Club
Generators of bio-energy (orgone)
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Aug 23, 2010 12:35
..."The conductor" A. Patrushev also "there" knows the way...
Sincerely, MAG.no
Смелый
Has thanked: 2 times
Been thanked: 79 times
Post by Смелый » Mon Aug 23, 2010 12:38
From the Reference State do not need to send anything. I don't know what a "zero point", but I do not impose anything to anyone. I'm just sharing my knowledge and experience.
Good luck to everyone!
Post by Маг.нет » Mon Aug 23, 2010 13:22
Bold! I just thought the similarity between "States", so I added this name. This state is the "point" is characterized by harmonizing the conscious with the subconscious. This place of "true self" (of the subconscious), no "add-ins" of consciousness. I.e. in the above example (by the way good, has not previously been known "the road") status allows to manifest the subconscious.
Success!
Sincerely, MAG.no
Post by Михаил_ » Mon Aug 23, 2010 15:19
There is another reason, in addition to the attunement of consciousness and the unconscious. This is what I call the zero point (many people, so many definitions of) = a condition when the own movement is not active. A full Dao even for a short moment. At this time, the perception ceases to be distorted by our own impact on the world, and the accuracy of perception realizes the accuracy of the subsequent impact and its effectiveness. Ie in order to do something you must first for a moment to a complete stop, continuing to distort his action, his perception.
Ideally, our halves of the contemplator and the Creator must work alternately. In reality, they almost always have to be simultaneously active.
Смелый
Post by Смелый » Tue Aug 24, 2010 5:45
After discovering the Reference State (ES), you can begin to practical use.
This is done as follows. Sit, as it is more convenient and some time to relax. Then call on the Internal Screen General plan of the place you have identified as your ES. If you need to go there by car, first see the road we would drive on this road. Or in other words, the road is coming at us. That is, a greater space is coming (I say approaching, it is very important), you approach the place. It's like when you work on a computer map. In the end, you need a place like runs into you and you're in that space. Feeling as if you put the suit. You are in your ES. Experience it good, clamp it. It's like new clothes dressed and make all the folds to the body. It is important to feel, if it still see or hear, even better. But to feel important. You can do with your eyes open, because feelings are primary.
Sit in this state. Feel how calm your emotions and thoughts. After some time cause a General plan of where you really are and begin to push yourself. City, street, house, office, apartment, armchair, chair, you on the chair and himself sitting in that chair you just put on yourself, exactly as you wore ES. And sitting on a chair to see the place of the Reference State, it begins to separate, it appears the environment, forest road, etc.. the Internal Screen is dim, around you the usual situation.
Only in this way. Golden state is coming up against you and getting dressed, then while in ES cause and pull on his usual place, clothe themselves and alienate (required) place of ES.
This technique can be used as a daily meditation cleans the energy field from possible energosberezhenii. Small ones at first, with regular practice, and heavier.
On how to use it when working with targets later. Need to practice entering in ES.
Good luck to everyone!<
Post by Маг.нет » Tue Aug 24, 2010 12:06
That's why ES, it is now clear that hasty remarks. Interesting technique...
Waiting for the continuation...
Sincerely, MAG.no
Смелый
Post by Смелый » Wed Aug 25, 2010 6:41
Now, the practical application of ES in terms of determining the truth of a specific goal for a specific person.
Create two emotional indicator. It is very simple.
The first positive. As a positive indicator, it is best to take favorite product, vegetable, fruit etc. anything that you are very much like. To distraction (no need to take loved ones or favorite animals, only inanimate objects).
The second - negative. Remember something that you particularly disgusting, even to disgust. You can take insects, snakes, etc. again, People don't need to take.
Sit in a comfortable place, relax. Called on the internal screen of ES. ES gradually you coming, here it is next and you are there, in their Reference Condition. Gradually calmed down, came in harmony with the surrounding world. Mentally take it out and see before us a positive emotional indicator. Note that from happening to You. Changed breathing, emotional state. Did not invent and customize. Only fix. Remove positive indicator. Just sat, before the second, negative indicator. Fix the breath and emotions. Remove negative emotional indicator. It is strictly forbidden to compare emotions. Called on the internal screen image the place where you really are now. The image slowly creeps on you and you on your place. On the internal screen image of the Reference State. It's deleted, close the internal screen.
Analyze and compare their feelings when in s when you consider ourselves emotional indicators. Clearly, they are different.
Now that it gives us. When working with target verification for validity. Do everything the same, only instead of a negative emotional indicator, cause the way of his goal. If while visualizing your goal in ES, your feelings are the same, congratulations. This is your true goal, who can't wait for your actions on the way of its implementation. If not, feel closer to negative emotional indicator,,,. In General, there are problems. The subconscious, karma, your personal qualities, which is not enough finding you in the wrong place etc. But the goal in the near future - is unattainable. And no devices will help you to achieve it. Yet. By the way, the target can be not only the subject. The situation can be, in particular, the forthcoming risky business. Relevant to you particular person. While in ES has caused its image and compared with positive emotional indicator. By the way, always be sure to first check on the first indicator. It helps to check you entered in the reference state. Such verification can only be done once a day. One goal. Meditation in ES much as anything.
Next. Autumn comes a Golden time. For those who have trouble finding in ES. As well as others. Choose a day during the fall, when Sunny and windless, retire at the pond and quietly look at the slowly falling leaves. Silence presses on his shoulders, good for the soul and peaceful. Come into harmony with the surrounding world. Feel a sense of oneness with Nature. Remember that state. Now it's your Reference As you can to work with him.
Good luck to everyone, a large number of purposes and desires, entirely to implement them!<
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Wed Aug 25, 2010 12:26
Good afternoon everyone. Today I reread some threads on Radionica. A question for those who have studied the forums in English. What people on foreign websites uses as Trends?
Thank you, if someone wants to share information.
рыжая
Post by рыжая » Wed Aug 25, 2010 23:06
Humpty-Baltay, your offer to participate and answer questions to the extent possible, is still in force? MAG.no? Brave?
Appeal to all forum members who are interested in the topic of Radionics, is anyone else ready to chat, share experience, to help newcomers?
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Thu Aug 26, 2010 10:24
not operate like
Смелый
Post by Смелый » Mon Aug 30, 2010 2:45
I'm all For, of course! Questions and I have many. I want to organize everything and that would use it would be as simple as the multiplication table. Today begin to make a list of questions. The situation is simple. There are advanced users, like Humpty. He has all the understanding is in the General at once. He doesn't need to go into details, because everything is clear. For someone (me in particular) requires understanding of "the stove." That is, if this pen, or Werner, will turn, it will begin to push the process in this way, and this affects the position of target or Trend, etc. And that's just expanding everything on the shelves will go the actual motion. But Humpty is not obliged here to chew everything, and probably boring to a lower level to descend. And so thanks to him, he has done and is doing a great educational work.
рыжая
Post by рыжая » Mon Aug 30, 2010 11:23
First, initially the idea of a seminar on Radionica and the idea of the chat belongs to Humpty to Baltay. So it was what it needed. :) The question is whether it is now?
So what are waiting for a final answer. :)
Brave, thank you for keeping ideas. I have a few questions. Rather interesting to hear other people and discover something new. So for example a long time ago, accidentally learned that Andrew Kabakov puts the device for a day or more without turning off, and not as Carl has written in a few hours. Was a day and a half I begin to show results. The construction of Baltay was the idea on the subject of money to lay down semi-precious and precious stones. I put the gold, I believe that this increased efficiency.
So every little bit helps. :)
Post by Маг.нет » Mon Aug 30, 2010 12:34
Will Express an opinion about chat. A very handy thing!!! at the time when they all got together and have something to discuss, but the time is different... sometimes, in the process of communication, take the chat to the forum less clutter reflections.
YA! A little bit over time will understand - I will run...
Sincerely, MAG.no
Малика
Has thanked: 251 times
Been thanked: 110 times
Post by Малика » Tue Aug 31, 2010 14:41
Good afternoon everyone! I happened by accident, opened two Windows at once manifest. Not become clean, and loaded it as well as the first and left to work. Then, consciously opened up and third window from the manifest and set "Boost energy" and after about an hour felt his work. Then work those two Windows with another program. Today opened four Windows Manifest immediately and downloaded one program+the same program on RADе RAD.. sometimes it works for days
Post by Шалтай Балтай » Tue Aug 31, 2010 16:04
Малика wrote:Then work those two Windows with another program.
Yes, the Windows manifest, you can open as many
just remember that in this case the energy will be "sharing" (to be distributed) between tasks (trends)
Post by Маг.нет » Tue Aug 31, 2010 16:42
Шалтай Балтай wrote:just remember that in this case the energy will be "sharing" (to be distributed) between tasks (trends)
...if You write a bunch of target-the Trend of "equal distribution of energy between running Trends" Manifesto, "notes" (in the appropriate fields, Radionics), or mental...
Otherwise, the most powerful ligament (structural link) is to take the energy for themselves (to "complete filling").
Time spins...
It is necessary to divide the flow of filling bundles of energy for the two positions:
-to associate elements of the "thought forms";
-to create the Trend momentum and the energy of the Trend.
So that the device "made a bundle" filled with a small amount of energy - 2 hours on the recommendations of Charles, upon receipt of response within 1-2 days is formed a connection is created and applied filling pulse...
Better to present simple:
2 hours first broadcast - fed and allowed to "Worker" task, if returned within 1-2 days (if not returned, "response" is not shown, it means not there or not it was sent, or the road not there - corrected) feed again with the same "trough", what to do, he already knows if you're hungry, it knows where to go (important that "busy" was not).
Something like this.
Sincerely, MAG.no
Малика
Post by Малика » Tue Aug 31, 2010 16:55
Humpty Baltay, MAG.no., thanks for the clarification
Post by Михаил_ » Tue Aug 31, 2010 20:15
you will notice one obvious thing about the 2 hour and other triggers - they will work differently at different times of the day. It is a fact, proven
Post by Маг.нет » Tue Aug 31, 2010 22:09
Yes, ALL the TIME, and when you don't know exactly "when?" you can't expand the time range would be very useful (maybe hooked).
And maybe otherwise, Radionic, such as 2400, for 2 hours (more powerful models in less time) "registers" (fixes) thought, and a little fueling her, and then, in TIME (according to Trend), there are structural changes. For this is no longer necessary to position the instrument (or scroll the intention mentally) a bunch of target-Trend, she RECORDED "spinning" constantly, periodically, from ArgumentError. Maybe so, and manages time...
Sincerely, MAG.no
Post by Маг.нет » Tue Aug 31, 2010 23:30
Time of response 1-2 days, can be so in time and "stretched" that you need to wait for the right TIME to catch and "netupdate track"... by "stretching" the time of the first element (waiting for the right time) - "stretched" in time the entire first stage of the process - fixing thought-forms, life "path of change" (algorithm Pattern) how to use your subconscious ("the formulas of achievement"), so with the help of basic algorithms and device bindings to "magic formulas" (a Manifest, for example, and again the subconscious experience).
Sincerely, MAG.no
Post by Михаил_ » Wed Sep 01, 2010 0:10
better communication will occur at night.... and the impact depends on the type and need of the barrel.
рыжая
Post by рыжая » Wed Sep 01, 2010 0:52
Михаил_ wrote:better communication will occur at night.... and the impact depends on the type and need of the barrel.
At night it is because the consciousness does not interfere?
The link type refers to what? How it structural?
What kind of trunks are these? In such schools uncle Karl passed.
Post by Маг.нет » Wed Sep 01, 2010 8:28
At night probably because the "ports" channels are open (or less loaded).
Type of communication - for example, "Basic action" of the Manifest connection to one of the 22 channels (trunks).
Can you?
Sincerely, MAG.no
Post by Михаил_ » Wed Sep 01, 2010 13:13
at night time, because this time activity planetary quality separationthe system 15 referred to as the lasso. He is responsible for the communication (creation, destruction, etc.).
I would like to add that, purely from practical observations and for a number of reasons, it is better that the moon was at a minimum.
Post by Маг.нет » Wed Sep 01, 2010 13:25
the Tree of life (author - Sator)
In ancient times, Magicians have made a scheme of the functioning of consciousness Genius of the Earth. The processes occurring there, of course, impossible to understand on a human level, but some abstract constructions allow one to assess the overall picture and, most importantly, make it possible Separations Magic. The study of the functioning of consciousness Genius of the Earth, the ability to enter in the desired channels, is the basis of all Separationthe Magic.
There are ten Sephira (spheres, information centres) consciousness of the Genius of the Earth (which is humanity). They are discussed in detail in the Kabbalah are a kind of manifestation of the Genius of the Earth. They are named quite abstractly, not to be taken literally. In parentheses are the English transliteration of the Hebrew.
The Crown, Keter (Kether).
Wisdom, Chokmah (Chokmah).
Mind, Bina (Binah).
Mercy, Hesed (Chesed).
Severity, Geburah (Geburah).
Beauty, TIFERET (Tiphereth).
Victory, Nezah (Netzach).
Glory, Hod (Hod).
Form, Yesod (Yesod).
The Kingdom Of Malkuth (Malkuth).
The properties of the first three Sephira are more in the mental world, the next three in the upper layers of the astral world, the next three in the lower layers of the astral world and the latter - in the physical world. Various human actions can be considered as moving on Sefira and channels of the Sephiroth tree, such operations are used in Magic to influence the mental level.
Ten information centers United by a common pattern called the tree of Sephiroth. Sephirah in the same manner are connected by channels with pipelines carrying not only energy of a specific property, but also the information (due to the heterogeneity of the distribution of the energy). Only 22 channels and each of them corresponds to a specific Arcana cards of the Tarot and connects the two sephirah in the same manner. The harness is the way to stay on a particular channel. Modern Tarot cards have 22 Big Arcana, of the respective channels of the information structure of consciousness Genius of the Earth, and 56 minor Arcana, corresponding to the States of matter.
Large Arcana give way to stay on a particular channel the Genius of the Earth, receiving the energy of some properties and perceive the running channel information. A deck of Tarot cards, obviously, is a symbolic display of some magical book of ancient Egypt. On the cards in the allegorical form, is drawn of the human condition, which is connected to the channel. The image is encrypted in a certain way, can be the only one who has the keys to the picture. Reproducing specified on the card as the Magician is connected to the right to work channel. Any of the 22 Great Arcana of the Tarot is a way of entrance into the corresponding channel of the Genius of the Earth.
All people are part of the consciousness of the Genius of the Earth and performed in this consciousness of the role connected to one of the 22 channels. The connection channel may vary for each person depending on what he does. Consciously connecting to different channels of the Genius of the Earth, you can get a energy of particular properties required for specific impacts. For such purposes, use a special magical machine or Tarot cards. The latter usually apply the laity only in divination.
Sincerely, MAG.no<
