CD "Ultramesh"
Post by Андрей Патрушев » Sun Jan 10, 2010 21:58
Маргарита1801 wrote:hi Andrea!
Successfully use Ultramesh for 2 weeks (session is coming),I have a question : in the last few auditions 1-2 times for shoots Sean in the ear,and only one.A sharp pain,seconds Ceres 5-7 passes,but pleasant enough.What xthis can be?
Hello!
The otitis. :?
ЕкатеринаЛ
Post by ЕкатеринаЛ » Thu Jan 21, 2010 11:48
Please tell me, on a regular (cheap and purchased 5 years ago) speakers or headphones the effect is heard, the result will be? or are these frequencies just for the super technology give the result?
Post by Андрей Патрушев » Thu Jan 21, 2010 15:03
ЕкатеринаЛ wrote:please Tell me, on a regular (cheap and purchased 5 years ago) speakers or headphones the effect is heard, the result will be? or are these frequencies just for the super technology give the result?
Unfortunately, I have not seen the characteristics of this brand. :?
татидитт
Post by татидитт » Tue Mar 02, 2010 23:52
Hello!
Listen Ultramesh only the second day. With duration, volume and frequency of the sessions is not being misused. Yesterday was missing quite a bit of volume to hear the noise, but every session has to be done louder, the noise sound worse Why? Is this normal?What to do? :)
Post by Guest » Thu Apr 08, 2010 13:01
Good day,
how long before you start listening to Healing, need to finish listening to superbacana disk Ultra brain, and effectively only listen to super learning.
I have a procedure alternate through the day, morning Star stranger on the trail. evening of Healing
Thank you
Post by Андрей Патрушев » Thu Apr 08, 2010 17:15
татидитт wrote:Hello!
Absolutely fine. Why do You hear this noise?
Post by Андрей Патрушев » Thu Apr 08, 2010 17:16
Anonymous wrote:Good day,
Thank you
To listen superbacana disk Ultramesh without reading the training material is absolutely useless. :?
Post by Guest » Thu Apr 08, 2010 18:36
not so with reading the same :)
just do not be harmful immediately after read super training, listen to Healing the disc, I mean that is to say, what is the minimum break should be on time
Post by Андрей Патрушев » Thu Apr 08, 2010 18:54
Anonymous wrote:not so with reading the same :)
Break standard - 3 hours.
Post by Guest » Thu Apr 08, 2010 18:58
alternate through the day, morning Star stranger on the trail. evening of Healing.
normal schedule, or as anything, this chart normal?
apparently forgot to answer :)
Post by Андрей Патрушев » Thu Apr 08, 2010 19:07
Anonymous wrote:alternate through the day, morning Star stranger on the trail. evening of Healing.
Yes, normal... :)
So you can in one day to listen, if not annoying.
Post by Андрей Патрушев » Sun Apr 11, 2010 19:02
сибирячка wrote:a Question for Andrei Patrushev.
What would you suggest the syndrome of attention deficit in boys (13.5 years). Problems in the school.
Thank you in advance
Sorry - missed.
Disk space wanderer should help. Done for her son (birth trauma) - helped. :)
Илья_Р
Been thanked: 2 times
Post by Илья_Р » Sun Apr 18, 2010 13:48
What "Star flight" differs from "songs chakramov"? :) :aa
Post by Андрей Патрушев » Sun Apr 18, 2010 14:40
Илья_Р wrote:Than the "Star flight" differs from "songs chakramov"? :) :aa
http://www.mindmachine.ru/patrushev.htm
Post by Guest » Wed May 12, 2010 11:14
Hello!
Will there be any effect from listening to this program "Star flight" in the morning without the rest of the programs contained on the disk?
Post by Андрей Патрушев » Wed May 12, 2010 14:25
Anonymous wrote:Hello!
Yes - improve memory and attention.
Post by Guest » Thu May 13, 2010 11:20
Thanks for the quick reply! :)
Is it possible to listen to the program, performing work on the computer? Or need to enforce certain rules?
Post by Андрей Патрушев » Thu May 13, 2010 12:18
Can. :)
Post by Guest » Fri May 14, 2010 11:17
Thank you! :)
Антропофил
Post by Антропофил » Sat Jun 26, 2010 22:15
I have a paradoxical situation. If you listen to the 2nd session of the headphones, they (headphones) otvelekayut! :roll:
Is it possible to listen to it through the speakers?
Post by Андрей Патрушев » Sun Jun 27, 2010 15:22
Антропофил wrote:I Have a paradoxical situation. If you listen to the 2nd session of the headphones, they (headphones) otvelekayut! :roll:
It is possible, but useless. :?
Post by Guest » Mon Aug 02, 2010 9:41
and at application of MM and disc Ultramesh one day break 3 hours is also required?
Умная мышь
Post by Умная мышь » Tue Aug 03, 2010 19:37
My question is the following: I ordered the CD "Ultramesh", I want to start to listen to him, because after 13 days I got admission to the University, but before outlets are not able to get before Saturday (9 to 18) to buy a normal CD player while you can listen to drive only in the computer or laptop. In the forum I never found a clear opinion about whether it gives the effect of listening to the disc in the computer????
Very. really need to know if I run headlong into the store, so as to learn a lot, and since I work not much time is left.
By the way, surfaced voracek..... Is it possible to listen to Super Learning in the evening (studying will after work). and then after another hour or so (before going to sleep, respectively) Integrator, or must pass a certain amount of time (or no difference?)
Post by Андрей Патрушев » Wed Aug 04, 2010 16:05
Anonymous wrote:and in the application of MM and disc Ultramesh one day break 3 hours is also required?
Perhaps, Yes.
Post by Андрей Патрушев » Wed Aug 04, 2010 16:08
Умная мышь wrote:my Question is the following: I ordered the CD "Ultramesh", I want to start to listen to him, because after 13 days I got admission to the University, but before outlets are not able to get before Saturday (9 to 18) to buy a normal CD player while you can listen to drive only in the computer or laptop. In the forum I never found a clear opinion about whether it gives the effect of listening to the disc in the computer????
This CD (except the last track) and can be on the computer. In the evening, but it will be possible to get sleepy (tired brain for any rhythmical stimulation so responsive), so I need a little rest.
