Advice from Andrei Patrushev
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Sun Nov 18, 2012 13:42
Andrei Patrushev
Hello, Andrey! Tell me how to go AVS and starvation? What session would you recommend to use when fasting on water and whether to do it?
Do I understand correctly that dry fasting AVS anyway MM can not be used?
Post by Андрей Патрушев » Sun Nov 18, 2012 14:22
Voffka
It is hardly possible to state categorically that it is impossible. Perhaps the dip will be deeper and there is less hunger...
Post by Андрей Патрушев » Sun Nov 18, 2012 14:23
AHHH In machine not only binaural beats are used, but amplitude modulation. :?
Иррина
Post by Иррина » Thu Nov 22, 2012 15:39
Good day, Andrew :)
Tell me, please, is it possible with the help of Your drives (if so which) to restore the sense of smell and touch. Recently had a cold, was treated with Augmentinom and oflebanon. Overall health has improved, but three weeks had passed he was finished with the meds and no smell, no taste, no feel. Before this incident, nothing like me was not.
Thank you in advance. With respect, Irina
Post by Андрей Патрушев » Thu Nov 22, 2012 15:42
Irrina
Try. :)
Conduit and Healing quite versatile discs...
Иррина
Post by Иррина » Thu Nov 22, 2012 15:50
Thank you very much for the answer :) Did not expect so fast. Start with Healing
Кипер
Post by Кипер » Mon Nov 26, 2012 18:08
Listen to the Conductor for a long time, 5 years maybe. The first few times courses. And now it's very irregular....
Nevertheless really enjoy when I remember to put it on the night(listen exclusively in this mode).
The quality of sleep changes dramatically - appears easy, requires less time for sleep, but the dreams are becoming more filled with previously blocked content of the subconscious, and through this acquired a deeper relaxed state of mind.
In the morning often Wake up surprised deeply emotionally that I was dreaming .
That's interesting... this is only my personal way, who opened the very subconscious mind to work with a Guide or is it all this? :oops:
Ярый
Post by Ярый » Thu Dec 06, 2012 15:20
Andrew, Hello! I understand that the discs "Star traveler" and "Massage brain" lead to approximately the same result? Or is it totally different programs and the effect of their listening different?
Post by Андрей Патрушев » Thu Dec 06, 2012 18:31
an Ardent
Hello.
The site has instructions...
MM, more comprehensive program.
Ярый
Post by Ярый » Thu Dec 06, 2012 21:32
Andrei Patrushev
Actually, the question is asked because the instructions to these drives description of possible effects identical! Thank you for your answer! :)
Сапфо
Been thanked: 2 times
Post by Сапфо » Thu Dec 13, 2012 18:56
Hello, Andrey Vadimovich! First of all I want to thank You for Your work. :o
I spent several years listening to Your CDs and Innerpulse. The first year I was very good at relaxed while listening to it (I mean body), and now to relax (or to achieve the same effect as before) does not always work. And the Guide in General was annoying :( Why it happened, is the effect of "addiction"? I usually speak at the beginning of listening to the "right hand relaxed" etc. (start with the head, the same phrase as in Explorer). It works, but not always. While listening to sometimes represent something more comfortable, like I'm floating in the river. Does calm effect? I know that you can work with the technique Jose Silva while listening to MM, would You recommend any other equipment?
ААААА
Post by ААААА » Fri Dec 14, 2012 21:40
Andrei V., good day!
There are interestnaya idea for your disks, by the way thank you very much for them, that was born spontaneously and decided to share,so here not so long ago, Aplle did a Russian version of its music store for all gadgets produced by it. Ie the same itunes store, where you can now buy a licensed Russian music and performers! So can You place the tracks and all the disks ? Conveniently , license and efficiently! The transmission format as I understand it MP4 , will not be any loss in quality?
With respect.
ААААА
Post by ААААА » Fri Dec 14, 2012 21:42
The question dogonku) waking up listening to the 2 track star wanderer....and slezyatsya eyes ..it's not a problem slightly,but the first time I thought it a coincidence but each time so)) ....from what?)
ААААА
Post by ААААА » Thu Dec 20, 2012 1:20
Andrew ! Good night!
Perhaps the post above was not in the format of the topic , but inspired by the ease of use) as recently I hit the electronics stores and anywhere already sold out of SD players! Gadgets and reproducing the file a lot in the end, the CDs we listen to on the stationary deck which is inconvenient and the laptop with an iPhone that might not be so effective?
There are questions to think about if you can respond ?
What is the impact on the rhythms of their activity, and which is dominated by waves or Vice versa?
Alcohol
Smoking
Stress
Love
Anxiety
Coffee/tea maker
Lack of sleep
Active physical exercise
Oxygen starvation
Sex
A sense of peace - life satisfaction
An adrenaline surge
And the philosophical question of the harmonious person, or the person who is in harmony which the wave rhythms are inherent and that it occurs with the rhythms?)
Thank you!
Post by Андрей Патрушев » Sat Dec 22, 2012 10:20
Sappho
Hello!
Intentional relaxation contributes to the manifestation of the effect of machin. Prolonged use establishes a strong connection, and You can achieve the same effects without Mashiny. As, however, and with a Guide, you can just imagine that You are listening to.
The greatest effect visible when there is a large contrast between the normal state and relaxed. The rather long and regular practice, this difference is smoothed...
Post by Андрей Патрушев » Sat Dec 22, 2012 10:22
AHHH
Hello.
The idea of the EPL has already been discussed. Unfortunately, this format is not conducive to efficiency.
Post by Андрей Патрушев » Sat Dec 22, 2012 10:23
ААААА wrote:waking up listening to the 2 track star wanderer....and slezyatsya eyes
In the alpha state hurts what hurts...
Post by Андрей Патрушев » Sat Dec 22, 2012 10:26
ААААА wrote:How to affect the rhythms of their activity, and which is dominated by waves or Vice versa?
People, unlike animals, is a very flexible creature. Although some trends, perhaps (after extensive research), I can choose, but each of these individual rhythms...
Бакыт
Post by Бакыт » Thu Jan 10, 2013 18:11
Good evening Andrew!
I want to buy "Lucid dreaming".
I have to question
disk need to listen to just before bedtime or at any time during the day?
Post by Андрей Патрушев » Thu Jan 10, 2013 18:14
bakit
Hello.
Just before going to sleep.
Чарлз
Post by Чарлз » Fri Jan 11, 2013 19:32
Андрей Патрушев wrote:AHHH
Hello.
there are also lossless ALAC format, it is lossless
Post by Андрей Патрушев » Fri Jan 11, 2013 19:36
Charles
In fact, it is impossible to assert unequivocally... :?
Роман Логоша
Post by Роман Логоша » Thu Jan 17, 2013 3:33
Hi Andrew.The question is.Listen to the programme "Ultramesh"but don't try to remember the information.To start I would like to increase the level of concentration (the way for the concentration may ultramesh and not do?).And then move on to data.
By the way the question probably already asked.But nevertheless is remembered while listening to the program (that is something you need to learn , to teach) or sufficient material before the audition?
and another question to the effect of absorption is valid only when you use the program "Ultramesh"?
Is there any addiction to the specifics of this program with its frequent use (i.e. when the material begins to be absorbed well only when listening to the disc, and it locks the memory function for every cent)?
and lastly, what else in addition to Ultramage to listen to your programmes?
I hope for a speedy response.
Post by Андрей Патрушев » Thu Jan 17, 2013 8:44
Roman Logosa
Hello.
To enhance the ability to concentrate and remember is intended for the second track of the Star Wanderer (the last track on Ultramote). The main track on Ultramote designed to enhance concentration and remember the material while reading. Without the teaching material, it is useless (read manual and forum).
This is a practice, not a pill - soon the brain learns to self-focus during lessons with the learning material and the need for the program disappears.
Роман Логоша
Post by Роман Логоша » Sat Jan 19, 2013 15:10
Thank you Andrew for the answer.I'm not saying that I want to use the program without training it is clear that a simple listening program Ultramesh without material is meaningless.
I say don't listen to the first track Training in the morning.And just before the program Super Training then immediately followed by the integrator.
And Star flight listening 2-3 times a day at different times of the day because it is not connected directly with the program Super Training.
But the program itself Super training is it possible to listen for more than 45 minutes a day?And for the integrator.
or there are limitations which do not violate?
