Range. A new product in the social. the line.
no, not that... it's just almost noticed not many, and the process affects all exactly the same.
Re: Spectrum. A new product in the social. the line.
Range of fruit overseas,there's the one who went to pick up all my contacts for the last 2-3 years -hpta I didn't order. Well, maybe how it changed my status in the collective conscious-unconsciousness. Tried to treat through it-the common cold (heavy) not mine-the next day got the effect than expected. At the Foundation of the program for a second he saw a bacteria-looked like a scattering of black caviar. But with a sufficiently large social structures -certainly pruha not enough light all the same(short colchica).
What You write, I read at least strange....ВЭНХЭ wrote:Range of fruit overseas,there's the one who went to pick up all my contacts for the last 2-3 years -hpta I didn't order. Well, maybe how it changed my status in the collective conscious-unconsciousness. Tried to treat through it-the common cold (heavy) not mine-the next day got the effect than expected. At the Foundation of the program for a second he saw a bacteria-looked like a scattering of black caviar. But with a sufficiently large social structures -certainly pruha not enough light all the same(short colchica).
I would OCENOCHNOE recommended to defer the spectrum, make yourself бж1.0 Lite and three months to wear it(can be on the path to change on a homemade panacea). And then come back to this spectrum.
Does the range itself will not update the old links at all in any mode.
The fact that (as I understand) You do not use BJ, creates a curve situation. Your subconscious mind absolutely for spectrum is not ready.
Range - a product for regular users of the BZ and BZ itself is not.
So Your "experience" of use is not only clean and revealing, but he is not experience in the use of the spectrum, strictly speaking.
Michael-the fact that I removed with a cold ,prakticheski reversed the per day is the wrong experience? Any experience is useful.The fact that skills happens to suck, it echoes one of the program is in principle logical. I have been living by the principle, randomness unidentified patterns.Interest in the subject BJ is a certain resonance with my vision of the world. Michael I svajanam Your attention to user BJ, unlike many gurus with much less incarnational potential.I have enough experience psychoenergetic practices-and the fact that adelay the Spectrum is not idle curiosity. I use it for its intended purpose-to improve the quality of life, and it naturally performs its function to Your honor.
Any experience is useful if it is not the last in this life.
In any case, very strongly I ask to add to the spectrum of 1.0 Lite or cure-all self-made. It is important that the interface is basic, or rather initialize it in the subconscious. Experience is certainly important, sometimes not important.... although it is better without it
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
A personal experience: in the hospital room included ordered for the money to relatives of the bedridden patients pop. I only had time to think about the module "Control of the egregore". Pop whispered a few words over the sick, and the bullet flew from the chamber. Roommate then said that usually he has to read for 5 minutes at least. I have even card "Spectrum" was not
The neighbors got normal, even without crosses. After this incident, put one with a cross. The wife of the new neighbor ordered some of the healer remote session at midnight, but the hour of the night turned out worse - the new neighbor got a severe attack of pain at the fracture site and an additional dose of analgesic.
2 2.1 BJ left the hospital nurses, those who liked them. They asked themselves. BJ and without push themselves perfectly masters find.
Thanks Michael-will do. Several acquaintances have done and BJ and the Panacea-see everything is fine.Question-if BJ charge tracks but not in water and in the dry salt will be the difference?
1. if you do a 1.0 then just follow the instructions
2. in your case (if you intend to actively use the range) 1.0 to You later, and you need something more active. !.0 light is done by applying matrix - no tracks, no salt or water is not necessary
Panacea Lite is also matrices.
Алексc3000
Wanted to ask why the matrix applied to the pendants range and panacea do not coincide with those which are applied to the bracelet links with self-manufacturing products light?
1. it is not a product of light.
2. there is no matrix where You saw them there?
3. if they were there, why they would be the same? it is not clear, especially because it is the product of increased power. But we do not use matrix for industrial goods, they are made specifically for ease of manufacture something in the field.
in General, the manufacturing process and the range of the pendant and pendant of panacea completely different from the manufacturing process for example the bracelet range, and for example the bracelet is a panacea (commercial) and matrix anywhere neither there nor there does not appear (neither in the pendants or the bracelets).
I developed this simplified method of manufacturing specifically for field conditions and light versions. Some where of the matrix, still get indirectly in the Lite version, but very rarely and only in a multistage process, for its simplification, which is not a significant component.
Алексc3000
I'm on the letters which the contour of the circumference of the coulombs applied, will take somebody smart enough to put on the bracelet links them interestno what happens
Great is the power of the human imagination
nothing. they are only part of the exterior design, which was developed taking into account wishes of my left leg. The pendant range, as I recall them at all.
And on the pendant written panacea "panacea" - a surprise
well, I think... ? it would be better did not waste time your and my.
Алексc3000
Yes, a Panacea really a surprise, there is hard to see in the photo, but the one with izumrudnom it more detailed, as it was thought, by analogy with the G 3.0, matrix, but if not then not, I just said it's the same forum
and Yes, indeed, there I wrote something to the ring that not empty was
looked in line with tradition, this time that anyone asked. The work product is not relevant
giving properties izdeliye in the manufacture of e-technology is happening at the level of the creation of the phantom and combining it with a material object. There is no need in fact at all familiar to the public here methods and technical tools.
Алексc3000
Now I understand, thanks for the clarification
we will release a limited-edition pendants (e-pendants exact) range-2.
more precisely, we will release the circulation for domestic use. Even more powerful than was the first. Based on the model of the circulation (the amount of which is for technological reasons limited) I have about 2 vacant positions. If someone really need a request in PM, I will consider individually each case (the product is powerful, everyone is not ready to provide).
Were relatives (20 years probably wasn't) - there's a son of a drug addict feel - will bring their parents to handle... (I still only have met the parents).
Honestly, I don't like the situation.(a classic of the genre, probably.)
I heard that they are "sealed", even thrown out of the egregore.(control egregor...)
Physical tests is good.
Parents of course, BJ will try to give...(their state is no good)
The situation is complicated by the fact that (I did not hold a candle, but you know) my mom had taken dad to the birth of 2 children in the family (but after birth). Just with the second problem...
No experience - will have to act on a whim.
PS - didn't know in what subject to write - I decided that this is more suitable.
In General, in the last week for various social services. groups throws...
heard from a very active and advanced user, which in the case of alcohol, he used the pan-the water (that which is commercial, in the sense of media structures and not just charged), from her "to come out" very hard.... ie for a few months probably really almost completely from myself to wash.
In General, the free measures - control of the egregore, the range (for detaching, join something different, activation of the channel is kind of like egregor), also panacea and 2.1 on all in the family, photos all and home, stoppage in the rooms and all family members.
If it is not possible on the conscious level - or quietly-and after photos.
ASD - drink problem drug addiction (reset) + endorphins (disk Patrushev).
Plus, I remember the good old tool, thanks aine, have such grass, or rather shrub, Ibogaine, check online if you do not know. About it is a lot of information. Well, for a man who has a panacea in the hands, this is not a problem to use, huh?
Only Ibogaine really neat, it erases the zero addictive, so it can be overdose, in other words without the knowledge it is better not to apply, one must be aware of the possible consequences, or simply could and yeah.
I think it's a good start.
There are still sudakovsky methods (not necessarily physical, I mean the concept), but I have multiple sclerosis pancake.
if need be we will return to this topic towards the end of April....(for sudakovsky methods), for the rest I hope in General is clear.
Michael , please tell me.
Continuing the theme about the junkies.
How to be more effective at Stabi be anchored?
For the info about the pot Ibogaine separate thank you!
And very, very necessary! Please return as You will have time to sudakovsky methods.
I have almost all the books of the Pack bought. It seems that the interest in sujok came under the influence of the gift of the bracelet:)
just Sudak rich and multifaceted.
methods of recent years (there is no way in the books, they are in the lecture on video is video I yet did not buy, this is still a Pro level for many years engaged in), for example pollina give such opportunities that you can program everything, including society, relationships, the past and the future and so on, i.e. details on the "links" in internetet to go on the program.
Our friend is "Antinarkota" program that is loved by businessmen and, indeed, many. Never with this problem are not related, but it (the programme) another of the old Arsenal, but very effective.
Consists of two parts for independent work. Enabled as and the man pours out a negative memory and consciousness. And then another (the second part, a different formulation of the eagle) and the man fills the sacred place that not empty was positive.
Some just regularly do and the second part of the paper with the order to bring.
At first a cry, regardless of gender and age....
use not only the addicts, rather they actually don't always, just once in a very long while was written for them and they discovered that without the second part - is not effective.
But it's something that essentially works well when using hands of a specialist.
And about remind it is about the fact that simply for self-installation. Don't remember, must ask.
Here....
be anchored - I don't know, individually, and then several different anchors on the same set.
generally, the issue in motion. the best thing is the active trend (self-actualization bright and high quality).
I think so.
Here....
I think so.
Michael_ A huge thank you!
Managed to get out of egregore! (kicks back sent...)
Understand why the common ancestor of all arms waving (activation channel kind) - not everything comes at once until...
While the culprit with 1.0 remaining 1.0 L go.
Literally dug into the water with T1, ASD began to take...
The cold is terrible of course...
PS - to be honest, during these operations, I from time to time in the pot was thrown.
Yeah, war is war.... Cold.
It is now much broader than just cold one person, it is better not to get caught.
Thanks for the warning. The night almost did not sleep - at times crying (a couple of decades this certainly was not) - perhaps a new kind of evil eye.(with this cold probably 5-7 seconds of contact - he sniza person to go was , I "buzzed" all night - still remember was having a horror movie-the ancient world+mystery(cocoon man)+like the undead from Warcraft)Михаил_ wrote:It is now much broader than just cold one person, it is better not to get caught.
For dinner I decided not to get stuck (well I have not seen this desire to escape...) - told the truth... now hold ASD-2, Ketorol(such and medications that do not know), T1 water drink...
Yeah, heavy features egregorial interactions....
so a little relaxed
notice how to the past tense Ernst
- it tomorrow "on the carpet"
so a little relaxed
