The development of the mind of the machine Navigator.
Алексей Крячко__
As for the file types. Each mode is assigned a specific folder to contain files of a particular type or session, or mp3 or wav or combined session. File navigation is the ability to surf anything on the memory card and go into any other folders. I think this functionality is useful. As for filtering by type of file to "not the same" was not displayed - think of it, I agree that would be nice.
Copied first to the computer, and then through the card reader at the map NAVIGATOR SUN_WIND, tracks are played the sound is there (but just hiss a few keys), and there is no light at all (setup level 4, 40 volume), with the same settings preset start HEALING glasses work twist "copied to track" from the map NAVIGATOR via InnerPulse (while the NAVIGATOR function is not yet understood) glasses and the sound works fine.
Yes, when you scroll SUN_WIND at the top of the scoreboard lit Player / Decoder [ ] (with empty brackets), and when HEALING is spinning inside the parentheses sign [▣] (square). I do not dovlecel?
Sincerely, MAG.no
Sincerely, MAG.no
Very high-quality copy of the track, well, let's throw off any track, for example 11. already upload to file sharing, when ready throw a link in PM. Earlier yesterday, copied the Massage of the brain, but already deleted, arguing that the problem is in the copy-high-speed card reader. But now twisted the solar Wind that is with the maps of the Navigator at InnerPulse - works without problems.
Sincerely, MAG.no
Sincerely, MAG.no
Алексей Крячко__
Алексей Крячко__
Алексей Крячко__
Алексей Крячко__
try to take 44100, and best of 48000 samples per second (16 bits, stereo).Маг.нет wrote:copy Settings:
WAV format (without data loss), the rate 1411.2 Kbit/s (best quality).
Sincerely, MAG.no
I think the devil is somewhere in these settings, I generally try to avoid software where the speed is specified in kilobits - not always clear that the developers understand them. Still all depends on the width of the conversion.
Алексей Крячко__
Алексей Крячко__
the spacing is very narrow, somewhere in the region of 40 Hz(on level -70 dB) and about 3 Hz on level -6dB. I have no filter, and implemented a special algorithm to highlight the single-tone signal, called by the algorithm Herzl. And because I no effort is made to further filter and adjust - this decoder always works perfectly if the signal is present.Андрей Патрушев wrote:Alexey Kryachko__
And what if the capture filter? The difference is very small. Innerpulse is about 1 kHz
In Innerpulse analog circuit and it works differently.
The decoder runs continuously after startup, in real time, so even if at the beginning of the gate is not, then he should see if he's on the wrong frequency you need.
In version 1.10 the truth was a little bug - sometimes (very very rarely) after you have chosen to play a session or run the "svetanics", the strobe decoder will not turn on. It was necessary, or re-start, or the machine to switch on and off.
Now in the current firmware 1.11, this problem is solved - do forced initialization and reset gate decoder and mixers.
About Massage know, just last night up and the sound is normally played on the Navigator, although the player with this card without problems. Now downloaded a normal copy program.
L@on used EAC (Russian version) download simple, clear, in Russian.
Sincerely, MAG.no
Sincerely, MAG.no
