Planned changes in the commodity row of the entire line BJ-SK, etc.
As a user of both versions of the Amps I note the apparent advantage of U1 in the possibilities of translation (including remotely without loss of signal strength, tested at a distance of thousands of kilometers) with the help of audio, including third-party development (V4 works with tracks for the UK without the need for scrolling - the start via mental commands to broadcast with it audiomaterials third party, you need to create, or rather to organize the available relevant Y4 mental design - describe the algorithm), as well as the formation of additional (expansion) of the communication channels is synchronized (via the Internet) the audio signal (synchronous to scroll the audio tracks from multiple Internet points, separated by a space of thousands of kilometers or, for example, similar to radio, etc. synchronized time signals broadcast on these Operators). U1 has (without any additional manipulation, Y4 - need mental control) are more focused on the "locality" of signal - object table. In my opinion for Users that are not always coping with the mental control, the U1 is more suitable at this stage option in turn as well (if you wish) which helps to learn is the mental control, manifested through enough transmitted signal and its changes, as well as the "bright" channel feedback.
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: proposed changes in trademark row the entire line BJ-SK
all quite true - Y4 it is a big power, and other signal parameters, including work in the plane of time. U1 and - easy learning option for everyone, often following the purchase ск1м, and often to such.
In addition, U1 is not limited to the sale (the current time), and Y4 can be, especially for "heavy" full version.
There is also a V5, and the flow direction, but we won't put in the catalog at all, as a specific and overly expensive device, it is extremely difficult to manufacture and highly restricted distribution, in the sense required capabilities of the operator.
By the way on a number of parameters, the system U2-U3 is available publicly, differs from other models, and in some cases better, ie, it, too, just different.
Y1 and Y4 gives the possibility of very large, and U2-3 currently specializes in working with large groups, in the sense of a large number of consumers, though with less capacity on each connected. In General, the Y4 can surpass U2-3 at the instant power and the possible number of connected too.
But U2-3 has a 1000% fault tolerance in time. The last 2 months Y2-3 does Not use physical hardware for their work. The problem is that U2-3 not cloned
and the meaning is not. For the end user wanting more, the most suitable time of the commercial version.
Also very interesting subtype of the amplifier will be EP.
Already nearing midnight, and Herman all there...
I wanted to say, the end of the year already, and the programmer is not...
Not talking in riddles, decipher, who is this your EP?Михаил_ wrote:Also a very interesting subtype of the amplifier will be EP.
And here's another in the comments to the reviews by Shielding the camera (which is in the office):
Sincerely, MAG.no 〠<
Here.Михаил_ wrote:EP2 may appear at the beginning of January or end of December.
Clearly understood, as will be realized, can specify equipment, requirements, and estimated cost.
equipment 5*6+6 cards laminated cards containing decals Panacea with special program, similar to that used in EK + special additive to it, actually providing increased shielding without the physical screen.
5 stickers on every wall and floor and ceiling (corners and center) ACC. these parts should be available. Permitted temporary installation of cards (dvustoronniy tape, pins, etc.) to be able to move to another room, or take part, in a time when the room is used and cards can cause issues. 6 cards designed for Windows and doors. A Grand opening for the doorway. If the room has a window with a large number of glasses - it is recommended to try another room..... a variant of optional equipment is discussed individually.
In the middle of the room, for the suspension of the chandelier is a special source of energy to power all the cards and start the system. It connects to still hasn't appeared in the sale of "Programmer" for panacea, as the external device, the cord (or rather 4).
The cost of the entire complex probably will be around 75T.
Михаил_ wrote:And I hope ЭП4 the effects are not much weaker.
Владимир Ш.
- Has thanked: 19 times
- Been thanked: 34 times
yeah, 3.1 is delayedЛогик wrote:Already nearing midnight, and Herman all there...![]()
Владимир Ш.
Oh! MAG.no - thank you for the good news! Really are waiting for a holiday
you really really want
3.1 in the process of making the first batch, although as with other E-products (the first publicly available was range-2) a mass of jokes occur directly in the process, so I know that in the next few days will be ready, but when exactly - don't know what tomorrow will not be
well the next day at (the closest realistic period Wednesday or Thursday)
EP-5 I have a sample in the box - ie fully custom version assembled to final form. Along the way we threw away her electronics for the non-standard modes will be used by the programmer, which is still not yet, but the EP will be terribly indestructible and reliable thing in one case it is still live a normal life not wanted (electronics that generates EP).
The situation the programmer will update tomorrow, I expect confirmation of readiness of mass production (there were technical issues with the reference boards ready interfaces (internal memory to the SD card is not removable and the Bluetooth for the prof version). Given the close release of EP, the programmer will soon begin to fit much out.
Especially want to pick up all of the tails (we still have not released E 3.0, E-pendant and E panacea pendant OZ), the delay is expected to be only on the "Genie" to it yet resources and the demand is not defined.
In other words we want to rake up the tails and focus on new products PC and Коммуникатор2 and several derivatives of the PC.
- Ольга К
- Сотрудник mindmachine.ru
- Has thanked: 1 time
- Been thanked: 17 times
Available in 3 pieces, hurry up!!!!Михаил_ wrote:We announce a reduction in the cost of U1 up to 30t. The reduction is due to the presence in the line of devices Y4-micro, is similar in cost and more powerful. Although from a technical point of view these are two completely different devices with different principles, each useful in its own way.
U1 is in stock at the moment (sometimes there are breaks of several weeks with their existence).
price 30000 RUB
the first batch arrived in the office, cost 15.Михаил_ wrote:announcement. we made three new case designs, showing hope a very narrow range of products to work with situations(you can say extra work).
In General, they are significantly stronger implementation of similar modules.
products
- shield (installed a virtual boom in a place where there is a very tough interaction with the world, the goal is to minimize the personal consequences and generally the consequences of entering into the world of custom courses), the analogues are viewed for example with 2.6 and the corresponding areas of the stabilizer, but a different way of implementing high-power
- stop (in a way similar to the module wall in order to create space with altered properties in your area of interest occurs as before, but outside interests gets in there with great difficulty, it outputs the part does not need interaction for short range, unlike the above-mentioned "shield" in principle and implementation, is quite a fundamental difference. "stop" is blowing everything around in time, space and cause and effect consequences. a shield is placed deliberately in a visible vector.
Both products are totally "eco-friendly" and "hygienic". Ie do not harm the world and you.
- broken ties. Rather abruptly breaking links virtually all. Has a relatively short relaxation time (stops working and goes into recharge). It is useful to disconnect from society, a situation external influences.
All three products in the light version are implemented in the form of laminated cards, small size (think a La credit cards). and have a neutral and active.
Will be sold a set of three at once.
Later, we will implement a very heavy version of all three (I think after the new year), but it will be expensive.
When using all three You are most likely short-term to neutralize any serious negative interaction with others drawn to You. During this time, you can take eco-friendly measures to harmonize the situation.
Broken ties less environmentally friendly than the first two. but due to the short time action relatively harmless.
All three products are useful to operators BJ 2.x 3.0, 3.0+OZ
I am able to interact with V4 as with the source and with the Stabilizer Operator.
Complete all three cards, two of each kind.
On the face of the card there is an inscription with the name (unfortunately in some places the letters are slightly cut off, as were on the verge of a plastic, intended for cutting in the production process, but the text is everywhere unambiguous). The name has two purposes. To understand where some steam and to activate-deactivate a particular function.
A pair of inscriptions inside - deactivated.
Out labels or cards separately (e.g. in different pockets) is active.
If the "shield" not ask, he will choose it himself among the active trends of bearing the risk.
Thus the whole set can be used even without mental control.
Limitation of use - no.
If there are different drives and sources of energy (ISB different versions, U1, U4, at, ск1м, SC-HF, TC2, stabilizer, and BJ just different versions above 1.x) of the function set are enhanced (if necessary) and can consume stocks or online flow of energy from these devices.
The first batch - malenica. Next will come next week.<
- Been thanked: 182 times
Yes, that's so crystal clear and beautiful stuff
- the size of a credit card.
Used a slightly different method of communication of information. Closer to the latest developments (PC).
3.1. Came to the office. not very much, if you go for them yourself ( not by mail) - check availability. additionally, will arrive on Friday ( same edition, did not finish finish ).
I have to state - the number of 3.1 affect the result.
Probably the best configuration ( I mean very strong), when there is a left and right.
In particular, this is due to the fact that in addition to 3.1 is still E, but not only.
Of course one 3.1 is more than enough to run the basic f-tsii 3.1 (activation vpihivaniya operator in 3.0).
Then, a bit about the installation.
There are two kinds of mounting plate:
- glue, i.e., permanent mount (preferably instant adhesives based on CYANOGEN-acrylic, called point 5C, super glue, etc., are on sale in household, car shops, stores, modeling, and other areas in excessive quantities).
- double-sided tape (installation to be able to remove and return 3.0 the ability to work less).
At first I wanted to provide a lining pad of double-sided tape directly, but then thought that maybe the number of applicants to mount the pad will always be great and they will have to spend time scraping away the tape and scrubbing the sticky bases from him, so that the adhesive is efficiently formed. As a result, I this idea was abandoned.
Left and right - conditional concepts? That is, the optimal two 3.1 are mounted on opposite sides of one bracelet, right?
I think "left and right" meaning side of the body....... the bracelet not because of the parties even provisionally, then, it would be the opposite.
It turns out a couple of bracelets with 3.0 3.1 pads on different hands (or feet....... or "diagonally" into different limbs).
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Yeah, I meant the two bracelets on both sides of the body (especially the most active users, as far as I know, this configuration is mostly).
The number 3.1 on the bracelet can be increased to two, but I would rather recommend to wait for the e-version 3.0, so it will be more cost effective.
I think we are somewhere after the new year start this thing over to the stream.
There are reasonable limits productivity... well, I guess all casting processes I'll pass on production, which will somewhat speed up the entire chain for already launched products.
well, I always ask without ekstrimizm I mean not to overload yourself and not spend money in vain, without 3.1 it is possible to do (i.e. I know when you can afford, but do not please to do an end in itself).
mounted on a slim bangle from 3.0 to pads 3.1
http://openmagic.org/31/31_1.jpg
mounting on wide bracelet 3.0 (well actually photo something combo 3.0+OZ via link, this is my personal bracelet)
http://openmagic.org/31/31_2.jpg
before installation don't forget to degrease the bracelet in place of bonding, when mounted on a narrow bracelet on the tape -be careful, it's more likely to lose.
the recommended position of the lining relative to the hands inward at the wrist(ie, where the clock usually clasp)
Configuration-how times are different) I have, say, one 3.0, but the "meteor". Therefore, it was important to clarify not yet reached the office.
PS Fell into a light stupor, studying two types of the same glue Moment: on the outer side of one written - metal (among other things), another tree (among other things))). Better second adhesive or the second adhesive gel? It is probably not the gel. Or odnofigstvenno?
better second adhesive gel - it forms a mass, and not just flows of liquid water. For the meteor this can be important because there is a link with a street side highly rough due to the engraving.
And I have where it "suddenly" (after payment 3.1) on the shelf among the documents appeared (never had that's for sure, if anyone "threw"))))))) home says see for the first time) a powerful, eye thickness not less than 1mm double sided black tape with multiple inscription on the protective film "NEW GALAXY®"what else is funny rectangle of size exactly 2 link while I use this "accident", the effectiveness of such fastener pads 3.1 to 3.0 S++ after you accomplish your goal.......
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
It is quite logical - 3.1 personalized bar earned and trivia (what is the concentration of no importance)have become easier to be implemented. Still it's all under conscious control and will be a beauty.
