ЗОМБИ wrote:Шалтай Балтай wrote:the set of tools you use at the moment, quite accurately meet the objectives you have set.
dear
Humpty Baltay and
Bold allow me to clarify what tools are
EXACTLY what YOU... "list of techniques" requires... as you slim your torso develop... etc etc.
I have tried many things. Including buying devices on mindmachine.
Was there an understanding between the two paths of development.
The first is by using what are called "technomage". That is, with the help of any external lotions.
Second - work with your internal state. And the second way I have used to methods of use of technomagic. This is transcendental meditation, Silva, Bronnikov, Levshinov, Zhikarencev etc.
Because in terms of success in business that has not given me anything (I will say more, it got worse), I came to technomagic. Here I also nothing to brag about.
And now I'm back to work with his internal state, but somewhat different angle.
There is an author - Sergey Jagdish. I read his "Influence and communication" in the beginning of practicing spirituality. There is a cool phrase: "BEFORE you DO SPIRITUAL PRACTICES, TAKE your POSITION IN SOCIETY". I did remember, but didn't realise.
And the meaning of it is that spiritual practices, the thing crooked. You seem to be good, but the money is where it happened. And no matter how you try, but no. And it's really annoying. The effect of spiritual practices evaporate, you are at a crossroads. And either suck it up and go in rags to go to enlightenment, or something change. Besides, as I now understand meditation to develop your energy system a kind, make it crooked. Develops by and large one of ajna. The lower chakras are responsible for the material well-being is completely neglected. At the same time instilled the idea that money is an obstacle to achieving spiritual development.
So, Nikolai Karmishin, the author of the program from the website of Astra-systems, itself a business man and makes programmes including business people. In this case understands that a successful and rich man, is the first energetically-developed man, whose Consciousness and Subconsciousness are moving towards the same goals.
I have a website with a few programs.
"The Energizer determination"
"Power of the biofield"
"Tamer of emotions"
"The destroyer of fears"
"Wealth formula"
They are very a lot of attention is paid to the development of the energy component of man. And it is through the subconscious.
In the "Formula for riches" for example, five disks. Two video and three audio. Audio focused on the development of the power system.
Forgive me, Nikolai Ivanovich (hopefully not tear), but I'll paste the descriptions of these three CDs.
Disk "2"
Combo audio program to remove the blocks 3 and 5 chakra.
The objective of the program release 3 chakras from the energy of inclusions that prevent to lead people, to be firm in business, to demonstrate their will on the people.
Segment 5 chakra, on the disc, produces a hard karmic cleansing of 5 chakras. Listening to it leads to increased self-esteem, to release the blocks that lower your dignity. There may be a change in the character, if you were good-natured and not strong.
It is recommended to listen to once in 2-3 days. If there is an inner desire to listen to it more often, you will obey intuition.
Disc "3".
Combo drive with software amplification 4,5 and 6 chakras.
If the drive is "2" only removes old blocks, then the drive increases the energy of the chakras.
To listen in the first month of the disc needs to be in 2 times less often than "disk 2", so that the original was the dissolution of the blocks, and then, using "disk 3", strengthening of the chakras, responsible for the free passage of the upward and downward energy flows.
After the second month disk "3" is recommended to listen to 2 times more often than "disk 2".
CD "4"
The drive for harmonization of channels, and mixing energies.
The program allows the downward flow of the energies of the chakras 5,6,7 to output to the outside through the third chakra ie the energy of thoughts and desires becomes effective, mixing with the energy of the third chakra, and the upward flow of energies of the chakras 1,2,3 output to the outside through the sixth chakra i.e. energy responsible for health, vitality, power, material well-being receive "ideological" content and , thanks to the sixth chakra responsible for intuition, the subconscious mind going in the direction that best decisive goal.
Listen to this CD daily.
Especially the program "disk 4" is useful in cases when you are tired, are in the doldrums, or Vice versa – is extremely excited and outraged at any life situations and you need to be in balance.
I won't describe anything here, so as not to be accused of advertising other manufacturers.
But I can say that in 10 years many things have tried, I eventually found that I was completely satisfied.
These programs allow me to develop my inner state on the one hand, on the other hand began dvat results in business.
Well and in plans of acquiring probably the most valuable programs out there: "Energogarant",<
