Radionic devices Karl Welz.
Ванька-встанька
Ebola in the snow goes off in the morning without stopping! The bike will get stuck
And Schumann 2nd, in the sense of 14.1 Hz - Beta?
Ванька-встанька
- Has thanked: 1 time
- Been thanked: 182 times
Last Wednesday brought home RAD 2400HD Two days off kidney apparently was normalization. After that has improved sensitivity, went brighter job with the twins. Drew attention to work with Svetlitsa Super after a time feel at sea , waves shook from side to side.In General, the movements, the work went more meaningful. With the cylinders of the Pharaohs twisted in the spring, this impact previously, it was not close.
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
- Шалтай Балтай
Krutov for the first timeАндрей Кабанков wrote:Leave for the night,in the morning write a review
IMHO guys - you better agree. This is not a joke, besides link - hard - photo - it can not "disable". So if Vani will need can be troubles.
IMHO - better to put something more Minaeva (what is 600 Hz?) - Schumann better IMHO.Андрей Кабанков wrote:frequency soft switch MAX
Ванька-встанька
Humpty Baltay! Let's leave it at that. If the van in the morning will not accomplish your goal - so he heathens and need
. And what about the order (still 1,000 or 10,000 devices were sold): so Carl started it. If, for example, 1,000 cars to sell - they have to be reviews. If You do not ask Dimas'and "please Give me feedback. Look"?
- Шалтай Балтай
- Шалтай Балтай
- Шалтай Балтай
Ванька-встанька
And on the mummy of Pharaoh did not try? If a person has no sensitivity to subtle energies and it does not feel the movement of energy, it will help probably the only room of this unique in the epicenter of a nuclear explosion. You may first find out the sensitivity of the subject, and then experiment? For purity of experiment.Ванька-встанька wrote:feel all the same as yesterday and the day before... Tried to hold the card under the glass of water half an hour, the taste has not changed. Not you little brat so...
- Шалтай Балтай
Ванька-встанька
Ванька-встанька
Sorry, but Your statement is akin to "If you have 2 legs - why would you want a bike?"Смелый wrote:A mummy of the Pharaoh did not try? If a person has no sensitivity to subtle energies and it does not feel the movement of energy, it will help probably the only room of this unique in the epicenter of a nuclear explosion. You may first find out the sensitivity of the subject, and then experiment? For purity of experiment.
- Шалтай Балтай
Were there any other copies of the SAME photo?Ванька-встанька wrote:the Photo was indeed mine, I was asked to use as a Target
Ahem....Ванька-встанька wrote:Card, which I printed out and put under a glass of water was from a free 2-hour test
You talked with Karl about the test?
Or Andrew had posted a copy of the card on radionic?
Ванька-встанька
About the copies - I don't know. The photo was from a digital camera, were stored on the screw. To reduce the weight drove it into another format and sent by e-mail to Andrew Kabankova.Шалтай Балтай wrote:were there any other copies of the SAME photo?
Directly with Carl agreed, just made a request to send the card to your e-mail. Now picked it up and looked: the card was still 1 hour: number, name, and end time of the test.Шалтай Балтай wrote:You talked with Karl about the test?
In fairness, I note that I don't respond to even so-called "Gypsy hypnosis". Hi Wizowski Roma
- Шалтай Балтай
Norms.Ванька-встанька wrote:About spears - I don't know. The photo was from a digital camera, were stored on the screw. To reduce the weight drove it into another format and sent by e-mail to Andrew Kabankova.
It was supposed to work
If done as stated in the test - so everything was supposed to workВанька-встанька wrote:Directly from Karl didn't agree, just made a request to send the card to your e-mail. Now picked it up and looked: the card was still 1 hour: number, name, and end time of the test.
Well, if no difference I feel - maybe it is You and not necessary. IMHO.
Ванька-встанька
Question Andrew Kabankova. You wrote above that You have a work colleague who is feeling subtle energy (her name is Lily, I think). It also saw the emergence of certain structures in the device Radionics, namely when working with Codes of the Arcturians. Can she describe them? This is sensation (visual, auditory...) or something else? Very interesting!
Lily was asked to describe the sensations from Radionics,until she tried to feel it.A structure sees the other person.In Radionics the code it was the Golden light grid.
Today Lily was watching codes of the Arcturians,they have on one side a picture of another silver code.Lily drew sensations from images with closed eyes.Now,her drawings were almost identical with the codes on the reverse side.
well put to say is valid or not is not always so immediately. Not about hypnosis - where consequences are judged
and about the photo. For purity of experiment it was necessary to measure the condition before and after. The Kirlian electropunctural or there, or there is a lyre of the same, etc.
Ie, many are just not used to analyze a certain stream of sensory information and prompt changes to "cocoon" did not register on the conscious level. But you can indirectly result to determine the total change in status, such as reduction in sleep time or the total psychological mood (or Vice versa, at constant sleepiness, which, incidentally, is a consequence of the start of the regenerative processes in the body).
Ie if you do not feel - does not mean that works for You.
Was (but still there) the only one "not feeling" anything... Wade
question in signal strength followed by objective changes, which are registered already is not a sensory perception, and logic, because everything is clear. (people really don't radionically Wade but that's not the point, I for example)
PS photo fresh is better in such cases to take and in full growth.The effect can be significantly stronger. Even get a signal through the photos no problem, usually the problem is not to
hmm.
