About the bracelets ( old theme,ported from the Gazebo )
СлаваМ
Has thanked: 33 times
Been thanked: 13 times
Re: the bangles ( an old topic,moved from the Gazebo )
Post by СлаваМ » Wed Jan 25, 2017 12:52
Did 1.0, while watching the changes in the condition of the chakra and energy in General, Michael - You rock!! Thank you very much.
Went to test modules :)
Еленка
Has thanked: 2 times
Been thanked: 4 times
Post by Еленка » Wed Jan 25, 2017 22:35
СлаваМ wrote:did 1.0, while watching the changes in the condition of the chakra and energy in General, Michael - You rock!! Thank you very much.
Sorry for little off the top.Just read it and thought:
....We had to intervene. not a step back!
And on the voltage knees are shaking,
And heart ready for the top run from the chest.
The whole world on the palm - you're happy and it
And just a little bit jealous of the
Others - whose apex is yet to come.
митек
Has thanked: 23 times
Been thanked: 15 times
Post by митек » Mon Jul 24, 2017 16:11
Good day!
I've been a theme with the bracelets began to study. A total beginner. I want to try to make yourself 1.0
Was thinking to buy a cheap bracelet and charge it.
Found a bracelet made of stainless steel with magnetic inserts. The magnets themselves should be curative.
Question to experts: Can better the simpler the better? Or material does not matter? Magnets will not hurt?
Thank you!
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Mon Jul 24, 2017 18:29
1) the effects of magnets You details to predict/estimate will not be able (if You are not an expert), so maybe not worth it?
2) better something non-metallic. it does not matter, but Michael talked about it many times - the metal in the field of the cocoon is not always good.
3) why the first version then? make a Panacea - a quick, simple and effective.
тороборо
Post by тороборо » Mon Jul 24, 2017 18:43
made a homemade cure-all via video. prompt, please, as a bracelet to switch in 2.9
show, using the word to illustrate. or please explain. I don't understand how to do it. Thank you.
that's copied from the site quantummagic.
The purpose of this matrix is more likely to switch the panacea 2.9, or 2.0+
Switching the return (which will be published return the matrix to the neutral state "panacea").
You'll need two sets of squares of equal size.
1st must have inside three cells (i.e., a square 3-by-3).
The 2nd must be within 4 cells (4 by 4), but to have the same as the first direction (to be the same size).
Equipment configuration the following:
Fill in the squares 3x3 worksheet the following content:
732
195
342
Then fill in the same sheet squares 4x4 and they are filled with content:
3412
4731
5325
1170
ie get the numbers on top of numbers.
In this paper wrap the panacea minutes... 10-20, and it is switched to stationary mode, where you don't have to go out myself, unless You get into some serious trouble, where is her other configurations will be vital.
The owners are not full, and the matrix a panacea, too, can try (especially the paper version, it's quite simple).
The matrix, which introduces a panacea to "cure", can be slightly stressful, because it erases a previous alignment with the operator:
012
341
723
1144
3265
1789
1334
ie a panacea for some time it will work "good as new" and can it you to rock.
Бисо
Has thanked: 49 times
Been thanked: 38 times
Post by Бисо » Mon Jul 24, 2017 19:02
тороборо wrote:show, using the word to illustrate. or please explain. I don't understand how to do it.
митек
Post by митек » Tue Jul 25, 2017 21:22
Владимир Ш. wrote:1) the effects of magnets You details to predict/estimate will not be able (if You are not an expert), so maybe not worth it?
I'm little read, but as I understand, a panacea it is strong and not for beginners? Or is it not so?
Where to find links on how to do it?
Thank you!
Бисо
Post by Бисо » Tue Jul 25, 2017 22:06
митек wrote:I'm little read, but as I understand, a panacea it is strong and not for beginners? Or is it not so?
It is possible for beginners.
http://support.quantummagic.org/showthread.php?t=104
Владимир Ш.
Post by Владимир Ш. » Wed Jul 26, 2017 0:11
And if in the beginning it will be harsh, you can switch in 2.9 (see above).
митек
Post by митек » Mon Jul 31, 2017 13:06
I tried to make a bracelet 1.0 from the skin. All of the recipe did. When unpacked Found that the water got into my packaging.
Ie a bracelet with the headphones lay simply in the water. Headphones tried after that, and apparently they covered, ie working, but could hear very little.
Don't know how quickly it happened.
Wearing one of these yesterday. While I can't say anything.
Does it make sense to "charge" again?
If the bracelet rosadilla still, what happens when you re-process?
But if not charged, then I have nothing to lose?
So?
митек
Post by митек » Mon Jul 31, 2017 13:07
тороборо wrote:made a homemade cure-all via video.
And do not tell where the video was taken?
митек
Post by митек » Mon Jul 31, 2017 13:10
Is it possible bracelet 1.0 to do another cure light?
The goal of rehabilitation and the addition of life energy
Been thanked: 10 times
Post by Мастер 108 » Mon Jul 31, 2017 15:49
The bracelet is not discharged.
Can the charging process to be repeated if there is any doubt that he was successful.
Video Panacea in a topic branch.
BJ 1.0 can optionally take a Panacea-Lite, but it will be a Panacea-Lite :)
Post by Михаил_ » Tue Aug 01, 2017 22:43
In other words when you record another, more powerful version, she will be the only one on BJ.
The old charging system (with immersion) is now used little, because for a long time made more simple things like matrix panacea for example. It is quite simple.
In the section about homemade products on my forum, everything is there. Selection of homemade products is huge and among them are plenty of that can be done simply with pen and paper in hand.
Влад Н.
Post by Влад Н. » Thu Aug 03, 2017 10:15
Мастер 108 wrote: BJ 1.0 can optionally take a Panacea-Lite, but it will be a Panacea-Lite :)
Feel, the bracelet Panacea Lite is made from the bracelet BJ 1.0 (the card transfer 2.2) differs from a Panacea Lite is made of pure bracelet. In the first case there is the presence of BZ 1.0 :) Only the Matrix a Panacea that I had caused mental, but very much on one subject :)
Post by Михаил_ » Fri Aug 04, 2017 1:31
mmm .... it impacts (footprint) of the map of the migration to "clean" object, give more "juicy" pan-Lite :)
митек
Post by митек » Thu Aug 31, 2017 1:17
I blunt. Read the thread, but do not understand how to make the panacea... :( Probably so simple that I do not understand...
Do not tell needy?
I made a 1.0. loaded in water leather bracelet. Wear a month.
3 weeks on the left hand. Then began on the right. On the right hand is clearly the heat from the bracelet for the last 3 days.
Don't know what it gives me, not yet understood, but wear nice. Feels like people have become to me more friendly attitude.
At first it was like the be very not comfortable. Now when you take off, something is missing.
Want to "charge" a watch with a titanium case and bracelet, i.e. make them a panacea. Does that even make sense there?
I couldn't understand what bracelets you should wear when, how much and for what. Start reading threads and forums after hours of reading I understand that do not understand.
Apparently it's not time yet. Maybe I not worth while to bother?
Бисо
Post by Бисо » Thu Aug 31, 2017 2:25
митек wrote: ..... Read the thread, but do not understand how to make the panacea... :( Probably so simple that I do not understand...
At every link of the band write the matrix:
AIT
WYO
ONYA
Leave aside for a few hours and you're done. The matrix will fade with time but it is necessary only to start the process.
Or better take a video pana2 run on the tablet so that the roller is spinning continuously and put the bracelet on top of the screen. So leave it for 24-48 hours. "I recommend screening space charge using a homemade Pandora-black - will Strengthen the process in ..." With the help of movie get more full-fledged Panacea.
митек wrote: Want to "charge" a watch with a titanium case and bracelet, i.e. make them a panacea. Does that even make sense there?
Metal is not the most eligible material for the manufacture of BJ. But if you really want to then apply the charging method with the help of video pana2.
Make two bracelets Panacea for left and right hand as the beginning. Keep reading and all will become clear with time. Well, a homemade Pandora-black will benefit from the very beginning. In a few months or sooner feel you can add a homemade 3.0 N.
Has thanked: 5 times
Been thanked: 16 times
Post by Вячеслав. » Sun Sep 03, 2017 11:23
There :) the belief that the skill zarabatyvaet 21 days then we are working on/ fixing running) as you like... in this matrix transfer to different modes wrapped pendant handmade ), supplemented with U - stick , just naively believed that mental nastolatka pumped being able to translate in any mode, the Cure.. more time passed since the beginning of training for more than 21 days started to feel some of the nuances Yes, pride is suffering :) but take a printout mentally set the mode and voila, qualitatively and harmoniously built my processes
Post by Вячеслав. » Fri Dec 22, 2017 0:55
In the Gazebo on one knee and... Proposed algorithm is a homemade BJ,left bellsou degree of freedom :) hi inspairens! So I thought
In nature, the nuances and the truth is not understood... but rather intuitively understood and did right... but in the description of my complete mess :)
dem further.. Handmade 2.51/2.61 etc. are Superfluous not take ... whatever Macedon,father of the founder of modern logistics (every man his carries),and with the suggested runes... "Float" ) on a mutually beneficial basis.Probably so intended,each one will reinforce and complement the other so far... hmm,looking ahead)).
Cola mentioned so-called pendant ) although he has become an integral part of me... the impact was soft like water,although at the beginning of the world? radicalized by ahm.to my person,or person neuchli radicalization me :) Harmonious trail in the local area (harmonious it is in my understanding a softener reality).Mark,if you are,I trust that such exposure will result in a blessing... it is important to Nunavut,today's problems will seem trivial tomorrow ... Often the challenge is irresistible and invaluable people can be.You have an understanding for example,that the person is not Prov if you do not need to call for help :) step aside... beat sit.under different modes and release...There you see everything correct.My vision of how... just tuned in to the theme and shabby in pleasure
PS translation Matrix it is the matrix of translated... :)
