign reports, the acetylcholine when working with mashinoy also produced, but I don't remember - are there differences in frequency, but the alpha state (increased power of the alpha waves, again, in certain areas of the brain) is primarily self-regulation, and attunement all body systems...
Post by Андрей Патрушев » Sat Feb 02, 2013 23:48
Strannix
Hello.
The disks are unlikely to have a significant impact on the development of Alzheimer's disease. In this case, first of all, works well light stimulation.
Странникс
Post by Странникс » Sun Feb 03, 2013 2:16
Andrew, Alzheimer's as the most unfavourable scenario, i.e. anything to anyone else is not clear, since a full examination was not, but the sclerosis is already taking serious shape. Whether your tools are, at least to exert any positive influence on the prevention of multiple sclerosis (I'm not sure yet what is there to say about the treatment)?
Прохожий
Post by Прохожий » Sun Feb 03, 2013 3:10
Good day,and thanks for the answer,so still I'm MORE or less correct idea of work MM.
Post by Андрей Патрушев » Sun Feb 03, 2013 9:34
Strannix
It is not excluded that the 2nd track Star Wanderer (Massage of the Brain will probably be too heavy load) with regular exercises will give some positive effect, but in any case the light is significantly stronger.
Прохожий
Post by Прохожий » Sun Feb 03, 2013 11:51
Good day Andrew.I still refused to antidep going to try to get out of depression by using MM on day 9 NO trace of enlightenment and POSITIVE attitude to life are not gone,but it is DEEP indifference to everything and of CONSTANT inner tension,plus EVEN the optimism and MENTAL urovnoveshenny which was at his WORST PAN of the attacks just disappeared.And there was a DEEP and VERY unpleasant ossumane the fact that NOTHING can be changed it's over and there's nothing you can do about it and if the drug my fears had at LEAST some reasonable explanation is that in the last days it's assumine that if I replaced the identity,and memory that I could remove REMAINED,but to sense from it was not absolutely no.That is, it was ossumane CONSTANT internal anxiety, but for which there is simply no strength to disregard and profound indifference to everything.And negative thoughts are ABSOLUTELY not gone anywhere just evolved.So this situation is me not really,or rather not satisfied and I accepted that decision.Well, in the most extreme case there is ALWAYS Relanium which I know MM is sochetaetsya.And I have a question could you please advise where better to start so to speak to recover with a clean r sessions,or start with disc healing?Thanks in advance for your answer.
Post by Андрей Патрушев » Sun Feb 03, 2013 11:55
Passer-by
You know better. You're both familiar with, just contact myself and ask a question.
Райдер
Post by Райдер » Mon Feb 04, 2013 0:23
Full adaptation to the disk is good or bad?
And when listening to CDs the adaptation is for each individually, or started to listen and in any case it is necessary to break through the 21 and 15 days in spite of the sequence?
Started listening to Healing, plan on 15 days and don't know when you can start Windows Explorer.
Post by Андрей Патрушев » Mon Feb 04, 2013 1:24
Ryder
Full adaptation is neither good nor bad - just a loss of efficiency. Adaptation for each drive individually. Explorer you can immediately start alternating with Healing.
Шамиль
Post by Шамиль » Mon Feb 04, 2013 12:45
Andrew, good! Acquired drives Conductor, Healing, Endorphins, solar wind, Star traveler, Ultramesh and Hypnotic trance. Have some questions, please advise.
1. If human nature Intrusive thoughts of a negative character, can they be registered in a subcortexwhen systematic listening. For example, Hypnotic trance - it is bought in order to say your affirmations, plunging into the theta state. These thoughts come suddenly. To accept them is not, because the strongest fear that it will suddenly appear later in life. Every time you have to interrupt the session. In unfavorable periods of life peculiar to obsessive-compulsive disorder. Anxious-hypochondriac (genetically) and emotional.
2. How long and in what sequence conduct the course with the discs that I have. Goal: to remove anxiety, fears, phobias, lack of confidence, fear of receiving negative information (especially when dealing with people), obsession. Increase energy, confidence, self-esteem. To feel joy in life.
3. Can I combine Your disks e.g. disks Sviyash or APK Bimetal.
Thank you.
Прохожий
Post by Прохожий » Wed Feb 06, 2013 17:22
Good day,Andrew, I have a few questions,the first QUESTION I have found herpes virus type 3 VARICELLA ZOSTER,it causes INFLAMMATION of nerve endings on the spine resulting in the STRONGEST neuralgia,now it's in my sharp so to say the handicap and I take an active antiviral therapy:NOT yavlyaetsya whether the disease is a contraindication to the USE of the device,it is time and second IF not HOW is better to be treated and only then begin to work with the device or moderately so to speak, to implement it and at the time of treatment?And the second question seems to be canceled I all PSYCHOTROPIC rigmarole,but still I would like to understand the issue,and so communicated with Kuchinova the same as you with SMALL doses of serotonin antidemon and only use CDs and MM approved and checked several sites on this topic and it says that with NEUROLEPTICS is absolutely IMPOSSIBLE well, it is clear to me,and that antidepressants can be very unpredictable so to say, effect, WHAT is the effect?And only about nozepam and Relanium they write what they can in very small doses to apply with relative confidence because these drugs do not involve neither serotonin nor beta endorphin or acetylcholine and in the WORST case, the person at reception just to disconnect for a while and hard to sleep but that all the same for the UNPREDICTABLE effect of the application of antidemon may occur?Thanks in advance for your answer.
Post by Андрей Патрушев » Sun Feb 10, 2013 11:44
Shamil
Шамиль wrote:1. If human nature Intrusive thoughts of a negative character, can they be registered in the subcortex, with a systematic listening. For example, Hypnotic trance - it is bought in order to say your affirmations, plunging into the theta state. These thoughts come suddenly. To accept them is not, because the strongest fear that it will suddenly appear later in life.
We should not deceive ourselves. :wink: While You may like it, nothing will happen. This is not a deep medicinal coding.
Шамиль wrote:2. How long and in what sequence to conduct the course with the discs that I have. Goal: to remove anxiety, fears, phobias, lack of confidence, fear of receiving negative information (especially when dealing with people), obsession. Increase energy, confidence, self-esteem. To feel joy in life.
Mode for each disk standard: 15 times listening to (not less than every two days) - 15 days rest. Drives: Healing, Conductor (they can be parallel and alternating through the night), Starry wanderer, the Endorphins (5-10 minutes at a time).
Шамиль wrote:3. Is it possible to combine Your drives for example, disks Sviyash or APK Bimetal.
No.
