Bioresonance modulators
Your own guide in the energy-space
операторпси
Been thanked: 3 times
Re: Bioresonance modulators.
Post by операторпси » Thu Mar 13, 2014 8:34
I read somewhere here that there is a spherical field around the crystals, someone even felt, but what was the experience like - I created the fee in the imagination of thinking of every detail: how I draw on paper, scan it, photoshop is transferred to a negative print on the laser printer, iron the pad on the PCB, etched, looking for the crystals, cut them on the machine, installed in the holder, and soldered to the Board - here there is a field which is expanding rapidly. Although the Board is created in the imagination of field is really.
нева
Has thanked: 21 times
Been thanked: 90 times
Post by нева » Thu Mar 13, 2014 12:43
операторпси wrote:but what was the experience like - I created the fee in the imagination of thinking of every detail: how I draw on paper, scan it, photoshop is transferred to a negative print on the laser printer, iron the pad on the PCB, etched
Good concentration. I remember once long ago this kind of visualization called "Korean meditation"...the highly working thing, but not really caught on, because no trained people are difficult for a long time to "pull the thread" (at least 15-20 minutes without being distracted), and thus, there are cases of miraculous healings, thanks to this practice.
But there are subtleties and nuances, the so-called "keys from the practice"..
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Thu Mar 13, 2014 14:08
операторпси wrote:I read somewhere here that there is a spherical field around the crystals, someone even felt .......
Crystals were not activated and not glued to the phone give you different feel. When viewed they show the structure of the crystal and the selected frequency characteristics. But who as it turns out to view. And you have activated for your phone is a different action and a different picture. There immediately emerges the structure of the crystal in Samadashvili with the crystal phone and infopole.
Quartz smoky - triangle from the hip with the top up , rapidly passes through the column and exits 25 cm over the crown. And the rapid rise of energy and even felt the vibration as the simulated signal. From the hips and up at an angle of 60 degrees as the bell is formed a protective field and a field of interaction . First, it is not very thick, but crystal felt almost immediately .
Amethyst on the contrary shown as a triangle ,from the lower chakras , with the top down. A slow rise of energy and slow activation ,slow pass along the post and out over the top, from the hip as in a smoky funnel funnel angle of 60 degrees. Slower activation, but in power he is stronger and the interactions more and more dense. That's what seemed at first viewing crystals activated on the phone of the Aura))) . About bridges can't say anything. Activated on the phone haven't looked. And the plate just the stickers without activation.....well ..the properties of the crystal, not the interaction . Although it is certainly possible and the crystals to use without activation , but there is other work and other opportunities. I work with crystals is not very familiar .
Юрий И
I bought three ..available on March 13, 2014.
Post by Юрий И » Fri Mar 14, 2014 13:54
attached to the phone smoky quartz..activated kind, then wore a sports cap this number. with naletim "smoky quartz",- the hour of the night cut down, properties sleep not like before, strangers (osoznanno, astraco train)). In the manual it is written that it is better to activate on the new phone. Went to buy a Philips 737, he was dvuhsotkratnym....The idea to ActiVote ostavshiesya two modulator on it.But here's the question - is it possible at once( one day?), or wait and ActiVote first second ( Amethyst) - then after some time and the bridge ?..in General, three of the modulator, one in the old phone( are two years) is already handled by the smoky quartz,but the new dosimetry smartphone "филипс737" while waiting for their fate.Who that will advise???
операторпси
Post by операторпси » Fri Mar 14, 2014 21:14
Again, Hello, and what BRM should immediately stick after activation or is it still first volume rendering to gain a couple of days, and it should be constantly on the phone to keep?
Юрий И
Post by Юрий И » Fri Mar 14, 2014 21:40
операторпси wrote:once again, Hello, and what BRM should immediately stick after activation or is it still first volume rendering to gain a couple of days, and it should be constantly on the phone to keep?
I followed the directions ,which was attached with the purchase, decided to hold the activation automatically,but re-reading the instructions (intentions) ,holding the phone between hands)so that fingers do not touch each other).
now the main question - how rasporyadilsya(options??) the two remaining BRM, -Amethyst and "bridge"(with two crystals"
операторпси
Post by операторпси » Fri Mar 14, 2014 23:50
Yuri And I have no instructions unfortunately for to BRM from Moscow I will not pull financially. Today I found two lovely small crystal rhinestone in the store here I think to deliver them or to look for more smoky quartz, dual-head true no problem to find a little. (This is the topic that I decided to do it myself) Although I've seen dogology, but again it is nothing to cut...in half.
лексветер
Post by лексветер » Sat Mar 15, 2014 23:33
операторпси wrote:Today I found two lovely small crystal rhinestone in the store here I think to deliver them or to look for more smoky quartz, dual-head true no problem to find a little. (This is the topic that I decided to do it myself) Although I've seen dogology, but again it is nothing to cut...in half.
a commendable idea, maybe in a branch doing it yourself will open the corresponding topic :) but I think not so simple as it seems more accurate to work will be just a piece of stone in the pocket, but the question is how much and effective, based as I understand it is not a method of influence on the crystals, plus the accuracy to calculate a specific type of stone a resonant circuit is also a big challenge, though not lose the desire to understand how and what :)
Aura
Has thanked: 22 times
Been thanked: 1124 times
Re: bought three ..available on March 13, 2014.
Post by Aura » Sat Mar 15, 2014 23:46
Юрий И wrote:attached to the phone smoky quartz..activated kind, then wore a sports cap this number. with naletim "smoky quartz",- the hour of the night cut down, properties sleep not like before, strangers (osoznanno, astraco train)). In the manual it is written that it is better to activate on the new phone. Went to buy a Philips 737, he was dvuhsotkratnym....The idea to ActiVote ostavshiesya two modulator on it.But here's the question - is it possible at once( one day?), or wait and ActiVote first second ( Amethyst) - then after some time and the bridge ?..in General, three of the modulator, one in the old phone( are two years) is already handled by the smoky quartz,but the new dosimetry smartphone "филипс737" while waiting for their fate.Who that will advise???
One day, you can activate the first amethyst, then the bridge HA.
About 3-x modulators on 2 phones have different options and they will give different sensations. You can start with the one phone stick BRM quartz, the second bridge, and after receiving responses to experiment.
Aura
Post by Aura » Sat Mar 15, 2014 23:50
BRM is activated, glued to the phone, then filled with a formed intention. The intention is to better define the predominant perceiving channel. BRM need to keep glued to the phone for as long as you want this intention was sent to HEIP. From what field rhinestone? What is the diameter of the crystal?
Aura
Post by Aura » Sat Mar 15, 2014 23:55
Валерич wrote:And more days probably 5 interesting observations with numbers. I'm on work quite often deal with 3-digit numbers, 200 and above, so I solidly are of such a plan: 388, 400, 448, 336, 550... Very often, 6-7 times out of 10. But of the remaining half of this kind: 235, 257, 314, 437... Can anyone have experience of decoding such signals?
Specific transcript it is difficult to give, service control programs, and GAIP weight, and each has its own digital sequence and several algorithms.
операторпси
Post by операторпси » Sun Mar 16, 2014 0:56
Aura wrote(a): From what
Honestly I do not know what field, and the diameter of the crystals 5 mm, length 25mm.
Юрий И
Post by Юрий И » Sun Mar 16, 2014 16:13
When I aktivno smoky quartz,- with the numbers too, it was fantastic( I had a sticker stuck лад210) - within 2-3 days - either called me or I called at a time when the numbers on the dial(the display is the same),- type 11:11 : 17:17 , 21:21 etc.Stop calling 'empty' conversations..GOOD!..When the second modulator (amethyst) attached to a new smartphone, night - dreams are more disturbing ( something from the past is not very positive things and is clearly a surreal context)..so Wake up and immediately was able to sleep again ... Actually, the memory is not erased - it is formatted - that's what I came up with for the time being..Oh, and the bridge will be glued, will necessarily accomplish your goal..by the way, I put the intention " to display additional finansesanas for 4,6 and 8 cristaline modulators .Egregor modulators,so to speak..interesting.well, that's all the little things.))) :ay
нева
Post by нева » Sun Mar 16, 2014 22:15
Юрий И wrote: when the numbers on the dial(the display is the same),- type 11:11 : 17:17 , 21:21 etc
The mystical response like this...
Aura
Post by Aura » Tue Mar 18, 2014 1:04
Юрий И wrote:Stop calling 'empty' conversations..WELL!.
This is the correct process has begun - a deliverance from the information “noise”. Crystal, being in some ways a living education, absorbs the energy of the place in which it was formed and grew, and forms its own special space in which there are other laws determined by the frequency of the crystal. At the same time, crystal is perfect on structural-geometric parameter. So the field of BRM, and interact with the fields of man, is able to structure the energy-component of man , including to get rid of unnecessary information (referring to thin the field, not in the head).
Aura
Post by Aura » Tue Mar 18, 2014 1:12
операторпси wrote: Honestly I do not know what field, and the diameter of the crystals 5 mm, length 25mm.
Diamond can be round cut. If the crystal is cracked, before cutting it to glue with epoxy glue. But in General, working crystals for BRM still need to look for (if you take the usual jewelry scattering), because jewelry and the energy purity of the stones do not always coincide. Work of course will be any stone, just as effective.
Валерич
Post by Валерич » Tue Mar 18, 2014 1:58
Аура wrote:get rid of unnecessary information (referring to thin the field, not in the head).
And probably rid of excess desires, requests that is...
And interesting figures continue... Some shift towards type : 451, 572, 396, 231... Average = sum extreme. And three times today 333 caught.
нева
Post by нева » Tue Mar 18, 2014 13:49
Юрий И wrote:Egregor modulators,so to speak..interesting.well, that's all the little things
You are very sensitive to the information were able to read the information.. about the Order of Geologists of Free Iron Mountain.. There, Yes...interesting Egregor...)))
нева
Post by нева » Tue Mar 18, 2014 13:57
Валерич wrote:451, 572, 396, 231... Average = sum extreme.
Not only the amount of the extreme..there is still the first digit is the difference of the second and third..... and the last figure..there is the difference of the average and first strong..number..) I Wonder how they come to You.?
нева
Post by нева » Tue Mar 18, 2014 15:58
LILIYA-R
Employee mindmachine.ru
Yuri And.. A single message ..employee..in this thread..and for number: 1111
Aura
Post by Aura » Tue Mar 18, 2014 18:30
Валерич wrote:And probably rid of excess desires, requests that is...
In this Rauh strong.
Валерич wrote:And interesting figures continue... Some shift towards type : 451, 572, 396, 231... Average = sum extreme. And three times today 333 caught.
Generally 3 in numerical sequence the service daemon is a transition point. And then - by intuition, 3 may be, for example, a coupling point with the other fields. In bridges to interpret the sequence somehow possible, because the bridge is able to generate a modulator with one crystal - no, it uses existing, and not just one, but the algorithms there are plenty.
Валерич
Post by Валерич » Tue Mar 18, 2014 20:26
Аура wrote: And then - by intuition,
Inclined to believe that these sequences are somehow reflect the processes that are set in my software. And what a beautiful number, the closer the result :D
Аура wrote:this Rauch is strong.
Thanks for the tip. That, I think, why would I have less desire to push BRM your wishlist :)
Aura pliiz , and it is possible more in detail about the features of BRM and Amethyst, Rauch Topaz? Not as formal as in the General description? I have both. Hurry, I guess. with both walk started, it was necessary to study separately.
операторпси
Post by операторпси » Tue Mar 18, 2014 21:45
:roll: circuit etched, put both of the crystal on the ends of the boards went a strange radiation, removed, disappeared, put - started again. Feeling as circular vibration in the volume. :oops: looking for needle file with diamond coating, or the same saw blade.
лексветер
Post by лексветер » Wed Mar 19, 2014 20:05
операторпси wrote::roll: circuit etched, put both of the crystal on the ends of the boards went a strange radiation, removed, disappeared, put - started again. Feeling as circular vibration in the volume. :oops: looking for needle file with diamond coating, or the same saw blade.
than measured the radiation? and the polarity of the crystals was taken into account and if so how, I understand the polarity of the crystals vlijaet on the result and the correctness
Aura
Post by Aura » Wed Mar 19, 2014 21:03
operatorsto polarize the crystal , you will need to assemble the high voltage generator, to deliver a minimum of 30 000 000 volts. A crystal between the electrodes so that the spark did not come. Withstanding in this field from 10 minutes (for quartz) It will be the easiest method conventionally to polarize the crystal.
