Small offtopic.
Сергей Битков
Grinding disk plan to use the knife sharpener the V shaped thing, mounted in a plastic handle, the widest part of 5-6 mm. And, you can skip, but how better to sharpen each disk of three or the whole package?
Re: Small off-topic.
Launched counter-clockwise.
There was a big wasp...turns and crawls around the bulb in the ceiling..
Abnormalities what is...
well, it's a device to create anomalies, what wonder is it that creates them???
Really looking forward to...
Yes, force majeure, me for a few days relatives got distracted .... now sometimes I reach a computer, a little freed - lay.
gift number 1.
mandala "the wheel"
laying under the fan listing on the A4
mental programming on the distribution of energy and other needs.
Able to very much.
Including the conversion between types of energy and frequencies and whatnot.
gift 2 will be a bit later.
mandala "the wheel"
Able to very much.
http://openmagic.org/g2atsrc/koleso001.pdf
lost here from the past messages link.
I don't knowВоффка wrote:For those who are in the train, it is possible for more at this momentМихаил_ wrote:is Able to very much.
Mandala tasty.
A big sincere thank you!
I do not understand. This replaces the P-l on the rim, which may strain and distribute it in such time do not apply?Михаил_ wrote:to put under the chopper a printout on A4
Or in addition?
It is an independent control unit-conversion-direction of energy flows. There a lot of things and taken into account. But you can use samopisnye for P-light.ФилиНН wrote:I don't understand. This replaces the P-l on the rim, which may strain and distribute it in such time do not apply?
Or in addition?
Michael,this mandala can also chopper how to apply your products ?Михаил_ wrote:gift number 1.
mandala "the wheel"
Able to very much.
Projected mandala at the chopper.. a dangerous mix... a feeling BJ 2.5.. this is a joke or so conceived?
In General, the prototype or predecessor of the U2 program, which is used in including "podkluchenie" branch of the amplifier. Just public U2-U4 has a more advanced firmware, which became the basis of commercial firmware V4 base. It was modified in the course of real operation as the monitoring system "under load". A "wheel" is the Foundation. Simplified U2.ЛИЛИЯ-Р wrote:Michael,this mandala can also chopper how to apply your products ?Михаил_ wrote:gift number 1.
mandala "the wheel"
Able to very much.
By the way firmware Y1 and Y4 vary greatly even the ideology of their work... In General they would form a independent branch, I use this and that.
Returning to the question "where you can attach" - basically anywhere where you can "collect" energy.
Some manufacturing and industrial processes, a variety of devices (including old TVs and monitors with a picture tube) have a tendency to slightly fonit around. Mandala can dispose of this energy-to-noise for useful purposes.
And then everything is simple - the operator programs.
no idea, the system is configured by the operator, the quality of energy can be transformed according to his needs.maverik wrote:Projected the mandala on the turntable.. a dangerous mix... a feeling BJ 2.5.. this is a joke or so conceived?
well, it is not clear how to understand the question "trick or so intended". My products always work as planned, although sometimes do not truly understand the causes of the settings in one mode or the other, but this fact does not change.
I.e. put under the turntable mandala will give a correct operation of the system. You can of course, as I indicated above, and under a lot of what else to put. It's a pretty universal thing.
And it has a particular affinity with Ah extension as (time), in particular canned and manipulation of the energy going on the same principle.
Yes, the owners Y4 additional sources "wheel" is generated, it is possible to cling to a single system.
It's a good start I guess
and industrial fan at high speed spinning for months and years is to mold a mandala?
and another technical question - mandala should fit snugly to the body of the turntables?
if anything, the chopper will stand on rubber legs on the mandala?
1. I was thinking the exhaust fans will not. Look in other places. Where there are electrostatics, high voltage, or circular streams of water, for example (bends of rivers).
2. do not care as it fits.
Thank you! Needs some work... something to think about.
During the day, turntables( three pieces) arbitrarily change the speed to any value between 500 to 1100 rpm/min., the food absolutely stable. What caused this change? Can be the density of the medium and mu-flow is not constant, and drives "bogged down", reducing the speed of fans?
