Neurofen
Post by Андрей Патрушев » Mon Feb 21, 2011 17:16
An anonymous report on the NEWEST Neuro-oriented device, the GROK..
http://www.keelynet.com/grok1.htm
I ordered a GROK box which arrived this afternoon. I had to know what was inside, so I tore it apart. Inside was a simple circuit board, for which I will provide a diagram at a later time, hooked into a TBA810S chip, the only thing I can find about the chip is it seems to be available from http://pepe.online.ee/~m.aug/tevalo/must.txtfor $11.00. The circuit board says SOUND MASTER on the top and TUNG YUNG on the bottom. TUNG YUNG is a Hong Kong company that builds electronics for all kinds of stuff.
The chip seems to be an amplifier. It is described on the web page http://www.cs.tut.fi/~pam/bebek.txtas a PT VAHVISTIN 7W. VAHVISTIN seems to describe an amplifier. This is rapidly looking like a $149 education, probably well worth it. The transducers look just like garden variety dielectric transducers. The kind in musical greeting cards. Instead of cutting into them however I think I will hook up some others and give them a try in the circuit. Except for the fact that this does work as advertised, I have the feeling I've been had, I will have to do some more experimenting with it to see if the same principals as the neurophone are in place here, but I think not. It seems to work by bone conduction but more later......
p.s. there is voltage on the electrodes just a few micro amps, but there is a potential.
More on the anonymous analysis of the Grok
Subject: Build a GROK for $5.00
There has come a "new device" in the "hear with your skin", parade. Dr. Patrick Flanagan developed the Neurophone in the early sixties and has marketed various production models over the years, at a cost of over a thousand dollars to the latest model which sells for around $700. The Neurophone as it has been described to me and in literature produces a ZERO PHASE WAVE which can be picked up by the skin, enabling one to "hear" through skin. This device was issued a patent #3393279 and investigated at Tufts University. It does not operate by any commonly known principal. I have been wanting a Neurophone for years, and had started saving to finally purchase one for use in releated research.
A new device has recently come on the market claiming to allow one to hear through their skin at a much reduced price. The manufacturer rightly claims no connection with Dr. Flanagan or the Neurophone, and claims that this new device works by an entirely different principle than the Neurophone and indeed it does. The different principle that it works by is called hearing. If you would like to experiment with the GROK BOX you don't need to do as I did and spend $149, actually $160 with shipping and handling, that it took me months to save. Follow these simple directions and you too can have a GROK BOX for $5.00.
1. Dig around in last years christmas stuff and get out a couple of those musical christmas cards, the batteries are probably dead anyway.
2. Remove the piezo-electric elements from the music box circuits.These are the metal disks usually in a white plastic resonating chamber. Be careful not to break the lead that attaches to the ceramic part of the elements. The other lead to the metal base, you can cut or desolder. Pop the element out of the plastic resonating chamber.
3. Solder the leads from the ceramic part of each element to a piece of phono cable with a mono jack that will fit into the headphone jack of your walkman, one to the signal and one to the ground. Only the one lead from the ceramic portion of each piezo-electric elements should be attached to the phono cable. You are actually forming a series circuit with your body as the middle element.
4. Put the phone plug into the walkman, use a stereo to mono plug adapter, and hold both elements by the metal part, or glue them to a piece of purple cloth as a headband with the metal half out. Your body completes the circuit and the elements begin to vibrate. HEY LOOK MA I'm HEARING WITH MY SKIN.....NOT.<
Николай3003
Post by Николай3003 » Mon Feb 21, 2011 17:55
ECCO
I was thinking to throw off the scheme of echofon on paper. Do you think there is a reason people worry or no?
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 12:14
bc
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Wed Feb 23, 2011 12:22
Николай3003
To copy the concept? well, you can
Экко
Post by Экко » Wed Feb 23, 2011 12:50
I have a generator with AM and FM modulation and plenty of adjustments. Here only range from 4 to 300 MHz, for our purposes, is not suitable or still try?
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 12:50
ECCO
Why not?
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 12:51
ECCO
mega you wrote!!! Well then, at the own risk.
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 12:55
not rasplava you dear EKKO?
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 13:15
ECCO
reached you my messages ?
Экко
Post by Экко » Wed Feb 23, 2011 16:01
came to only me at that moment was not.
And what will melt it?
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 16:07
ECCO
I'm talking about private messages!
Тапка
Post by Тапка » Wed Feb 23, 2011 16:44
from 4 to 300 MHz is a radio transmitter will work with a Micropower patikami)) I think not.
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 16:59
Sneaker
do not pull pitici
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 17:11
well, as always when it is not necessary, everything is there and when the special need is ay ay ay
Тапка
Post by Тапка » Wed Feb 23, 2011 17:32
Will not help us special....checked.....you just need according to our Intel, do - modulator AM ,a generator of ULTRASOUND,pitici.
Specialists all say no high voltage is nonsense.
But what prevents then add cascade high voltage???
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 17:44
Sneaker
there is about cascade and all have the opportunity to ask only okuratno if you will.
Тапка
Post by Тапка » Wed Feb 23, 2011 17:51
Plug-in our Agenda )))
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 17:53
Sneaker
go accomplish your goal if anything.
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 18:24
Sneaker
and SAC ?? Gone?
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 18:37
Sneaker
can still come in!! or you and Claudia something
and lichiko wn otbavlyay
Николай3003
Post by Николай3003 » Wed Feb 23, 2011 19:23
Sneaker
And how ?
Экко
Post by Экко » Wed Feb 23, 2011 20:24
Sneaker
see you on Radiokote, your new messages mean
Тапка
Post by Тапка » Wed Feb 23, 2011 20:35
Oh this radiokote,there is no support find 7 pages of chat flooding and obscurantism ))
Sit your running lights solder and pension advice is given .
Экко
Post by Экко » Wed Feb 23, 2011 21:06
and where are you going to ask questions?
Николай3003
Post by Николай3003 » Thu Feb 24, 2011 20:23
ECCO
Good Afternoon. Is who?? Case intereste.
